Question about Maytag PAV3240A Top Load Washer
No water to machine
I have a top loading washer. When I turn tthe machine to any cycle, the on light comes on, but no water flows into the machine.
  • Maytag Master
  • 19,396 Answers
Start checking the water supply connected to the machine, if water is regularly coming to the machine, the problem is either a faulty inlet valve, a defective membrane water level switch, or a faulty timer control (the first two are more likely).
Call a local technician and have the appliance fixed.
You find replacement parts and diagrams here.
Posted on Dec 27, 2008
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
I have a kenmore series 80 washering machine. The washer begins the wash cycle mormal. About half-way through the wish cycle the washer begins to fill with water again. It will fill with water until to...
the water level control has gone bad,its located in the top of the washer control panel,four philips head screws gets you in there,make sure you unplug the machine,it has a rubber hose,and four clip on wires,one 1/4 inch screw holds it in place,its job is,it works off of air pressure from the rubber hose that comes from the washer drum,if it don"t read the back pressure from the drum being filled it will over flow.good luck
Nov 19, 2012 | Kenmore 24032\24036 Top Load Washer
Water won't shut off on my Estate washer
check clear tube that is inside machine.1st take off shell of machine look for clear tube about 1/4 inch sometimes comes off,it pushes over nipple to load size water fill knob.if it came off the water will keep on flowing and over flow.if that's the problem just put a dab of silicon on nipple and push tube back on.
Feb 20, 2012 | Estate TAWS800JQ Top Load Washer
Low water level kenmore elite front loader i have cleaned the hose strainer,water pressure 55 psi can i adjust
Whats tthe model number on the washer? I wana check if that model has a "water flow meter". Does the washer fill then give you an error code about the water pressure? Is this the HEt front load washer? If so, open the top panel. 2 screws are located on the back upper corners. one on each side. slide the panel back and lift up. Now you will see the inside from the top view. Now if it does have a "water forw meter" it should be inline with the water inlet caomming in. Its looks like a plastic like tube that is in the middel in the inlet water coming in..i would check that out.
Jul 30, 2009 | Washing Machines
No cold rinse, only hot
Either the wires have come loose on the water valve or you have a defective water valve.Open the lid and look at the water valve. Are all wires connected?
If yes, replace the water valve.
Jun 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing machine has low flow and stops in middle of cycle
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside where you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Feb 24, 2009 | Kenmore 24032\24036 Top Load Washer
Water keeps coming in
if the water is coming in when the machine is off then you have a faulty water valve and you need to start thereand solve that problem first
cheers grantsreps
Sep 20, 2008 | Fisher and Paykel GWL11 Top Load Washer
Water in my washing machine
it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
Note: unplugging the machine will not stop the water from running
May 13, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Maytag PAV3240A Top Load Washer Logo
47 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
