Question about Compaq Presario 700 470024-192 Notebook
Wireless conection my wireless linksys card wont power up and connect
  • 1 more comment
  • vanesssa Jan 09, 2009
  • Teis Thomsen
    Teis Thomsen May 11, 2010
    Hi leeh121988 does you sound driver work, if so, from where did you find it?
    /Teis
  • John Hong
    John Hong May 11, 2010
    Both - What model is the card?
    Vanesssa - do you also have a Presario 700 computer?
    Both - What operating system are you using (Windows XP?)
    Both - More details, do any lights come on, does windows find a new device, are there any error messages ...
I can not conect to my linksys wireless router with my dell inspiron laptop I can conect to any other wireless network but the linksys help please?
Can you provide more information about this issue.
1. Is the wireless card enabled on your laptop ?
2. Does it try to search for available network ?
3. Do you get any error message ?
FixYa Team
Nov 12, 2010 | Dell Inspiron E1505 Notebook
Need to conect with wireless card to internet. moved and am trying to connect to my neighbors wireless modem with his permmision of course. windows message is that it cannot configure wireless connection....
Once you detect his network he wil need to give you his encryption key in order to connect. Otherwise you will be denied.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Cant get the Linksys to find the Optus DSL network
do you have security enabled on the wireless router?
if so, disable to security and see if you can connect.
if it works, check if you set the router security to use WPA2- it is possible that your laptop/wireless card doesn't support it- try to use WPA instead
Aug 02, 2009 | Linksys Wireless-G WET54G 802.11g/b...
Linksys wireless adapter won't auto connect to 2Wire router
Go into the wireless adapter settings and make your connection "default" and then it should connect automatically .. and if not then look for a "connect automatically setting
May 29, 2009 | 2wire HomePortal® 1800HW Router...
Wii wont connect
Wii should connect with Security set to PSK with TKIP encryption.
If still a problem please provide Linksys model, version and firmware.
Mar 21, 2009 | Linksys Wireless N Gigabit Router
Looks like conected but i cant get internet
Router might not be set up with the modem. Your router broadcast wireless signal when it is powered on, so even if it is not connected to a modem(where you get your internet from)you will have a local connection. That's normal. You need to set up the router. Call linksys technical support, if they cannot help try http://technicalsupport.blog.friendster.com
Feb 24, 2009 | Linksys Wireless-G Broadband Router
Linksys WRT54GS router needs to be rebooted frequently
Try to leave of air for an hour, untill its cold, then reconect it, if the time untill it quit conecting is consitrly longer, your Linksys is dying.
/Teis
Dec 07, 2008 | Linksys Wireless-G WRT54G Router
Wireles conection problem
I've run into this issue with USB wireless network cards from DLink, Linksys, and Netgear. For me, the issue was with the USB ports on the PC and not having enough power for the device, the connection would stay live for a random amount of time and then all of a sudden it would die (same thing would happen when resuming from hibernation or standby). I added a PCI card with a powered USB hub in it and it solved my problem.
Hope this info helps!
Jan 15, 2008 | D-Link DI 514 Wireless Router (DI-514)
Linksys card wont light up
ensure that the wireless adapter switch on the pc is turned on.
also check "network connections" to verify wireless adapter in there and fuctioning properly.
Nov 18, 2007 | Linksys Wireless-G Broadband Router
Internet conections
you will need either a usb 54MBPS or 108MBPS wireless adapter of any make that will connect to a usb port or a pci wireless card to fit in the pc tower on the motherboard.
Oct 06, 2007 | Linksys (WUSB54GCU) 802.11g/b Wireless...
Compaq Presario 700 470024-192 Notebook Logo
35 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
