Question about Trendware TRENDnet TEW-421PC 54Mbps PCMCIA Wireless Network Card 802.11g (NETWTEW421PC)
Browser not connecting
The problem I am having is that my laptop is telling me I am connected to my router (Trendnet tew-432brp) but when I open my browser it will not connect and says I am not connected. I have called costomer support and tier 1 was no help everything we tried did not work and I have still not recieved a call back over 5 days later from a tier 2 tech. I have tried with help from customer support on changing ip address, and other numbers that I do not know what they are and still nothing. Its wiered cause it will automatically connect to network and start downloading updates for my anti-virus software. Any help would be greatly appreciated.
  • phillip long Apr 22, 2007
    I still cannot connect through my browser
    nevermind i figured it out, i had to go back through and set up a new network connection
    President:
  • 2,961 Answers
Ok, this is more than likely your isp is at fault, i had the same thing and my emails and updates worked but was unable to browse. But first make sure that your pc does not have any corrupt cookies, go to the sie below and download ccleaner, it's free and has no spyware, when you install it go to the left side of the menu, click on cleaner, then click analyse at the bottom. when it has done a sweep click delete files. Try connecting again. Next go to your routers settings and look for what is called DHCP and make sure this is enabled to give your pc an automatic ip address. Then go to your wireless card in control panel>network connections and right click on the wireless cards icon an go to properties. Highlight on the TCP/IP line and click properties, then check that 'Obtain ip address automatically' is ticked. Click ok then try again to get on the net.
Posted on Apr 22, 2007
I cannot find my pin number on my trendnet tew-432brp router
! In your browser write in 192.168.1.1. If theres an option for Configuration Pages, click on that. If it asks you for a username and password they're most likely to be
USERNAME: Admin
PASSWORD: Admin
Look for a system information setting. In that information there should be something about a WEP or a WPA key. It should tell you the key there.
Jan 07, 2011 | Trendware TRENDnet TEW-432BRP Cable/DSL...
How properly to connect TRENDnet TEW-432BRP to laptop
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Nov 26, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
No SOftware Driver for TEW-432BRP
What brand is your router? Check for the IP address of the router and default password (should be written on the back of the device). Then type the IP address into the web browser on your main desctop in the kitchen like that for example http://192.168.0.1 enter the default username and pasword and you are in the router's menu.
Set up wireless connection SSID is the name of your network that will apear when you search it, do not change any of the default settings exept the SSID , enable, and select password. Use the WPA2 and type in your desired password and press SAVE . Then go to your bedroom and try to find the wireless network you've just created. And connect. Good Luck
Jul 23, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
Reset password
What password are you referring to; Wireless Security or Web password to access the Router's interface?
If it's the 2nd; Open http://192.168.0.1 (default IP) on your web browser, type username: admin and Password: password. Click on Password then change the default password.
If it's the 1st; Open http://192.168.0.1 (default IP) on your web browser, type username: admin and Password: password (put you correct password if you change the default password).. Click Wireless on the left, Enable Encryption WEP or WPA; for WEP 64 bit you will have to use 10 HEX, meaning 0-9, A-F (e.g. common is phone number). If WPA; password can be set from 8-64 characters long.
Angel .
Jun 30, 2010 | Trendware TRENDnet TEW-435BRM 802.11g...
My wireless is not pass word protected, how do i do this
Open a web browser
http://192.168.0.1
or
http://192.168.1.1
Login to your router
Goto wireless settings
And there should be some options there to add password to your connection
May 21, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
How to connect tew-432 brp to MT800 modem for a wireless connection
you can connect your Ethernet cable from tew-432brp to MT800.
if serial ethernet cable not work you can check with cross cable of ehetrnet also.
Mar 30, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
I have trendnet wireless router model TEW-432BRP.i switched on the power,but the router didn't switch ON long time.when i switch ON the computer and logout the computer several time,then long time only its...
It is because the Power adapter is not connected properly. If this happens again. Disconnect the power adapter cable from the router and from the power socket. Then connect it back again. The router will come on. It could also be because of power surge which might have stopped the system for a while
Feb 03, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
Cann't get my wireless router to work,don't understand how to config the router.
HI helock,
This is a step by step instructions:
Note: It is recommended that you configure the Wireless Router from a wired
computer.
1. Open your web browser, type http://192.168.10.1 in the Address bar, and then press Enter.
2. Enter the User Name and Password, and then click Log In. By default: User Name: admin Password: admin
3. The Wizard will automatically appear. Click Wizard if the Wizard does not automatically appear.
4. Click Next.
5. Select your Time Zone and then click Next.
6. Click Next. Note: Do not change default settings unless it is conflicting with your existing hardware.
7. The TEW-432BRP will attempt to auto detect your Internet connection. Follow the wizard instructions and continue on to step 9.
8. This screen will appear if the TEW-432BRP is unable to auto detect your Internet connection. Configure the settings based on information provided by your ISP.
9. Follow the wizard instructions to complete the configuration. Note: Each Internet Connection type may have different options.
10. Click Next
Note: It is recommended that you enable encryption on the wireless router. Please refer to the User Guide on the User's Guide CD-ROM for information on
setting up encryption on the wireless router. 11. Click Restart. 9. Follow the wizard instructions to complete the configuration. Note: Each Internet Connection
11. Click Restart
12. Click Close.
13. Wait 30 seconds while the router reboots.
14. Verify that the following panel lights are on: LAN, WAN and WLAN.
15. Open up your browser and enter in a URL (e.g. www.trendnet.com) to verify that you have Internet connection.
Your configuration is now complete.
Good Luck,
And don't forget to leave a rating
Thanks
Mark
Sep 14, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Trendnet router
i found out that since i have an older version of winxp 2000, i need to get a network adapter, to get this router going.
Mar 25, 2008 | Trendware TEW-432BRP Wireless Router...
Trendware TRENDnet TEW-421PC 54Mbps PCMCIA Wireless Network Card 802.11g (NETWTEW421PC) Logo
222 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
alex metro
alex metro
 Mike M
Mike M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
