Question about Saitek Aviator AV8R Joystick
Use of AV8R-01 with Google Maps flight simulator
I am able to use my keyboard to operate the flight simulator in Google Maps, which enables you to "fly" and "land" anywhere in the world using Google Earth imagery. However, I cannot figure out how to use my Saitek AV8R-01 joystick with Google Earth's flight simulator. Every time I click on "Enable joystick" in Google Earth, it blows me out of the program. Is there a setting I need to change on my computer, to solve this problem?
  • 7 more comments
  • Colin3 Jan 09, 2009
    I have the same problem but with a slight difference. The AV8R-01 joystick DID work with the Google Simulator when I plugged in the joystick right out of the box, prior to loading the Saitek Aviator software. When I loaded the software to map the keyboard strokes into the joystick, it was then that I ran into to the same problem: Google Earth Simulator now crashes when run the simulator. Any ideas out there, guys?
  • ezeka Feb 04, 2009
    I have exactly the same problem as described before, even with the most recent version of Google 5.0
  • Anonymous Feb 08, 2009
    Saitek rumble pad, but same problem
  • Anonymous Feb 24, 2009
    same problem must be a software conflict
  • Anonymous Feb 25, 2009
    as soon as I start the flight simulator the program shuts down
  • Anonymous Mar 02, 2009
    same problem
  • Anonymous Mar 12, 2009
    I don't know. I'll try searching new forms
  • Anonymous Mar 30, 2009
    I have the same problem, but at one point initially the joystick did work. I hadn't messed around with it for a few months and when I tried again I had no luck. Did you find a solution?
    Robert
  • Charlie Buehl Mar 24, 2012
    I have an av86-01 saitek joystick and i tried running it on Google Earth's Flight Simulator. It works, as far as responding to input. But, when in the neutral position it enters into a vicious right wingover. You have to continuously roll left. it is nearly impossible to hold straight and level flight. Managed to land, but it wasn't pretty. It will land on almost any hard surface. Actual airports are recommended. I have found no way to calibrate a saitek on a mac OS/x v10.6.8 Intel Duo. Oldie but a goodie. Good luck to all, I will post a fix when I find it. I recommend Google Earth over Google Maps (did not know you could 'fly' gmaps save for the new 3d feature.
My blackwidow joystick would not work in google earth, the sim would just crash. I tried a surgestion to remove the blackwidow software and just run it with the ms hid driver. It now works fine, even the throtle and rudder controls.
Posted on Mar 30, 2009
I have changed my operating system from XP home to Windows Home Premium. my Saitek AV8R-01 seems to be designed for XP. Can I intall a driver that will work with Windows 7
The driver for Windows 7 can be downloaded from here:
http://saitek.com/uk/down/drivers.php
From the second drop-down menu to the right select Joysticks then select AV8R and then select your operating system.
You'll have 2 buttons with the driver and software. Click on each and save the driver to your computer then install them(driver first).
Hope it helps. AV8R AAV8R
Apr 26, 2011 | Saitek Aviator AV8R Joystick
MCFS Joystick Problem
Make sure, that your Joystick is compatible with the version you are having problems with. If not, make sure that it's enabled in the configuration of MCFS. If none of those work, you will most likely have to purchase a more compatible Joystick.
Matt P,
Computer/Gaming Relations Team.
Sep 16, 2009 | Microsoft SideWinder Precision Pro 2.0...
Joystick will not work with Combat Flight Simulator WWII Europe
Some joysticks are not compatible with certan games for expmple when i am using flight simulator and change to my combat flight simulator i have to change joysticks
the only other thing i would think is try deleting the currently installed driver for the joystick and then download a driver for a joystick that is surported, it wont work as well but at least it might accully work
Mar 22, 2009 | Logitech Attack 3 Joystick
Saitek AV8R-01 Joystick - How to install?
No download disk is required. Your PC will automatically 'find' the joystick after it has been plugged into a USB port.
You can just about play any flight sim with this joystick, jat, prop plane or helicopter. The buttons do what ever you program them to do through your game's control settings.
Mar 19, 2009 | Saitek Aviator AV8R Joystick
Joystick turned off, won`t operate
Ok... that is a VERY Easy fix... all you do is get into a plane with the kneeboard and click controls and find it!
Feb 09, 2009 | Saitek Aviator AV8R Joystick
The tutorials in MS Flight Simulator X unexpectedly stop
this is Easy... so when he talks he tells you what to do as you go along so do
EXCATLY AS HE SAYS then he will keep going. Also Your Computer May Be old.
Feb 05, 2009 | Microsoft Flight Simulator X for Windows
I can not run flight simulator becoz,d3drm.dll has not been found
U can go to google.com And Search for   '' d3drm.dll download it .....
Jan 16, 2009 | Microsoft Windows Vista Ultimate Edition
Combat flight simulator wont recognize my sidewinder precision 2 joystick on vista but it did on xp?
I am farmiliar with most flight simulators and know that you have to go to settings on the main menu the controls and select joystick, enable joystick and/or calibrate joystick. If this doesn't wok then in gameplay push "alt" on your keyboard if the task bar for flight simulator isn't at the top. Once or if it is allready there select settings and then enable joystick. If this doesn't work then call or contact or google microsoft flight simulator.
Jun 25, 2008 | Microsoft SideWinder Precision Pro 2.0...
Saitek aviator joystick av8r-01
Well.. if you have windows xp.. then you can calibrate your controller fairly easily.
Go here:
Control panel:Printers and Other Hardware:Game Controllers:(your controller should be in the list):Advanced:Calibrate
This should solve your problem ;)
Apr 11, 2008 | Saitek Aviator AV8R Joystick
Joy stick or?
I have a Saitek X-45 that I use. It comes with a throttle and joystick. It's controls are very smooth and can be adjusted for increased firmness. There are a lot of programmable buttons that work great for FS2002. The only draw back is the joystick does not have aileron control by twisting it, you have to program a rocker button on the throttle. Unless of course you go all the way and buy foot controls. It looks like the X-52 is the updated version of my controller but it isn't cheap. The X-45 works good for what I need it for.
Jan 17, 2008 | Video Game Consoles & Games
Saitek Aviator AV8R Joystick Logo
1,339 people viewed this question
Top Saitek Video Game Consoles & Games Experts
Hjalmer Lamminen
Hjalmer Lamminen
Marvin
Marvin
Rob Emerson
Rob Emerson
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
