Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
Freezer vaccum seal not working
My freezer temp alarm goes off periodically. Meats are still hard frozen but popsicles are mushy. When I used to close the door it seemed to vacuum seal shut. Now that doesn't happen. Any solutions? Thanks.
  • 700 Answers
Check the gasket and make sure that it it not pinched and letting in air whe the door closes. primaryly around where the hinges are.;
Posted on Dec 27, 2008
Freezer vaccum seal not working not freezing like it should
Posted on Jan 02, 2009
  • 67 Answers
Posted on Jan 07, 2009
My kenmore is not pressure sealing
the problem is that the compressor is not working
call a technician for a proper diagnosis
and it is not a pressure sound but a vacuum sound as the door when closed drops the temp inside the unit and that creates a vacuum making the door temporarily hard to open
May 15, 2017 | Kenmore Elite Side By Side Refrigerator -...
The high temp light is on. What can I do to reset it? Everything seems frozen and fine in the frezzer
HIGH-TEMP ALARM SWITCH (SOME MODELS)
An audible
alarm will sound if the freezer temperature reaches
unsafe levels. The alarm operates on household electricity.If
the power
fails, the alarm will not perform.
An ON/OFF switch
allows the high temperature alarm to be
deactivated if desired. NOTE: You must open the
freezer door to
view the alarm switch. The
freezer is shipped with the switch in
the OFF position.
After the freezer has run longenough to
lower the temperature, you
may set the switch to the ON
position.
To activate the alarm, set the switch
to the ON position.
To deactivate the alarm, set the switch to the OFF position
i got this from the freezer manual from Kenmore hope this was helpful
Mar 28, 2010 | Kenmore Freezer 13.7 cu. ft. Upright...
Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Feb 05, 2010 | Freezers
Freezer is 4 months old, when we closed the door it used make a vaccum sound like it was sealing now it no longer makes that vaccum sound.
it doesn't mean the fridge door gasket isn't sealing properly, if just means it has worked itself into a permanent seal. if you aren't having any problems with the fridge, don't worry about it.
Nov 13, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Sears Upright freezer-the door does not have the suction anymore
You may need the hinge adjusted or a new door gasket but you might first try putting a layer of vaseline on the gasket. If none of those things help the problem is probably other than the door seal.
Dec 05, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Temp alarm on freezer alarming.
that's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
Dec 03, 2008 | Kenmore Freezer 14.1 cu. ft. Upright...
Kenmore Freezer Temp. Alarm
You should get a thermometer to be sure the temp is what it should be. With out it is very hard to tell correct temp.
Aug 05, 2017 | Freezers
Its keeps peeping
Hello twins49
Welcome to Fixya,
You said, your Frigidaire freezer 17 cu. ft. , it keeps buzzing or peeping
The alarm may be malfunctioning or it may be warning you of low temperature.
You can go to any hard ware store and buy a refrigerator thermometer and ask them if it can go into a freezer too!It can, But ask anyway!
If it is cold enough then it is a faulty alarm going off.
Your freezer may be equipped with an alarm.
Here is some information that may help you find it and turn it off if you wish
Temp Alarm (audible only or audible with warning light)
This feature is designed to provide a warning of possible malfunction. If the
temperature of the food rises to a level unsafe for long-term storage, the buzzer will
sound. The red light will also glow on models so equipped. The Temp Alarm feature
operates on household electricity. If power fails, the alarm will not perform. An ON/
OFF switch allows you to deactivate the Temp Alarm when not wanted. The freezer
is shipped with Temp Alarm in the OFF position. After freezer has run approximately
4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm
without the alarm sounding.
Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch.
If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and
seals properly. If you suspect a technical malfunction, call an authorized servicer
immediately.
Let me no what you find.
Huuum
Please remember to leave a rating before you leave
Aug 26, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
761 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
