Question about Gigabyte GA-8IE533 Motherboard
Computer won't boot up
My PC has been working just fine until yesterday.  I used it in the morning but when I when to use in the afternoon, the monitor was dead.  I have rebooted and I get one long tone that seems longer than usual, then the power light blinks on and off. I hear the disk drives ramp up and I get an initial seek or two but then it sits with a flashing power light.
I have tried a different power supply and and a spare Ram stick but the results are the same.
I checked the documentation on the Gigabyte site but can find nothing about the beeps or power light.  Any ideas?  I'm thinking the MB is toast.
  • andydfw Dec 27, 2008
    The MB does not have onboard video but an add-on AGP card.  I removed it to see if anything changed but it operated the same.  I am thinking it is a MB/mP  issue.
    You win.  I d id try another AGP and it works!!  Thanks.
    President:
  • 1,314 Answers
A long beep code often indicates the video card is kaput. If this has onboard video (i.e., the monitor plugs directly into the motherboard) then purchasing an inexpensive video card that will fit into your computer will take care of the problem. If you already have a video card, just swapping it with another one will fix your problem. Oh, and another thing, please rate this solution with a fixya rating, I'd appreciate it. Thanks!
Posted on Dec 27, 2008
  • Kevin Shafer
    Kevin Shafer Dec 27, 2008
    If the video card is not working, and you remove it, yes it will still give you the same error because the error indicates that it is a video problem. There are two types of beep codes....one for memory (usually two short and one long beep and you've already tried replacing the memory) and one for video (usually one long tone). Since you indicated that you hear one long beep, this indicates to me that the video card is the culprit. Removing the video card, it does the same thing because the computer is telling you that there is no video card or one cannot be seen.
    Scholar:
  • 172 Answers
If you have the following all working/can be heard working:
hdd,dvd/cd drives,cpu cooling fan, but without display and you have tried a good power supply,then the processor socket is blown. This will stop it booting and the screen light will remain at yellow standby. The board needs replacement, not too many about these day in the socket 478 intel pentium 4 format. I can supply these, but you may be better off installing a motherboard upgrade kit comprising a motherboard, cpu,fan,memory either in Intel P4 socket 775 format or AMD,AM2 format.Both options will secure your data on the hard drive, and bring the pc up to date with the latest hardware at a fraction of the cost of a new pc.Hope this helps.
compdoctor2005@btinternet.com
Murray m2500 won't start after one day of having it
bad coil in it, i had bought a m2500 murray weedeater from walmart .did same thing i replaced the coil. bad when you buy something from wal mart and have to get it fixxed before you can use it. now it works fine
Apr 23, 2013 | Cars & Trucks
G62 won't boot up
Take out the battery and wait a minute, then put it back and try again.
Mar 03, 2017 | HEWLETT-PACKARD HP Laptop / AMD Turion II...
My new Bosch B26FT70SNS fridege which i got delivery yesterday morning compressor motor won't turn off. Since yesterday afternoon around 5pm until now 11am. More than 18 hours continue running, the...
HI JAMES.ummmm new bosh...should work.if not and motor running cont.then it sound to me like is out of refrigerant or motor faulty.check condenser unit.should hot.if cold call under warranty or replacement i would say.good luck Ali
Jun 30, 2012 | Refrigerators
Storm knocked power off late yesterday afternoon....back on this morning. PC won't power up....small green light on back flashing. Modem, router, etc. all back up and running, but PC won't turn...
The first thing to try is to cycle the power. To do this, unplug the power cord from the back of the PC and press and hold down the power button on the PC for 5 seconds. This will completely drain any "stuck" power in the components. Now plug the power back into the PC and try booting. If it still does not come back on after this, then you may be dealing with a blown power supply. You can buy replacement power supplies from your local PC shop for about $50 for a 400watt.
To protect your devices in the future, make sure you have a good surge protector and / or a UPS (uninterrupted power supply).
Regards, Chris
May 25, 2011 | HP Pavilion a350n PC Desktop
Can not start my computer
Plug the unit directly to the ac outlet if it is plug into a surge protector. See if it boots. Did you shut it down yesterday or was it left running? Any bad weather last night? You could try another computer memory and see it is the memory. Not sure what it could be at this point. What type of system is it?
It could possibly be a bad power supply.
I hope this helps.
Feb 17, 2009 | Acer Aspire™ T180 PC Desktop
Set to box problem
Where did you grab the firmware for it? I can't find it anywhere!
Aug 30, 2008 | Teac Audio Players & Recorders
A/c compressor
It probably failed because it reached high temperatures or pressures. make sure the regular maintenance has been performed then wait 1 day and try again. It has internal overload protection and that can take hours to reset. If this doesn't work then you probably need a licensed technician to take a look at it.
Jun 07, 2008 | Dometic Rooftop RV Air Conditioner
Gigabyte GA-8IE533 Motherboard Logo
173 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
