You can go to the Envision customer support website and look for the driver under the driver support section for you model monitor. The website is. www.envisiondisplay.com. You can also call the Envision customer support at this telephone number. !-888-838-6388. They should be able to help you with getting the correct driver to support your set-up. I hope this information helps you with your problem.
After just a short while the display on my Samsung SyncMaster 943NW Monitor turns semi-transparant...
(More)
After just a short while the display on my Samsung SyncMaster 943NW Monitor turns semi-transparant blue, then tyrns to normal display, only to turn back to semi-transparant blue again. It then stays this way. Any help would be much appreciated.
What is the difference between a NEC 1880 SX and a NEC 1810 SX Monitor? ALSO What is the difference...
(More)
What is the difference between a NEC 1880 SX and a NEC 1810 SX Monitor? ALSO What is the difference between a NEC SX and a NEC FX monitor?
