Question about Microsoft Xbox 360 Console
My memory card won't load!!!
I brought it to a friends house whom has the wireless modem in his X-Box 360. My memory card wouldn't load there and now that I'm back home at my machine all the information is still there and now it won't even load on machine either!!! I tried to turn off/on the machine, nothing. I tried to save new info hoping that when I go to load it again it may pop up, nothing! ANYONE...HELP!!!
  • Ryuck666 Mar 15, 2009
    My controllers turn on my xbox but they just blink ive already tried syncing it!!!!!!!!!!!!! It also wont load my memoy cards
xbox fan
  • 28 Answers
SOURCE: Xbox 360 to Linksys wireless modem...
OK I think the easiest way to connect the xbox to the linksys, is if you configure your XBOX to have a static IP address, because the xbox will not have to pick an IP address every time you connect to the internet using the Linksys router and will not have conflicts with other PCs on your house, if you have any. What the linksys does is to convert your Public IP addres into a Private IP address, so example if your ISP gave you an IP address of: 209.235.205.30 that is your IP address for you, then the Linksys converts that number (NAT) into a private IP address so it can be share with many computer inside your house using a single Public IP address. The Linksys always transform it into 192.168.1.?=any number between 1-256 thats the defaults IP address from the manufacturer but you can change it if you want. Ok enough info about NAT or IP jeje.
Where going to use the default IP addres for an easier setup.
First: On your XBOX 360 dashboard go to SYSTEM, then Network Settings, then Edit Settings, then choose the option manual, here put the IP address= 192.168.1.33 (if 33 doesn't work use another numer like 20 or 45 just pick a number between 2 and 250) ; Subnet Mask = 255.255.255.0 ; Gateway = 192.168.1.1; DNS options put Automatic. And see if it connects. If it doesn't work just post it here, any problem that you have.
Posted on Aug 27, 2008
  • 14 Answers
SOURCE: saved games on xbox 360 hard drive
its not the account just the hard drive. make a new xbox live account.
Posted on Jan 03, 2009
SOURCE: Xbox 360 wireless controllers wont connect!
well you might want to press the little button by the battery pack at the top and the little one on the 360
Posted on Mar 02, 2009
  • 24 Answers
SOURCE: x box 360 wont connect to orange livebox!!!
there could be a problem with the xbox wireless adpter which it maybe a fautly item
Posted on Mar 05, 2009
  • 21 Answers
SOURCE: Xbox 360 reads games, doesn't read games?!?!
Microsoft Xbox have some common problem like red lights, E74 and Disc Read Error. Microsoft is providing extended warranty for red lights problem, Means you will have to spend some money in order to get this problem repaired from Microsoft also you will have to wait for 3-4 weeks to get your Xbox back. There are many reasons disc read error can occur in your Xbox like your disc might not be clean, laser might also be dirty and many more common problem. I would suggest you to first clean out the disc, you are using. If that don't solve the problem you can also take the help of DIY guide available at Internet. I think you have got good no. of options to get your Xbox repaired, Choice is yours....................
Posted on Apr 07, 2009
When i connect my battery pack outlet for my xbox it goes to red light and my xbox 360 won't turn on
Hello
1 unlpug power to x box,remove hard drive.
Plug x box back in and reinstall hard drive. Try x box.
2 remove memory cards.Try x box.if it works the memory card was bad.
3 Remove any accesories. Try x box.plug one acc back in at a time.
Sep 19, 2011 | Microsoft Xbox 360 Console
I bought a new DSL-2642B Wireless Router and Modem but it won't let me connect to Xbox Live, the solution that the Microsoft Solution thingy game me was to change the MTU settings, any idea of how to...
In order to connect to Xbox Live with a Wireless Modem and Router, you will need a Xbox 360 Wireless Adapter. You can get a Xbox Wireless Adapter cheap on eBay, or you can buy it Microsoft at Gamestop. http://www.gamestop.com/browse?nav=16k-Xbox+360+Wireless+Adapter
To find your MTU Settings, follow these steps.
1. Click on 'Start'
2. Click on 'Run...'
3. In the bar, type CMD, and hit enter.
4. A black box should appear. Type "ipconfig" without quotation marks in the field.
5. Your IP Address, Subnet Mask, and Default Gateway codes should pop up.
6 Go to your internet browser and type you IP Address into the URL box.
7. You should find MTU settings, and you can set them to your desire.
May 28, 2011 | Microsoft Xbox 360 Console
Keeps losing connection? charter says no problem with them, motorola is no help.....
Check / replace the power supply. Also check your cable. If you have access to where the cable comes into your house, try connecting a brand new cable at the box and connecting to the modem. If that solves it, then you need to have the house cabling checked / replaced. If not, then there is most likely a fault with the modem. Do you have any friends with cable Internet you could check out the modem at their house? Maybe swap cable modems with them for a short time to see if the fault travels with the modem. If both work at your friends house and neither work at your house it is is a problem with charter and they need to come out and verify the signal strength if they have not done so. If the problem is intermittent, is it a particular time of day? Cable services theft is a big problem and somebody may be tapping in to the line causing signal loss.
If none of the above helps, post much more information and what you have done to solve the problem.
Best of luck, Jim
Mar 05, 2011 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Xbox 360 - Thomson Router TG585 v8 Strict Nat limits who you can connect to. As you can imagine this creates a problem when trying to connect to friends. Kindly, devliver a simple step by step on how to...
OK, i too have had this problem and i have solved it via this website. This thompson modem is also referred to as... o2 wireless box II/III the website link is
http://www.unofficialguidetolive.co.uk/faqs/62-my-nat-is-strict-or-moderate
Search for the specific (o2 wireless box II/III) modem and follow tthe simple instructions onscreen.
Jan 01, 2011 | Video Game Consoles & Games
Game won't load
if it says the saved game is corrupted that means all your data will be deleted and if so it is deleted so all your memory is deleted you have to start over
Jul 13, 2009 | Microsoft Xbox 360 Console
My WireLess XBox 360 Controller wont connect to my XBox 360
i had the same problem, and is a easy fix, turn on your console, dont need the controller on, and hold the sync button for approx 30 seconds, then turn the console off, take out the power lead from the console and then remove it from your mains, wait about 1-2 minuts then plug it up and switch on the console, first sync the xbox then the controller, and this should work, if it dosent try xbox support their number is on xbox.com
May 30, 2009 | Microsoft Xbox 360 Controller
X Box 360 controler for pc doesn't wanna work for my X Box 360
click the button on the front of the 360 console...
which is to the right of the memory slots... when the ring of light is spinning around click the button on the top of the controller... it will then connect to that system.
There after it will always look for that system. so if you want to connect to a new system you push the button on the front of the system and then the button on top of the controller.....
Mar 18, 2009 | Microsoft Xbox 360 Controller
Xbox 360 ics apipa
you need to set static ip's for the xbox 360 and the lan that is on the pc, easy to bride the two connections on your computer, then set static on the lan that the 360 is plugged in to, example:
360's static settings:
ip: 192.168.1.14 sub: 255.255.255.0 gateway 192.168.1.1 ------------------------------- computers settings:
ip 192.168.1.15 sub 255.255.255.0 gateway 192.168.1.1
Feb 05, 2009 | Microsoft Xbox 360 Console
X Box 360 can't connect in hotel room!
I figured it out! I am also in a hotel room with only ethernet...and can connect to the network but not to the internet. When I got onto the internet for the first time on my laptop, there was a hotel internet webpage that came up immediately. You have to click CONNECT for 24hrs; 48; 1 week etc. unfortunately for us, Xbox doesn't have a internet browser like the PS3 does. So we can not click CONNECT when we are attempting to connect on the 360. The only reason why I know this is correct is because my friend brought his PS3 to my hotel room and that hotel connect window popped up and immediately we were playing Modern Warfare 2 with "full bars"...Xbox should really add a download for a browser! Like 360 way more. Sorry guys!
Jan 28, 2009 | Microsoft Xbox 360 Console
Ethernet
The internet cable fed to your modem by your ISP if faulty.
Jun 29, 2008 | Computers & Internet
Microsoft Xbox 360 Console Logo
176 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
