Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Profile Oven Door Lock Broken...
Hi!
A while ago, you helped me out with my oven broiler, a GE Profile (JGBP86WEA2WW). Your advice allowed me to fix the problem myself and saved me the time and frustration (not to mention expense) of calling a professional. Now, if it's not asking too much, I need your help again.
I have a problem with my door lock, or maybe just the sensor. Here's what happens: The display for the oven blinks "Locked Door". However, the door isn't locked and I can open/close it.
Anything you can do to help would be greatly appreciated.
THANKS!!!
-Mark W.
p.s. Note the product number below isn't exactly the same. The one in the e-mail is correct.
  • whelgemo Dec 27, 2008
    Great answer!
    There are two plastic pieces holding the top in place and I can't figure out how to release them. I have a tendancy to go the wrong way with these things and the "Body Parts" exploded view doesn't help. I'm not convinced the parts that I'm about to break are even listed, unless they are "Pin Locators" as listed on the "Control Panel & Cooktop" exploded view.
    Any suggestions on how to get past those pesky little plastic clips?
    Thank you,
    Bill
  • jwmiddlebroo Feb 12, 2009
    my door locked light is blinking and i can't use oven. I tried to reset the self clean and the lock is not moving. just a grinding sound. the lock acts like it wants to grab and then does nothing. Plus, the only way to get this to do is by me holding the oven door in tight and it cuts off when i release pressure. thanx
  • 5,911 Answers
It sounds like your door latch motor, and/or interconnecting wiring may be bad. You will need to carefully lift the top panel and/or rear panel and locate the latch motor and linkage. If you go to searspartsdirect.com and look under the "Body Parts" heading, there is an excellent exploded view diagram. The latch is listed as item #279. Your exact model number was not listed, but if you use JGBP86WEA1WW or JGBP86WEA3WW, these will suffice. With the top of the range lifted, inspect the latch for any broken wires and attempt to operate the control panel to see if the latch works. If not, replace it. The part number is WB2K10010. This same part can be found at appliancepartspros.com for about half the price. Let me kow if you require addtional assistance. I hope this helps you.
Posted on Dec 27, 2008
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    I need help with my broken Ge profile oven broiler works but not the oven
    The problem with your oven is the ignitor that lights the burner. You need to replace it and your oven will work again.
    Check out this tip that I wrote about your problem...
    http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
    Heatman101
    Mar 01, 2010 | GE Profile JGS968SHSS Gas Kitchen Range
    GE PROFILE JBP79 OVEN RANGE - OVEN DOESN'T BAKE. CLOCK, BROILER, CLEANING WORK, LIGHTS WORK WHEN CLEANING OVEN. COIL ON BOTTOM DOESN'T GET HOT BUT BROILER COIL DOES.. WHEN CLEANING OVEN LIGHT WORKS WHEN...
    Could be the sensor inside the oven.Mine burnt out when using the self clean feature. Two screws un-plug replace with new. Part less than 15 dollars
    Jan 08, 2010 | GE Kitchen Ranges
    GE Profile JGBP86WEA2WW Won't get hot...
    Sure. If you go to my profile and look under "Tips and Tricks" section. I have a complete write up on how to replace an igniter in an electric oven. If you can't find it, let me know and I will forward the instructions to you.
    PS Yes, this is a simple job that anyone can do. The igniter will cost you about $30 - $60 depending on where you get it. It will save you big $$ in the long run, if you avoid the labor charges :).
    Apr 06, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
    GE Profile XL44 Spectra gas oven
    try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
    Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
    GE Profile Spectra XL 44 gas oven
    If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
    Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
    Ge oven problem
    Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
    Jun 07, 2007 | GE Profile JTP56 Electric Double Oven
    F3 code
    It's your oven temperature sensor. It's a thin metal stick that juts into the oven. It is located on the upper right back wall of the oven cavity. Flip your breaker, slide out the oven. You install it from the back, very simple, two screws, i think. I'm a beginner at DIY and had no problem fixing it.
    Feb 23, 2007 | GE Profile JK915 Electric Single Oven
    My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
    Nov 13, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE Profile Spectra JGBP90 Gas Kitchen Range Logo
    1,291 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
