Just wondering if a bytecc usb 2.0 drive mate needs a driver installed or if it's just plug and play. I hooked it up to my hard drive on desk top and then into a laptop and safely remove device tool came up and labeled it as a usb mass storage device but does not show up in my computer screen.
  • 23 Answers
Drivers are not required to use the bytecc drive mate for winxp or newer. detailed instructions can be found at my website http://www.brokendesktop.com
exact url is http://www.brokendesktop.com/index.php/page,Bytecc_USB_Drive_Mate.html
the jist of it is plug in drive mate to hard drive, power up hard drive wait 5 seconds plug into usb.
hope this helps ;)
Posted on Mar 12, 2009
    Novelist:
    Champion:
  • 233 Answers
Left click MY COMPUTER: left click MANAGE. It might show up there. If not try ADD HARDWARE WIZARD in CONTROL PANEL. Also check in DEVICE MANAGER.
Posted on Dec 31, 2008
How to open case for BYTECC Slim Mobile Drive 2.5" SATA 6G USB 3.0 External Hard Drive
you obviously want to scrap it for magnet or aluminum, so bashit with hammer and split with chisel, etc.
Jan 15, 2013 | BYTECC 2.5" USB 2.0 Slim Hard Drive...
IDE hard drive in Bytecc ME-535U2 enclosure not recognized by OS
smc4
There is a couple of things that could be going on. The first thing to check is that the drive did not get bumped off its drive letter by another device. If that is the case you just the to assign it a new one. The link below will help you do this.
http://www.fixya.com/support/r4183994-change_drive_letter_in_windows_xp
The other issue is the drive may have gotten disconnected improperly. I had the same problem with one of my drive on my XP system as well. It partly has something to do with the USB controller to my understanding. Alot of times if you plug it into another computer it will detect it and ask to run a scan to repair the drive. After this you should be able to access the drive on your XP system again. Note I have the best resolutes when I plugged the drive into my Vista system. So I would recommend trying to plug it into a Windows Vista or 7 computer to attempt the repair.
Let me know if you have any more problems or questions.
Issken
Feb 23, 2010 | BYTECC ME-535U2-BK Aluminum 5.25'/3.5'...
Bytecc BT-300 USB 2.0 drive mate problem : I am a PC user with WinXP O/S. My BT-300 worked fine when used along with 2.5 in laptop hard disk (power cable connected to drive mate). On the other hand, I am...
First is the "Drive" formatted? It will not work, if it is a new drive, until it is formatted. And/Or "Initialized"? If it has data on it already then it may be faulty? the only way to check that is to try it on another machine... also are you 100% sure you have it connected right way around, I have made exactly that mistake, before, I learnt whats what. Also try another USB port, this sometimes works. Try the setup on another PC to check it is actually OK.
Feb 22, 2010 | BYTECC USB2.0 to IDE Adapter Kit...
I am using SuperDuper to clone my 160GB MacBook Hard Drive to a 500GB Western Digital Scorpio Blue. My problem is that I cannot determine why neither the SuperDuper program nor the MacBook itself...
The Western Digital Scorpio Blue 500GB hard drive is formatted for PC, not Mac. The simplest way to get your MacBook to recognize this new drive--and therefore copy the files from your old drive--is to plug it in to a PC and format the drive. I was advised to format with FAT 16, as this would be recognized by my MacBook. Fortunately, the process was not that involved, since the Vista-driven PC found the drivers for the WD Scorpio Blue automatically. Once formatted, I safely removed the drive and plugged it into my MacBook via a USB port using a BYTECC Drive Mate. Magically, it now appeared on my MacBook Desktop and was recognized by the cloning software I was using, SuperDuper. Three hours later, the files on my old hard drive were successfully cloned onto the Scorpio Blue--except now I had an additional 364GB of storage space. Swapping out the old drive and replacing it with the new was not a big deal at all--just make sure you have the right screwdriver for the last task--a Torx #6. Mission accomplished.
Oct 24, 2009 | Western Digital Elements powered by WD 320...
No manual for 320 GB desk top hard drive
its a plug and play just connect to the sys and start working on it
but be careful that u connect the power to the Ext.HDD first and then after that connect it to the USB port
similarly safe remove from the Sys and remove it only after u see the msg It is safe to remove the USB drive disconnect the USB cable from the Sys wait for 20-30 secs ten power off the HDD for better performence of the Ext HDD
Jul 27, 2009 | Electronics - Others
Does not get recognised by Desk top or Laptop Asks for Installation and drivers
these drive require a usb 2.0 port.
If you are using XP and do not have a 2.0 port in your computer
you may want to get a USB 2.0 pci card this will help.
if you are using vista, it should install the driver automatically.
also do not use it on a hub plug it into a usb port on the motherboard or a powered card.
Apr 14, 2009 | Western Digital Passport WDXML800UE...
Dell Dimension 5000 - Installing extra Hitachi 500GB SATA Hard Drive
you need to turn it on in the Bios so the computer sees the drive, then format it.
Jan 20, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Software for 500GB
I don't think BYTECC sells complete external hard drives. But they do sell the enclosures. People buy the enclosures and install a hard drive in them and, now you have a working external hard drive. I have don't this before, but I have never used BYTECC before. You can download the drivers for there enclosures at there website:
http://www.byteccusa.com/
They have several different versions, Just pick the correct one, hopefully the enclosure has some markings or a sticker identifying the model.
Nov 17, 2007 | BYTECC 1 Bay ME-350U2 USB 2.0 External...
Problem with external enclosure ( No power)
Perhaps the gentleman at the store did not connect the power from the case to the drive itself.
Feb 11, 2007 | BYTECC 3.5" Aluminum USB 2.0 and Firewire...
Computers & Internet Logo
2,548 people viewed this question
David Payne
David Payne
