Question about Home
Replacing Moen Posi-Temp shower handle with a Danco and temp of water is now different - cold to left, hot to right and no flow when this knob is in center. Help?
    Scholar:
  • 68 Answers
Take the knob off and rotate 180 degrees and put back on. Just take the knob off, turn 180 and screw back on. New stems many times are in the half way position from the factory. You are not the first this has happened to. My answer assumes you just changed out the cartridge.
Please rate this response and Good Luck, Phil
Posted on Dec 28, 2008
MY Moen single handle shower knob turns in a complete circle. From left clockwise, it goes from hot, tepid, cold, tepid, then back to left-hot. What causes this and how can it be repaired?
It sound like you have a Moen Posi-temp faucet and the handle is broken. It is probably an acrylic hdle with a tear drop shaped cover. Take a knife and slide it under the cover to pry it off. Unscrew the center screw and the handle will pull right off. You will see two shoulders inside the hdle, one of which will be cracked and broken. Replace the hndle which can be purchased at any Lowes or Home Depot. Plumbing supplies also carry replacements, but you can probably get one cheaper at HD or Lowes.. Make sure to use the washer provided. It has two flats on the inside of washer. Slide this over the brass stem on your cartridge, NOT on the hdle screw. Install it with the flats of the cartridge in horiz. position. Try faucet. If the water comes out in the opposite temp you expect, warm is cold, and cold is warm, remove the hdle, spin the stem 180 degrees and reinstall hdle.Good luck!
Oct 22, 2013 | Moen & Posi-Temp Single Handle Shower Or...
I have a moen posi-temp shower valve and it says "up" on 1 side. when it is installed this way the hot is on the wrong side. the hot is hooked to the left side but the handle points to the cold...
you need to pull apart the handle and rotate the cartridge 180 and reassemble and that will put the hot on the left and the cold on the right before you put the screws all back in test it to make sure its correct then reassemble IF THIS HELPED YOU PLEASE VOTE FOR ME AND LEAVE GOOD FEEDBACK
Aug 27, 2011 | Moen & Posi-Temp Single Handle Shower Or...
I've been given an old (10+ yrs) Moen shower control valve that I want to use (it does apparently have pressure balancing built-in), but don't know which side is hot and which is cold. Does Moen always...
Moen and all shower valve manufacturers follow american federal guidelines. Hold the unit in your hand with the handle facing you - the left side is the hot water inlet and the right side is the cold water inlet.
Nov 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
When i turn it on it is only warm at best. when i turn it all the way hot the water comes out in a trickle. all our other showers and sinks get hot water just fine. this is a single handle shower and does...
You will need to remove the old cartridge from inside the shower valve body and either refurbish it with new rubber seals and O rings or replace the cartridge altogether (preferable). It's not a complicated fix but the Posi Temp cartridge can be a bear to remove. Moen and Danco make special 'pullers' to make the cartridge removal go a little easier (sold at Lowes/HD and plumbing supply for anywhere between $15 and $35 but well worth it, IMO).
Oct 27, 2010 | Moen & Posi-Temp Single Handle Shower Or...
We have a home that is 3 years old. We never used the 3rd bathroom shower until today. We have a Moen single knobe shower/bath valve. To get water from the faucet you pull the knob out. To adjust the...
Remove handle to gain acess to the temperature limit stop. Remove handle and pull out handle adapter kit and next there is a dail that can be adjusted to control the water to balance the temp. It could have been installed wrong, pay attention to where it is now and pull it back to it disengages out of the stem and move it counter clockwise a little and reinstall. Put handle on and test water for correct movement.
Go to link below for a part's diagram if needed.
TO ORDER PARTS CALL: 1-800-465-6130
www.moen.com
Aug 15, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Waters hot instead of cold when you turn it on
You have to remove cartridge and rotate 180 degrees then re-install. Was it removed or replace lately?
Jan 06, 2010 | Moen & Posi-Temp Single Handle Shower Or...
My shower has been leaking for months. someone
turn the water off to the shower,sometimes you must shut down the whole house at the main ,near the water meter,then take the handle off slide the clip in front up and out then pull posi-temp straight out.replace posi-temp in reverse order.be mindful of the H/C indicator on posi-temp this will ensure you have hot and cold on right sides,if reversed just flip posi-temp.
Jul 08, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen posi-temp for shower pressure
Is this only happening in your shower? Or through the hole house? Maybe you shower head has a flow restrictor in it. Try removing it!
Jan 31, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen single handle valve tub/shower
The Moen Posi-Temp Valve is a pressure balanced valve and when not used for long periods of time they can stick causing only cold or hot water to pass through the valve.
A New Posi-temp cartridges can be purchased at most plumbing supply houses or big box outlets such as Lowes or Home Depot.
As long as you had cold water before, a new cartridge will solve the problem. In the future it would be wise to occassionally operate the valve at least a couple of times a month in order to keep the pressure assembly from becoming lodged in position. Just follow the instructions included with the new cartridge on the proper removal of the old cartridge and the installation of the new cartridge. a little silicone grease inside of the valve before installing the new cartridge will also help.
Be sure that there is no particles of the old cartridge left in the valve.
sanray
Dec 27, 2008 | Moen & Posi-Temp Single Handle Shower Or...
Home Logo
575 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
