Back to:
Tags:
Canon PowerShot SD300 / IXUS 40 Digital Camera
Canon powershot SD 100 - I can't see anything but a... (by 4 users)
posted by ya thung on Apr 22, 2007
When I turn on my camera to take a picture the display screen is completely black. If I try and take a picture nothing comes out. The whole picture is completely black. The camera is still functioning as if it is taking the picture. The flash continues to work, but unfortunately no picture comes out.
But when I switch to the display mode to view my pictures, I can see the old pictures from my memory card. But I just can not take any new pictures. What should I do? What do you think the problem is?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by darlamay1, posted on Sep 30, 2008
I have the exact same problem with mine - It worked all summer ( took over 400 pictures ) and than on Spet 11th - it is now showing just a black screen - any solutions?
Comment by Guest, posted on Aug 20, 2008
exactly the same problem here too... any ideas?
Comment by P4nda, posted on Jun 10, 2008
exact same thing.... i can see all my other old pictures but then when i try to take a picture, the screens all black. But i just turned it on then it worked, for like 5 seconds then the screen went black again
Best Solution
posted on Nov 15, 2007
FixYa! (100)
t00nz
Rank:Guru Guru
Rating: 90%, 977 votes
I know this is an old post, but it really sounds like a defective CCD imager. You may be in luck. Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Comment by t00nz, posted on Dec 14, 2007
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on canon powershot SD 100 - I can't see anything but a black screen:
I don't want to Accept this solution
Solution #2
posted on Jul 04, 2007
FixYa! (100)
Jalchamp
Rank:Apprentice Apprentice
Rating: 94%, 8 votes
Check cannon's knowledge base for solution to "blank or distorted screen on certain digital camera models". The URL is http://www.usa.canon.com/consumer/contro...
Enter your product info and follow the screen instructions.
You can call them at 1-800-828-4040. "Support hours are Monday thru Friday - 8:00 AM to 12:00 midnight; and Saturday 10:00 AM to 8:00 PM (all times EST)" - Cannon website.
They are aware of the problem and will take care of it for you free of charge.
I have a similar problem and I am getting my camera repaired free of cost.
Thank You!
Solution #3
posted on Jun 16, 2007
Helpful (85)
advance
Rank:Guru Guru
Rating: 90%, 330 votes
This problem is caused by a stuck shutter assembly. Normally the shutter is open which allows light to enter the image sensor and show you the live preview you see on the screen. When you take a picture the shutter closes which allows the image sensor to record what was seen at the exact moment the shutter closed. The shutter is stuck closed, causing the image sensor to always be in the dark.
These shutter assemblies are extremely small and delicate. The miniature parts can become jammed with just the slightest bit of oil or contaminant, or the slightest misalignment of components.
The problem can sometimes be fixed by gentle tapping of the camera on a solid surface. If you are going to try this be VERY careful, and do not tap the camera on the buttons, lens, or battery door. If this does not solve your problem then the camera is going to have to be taken apart and the shutter cleaned and reset to allow free movement. This repair costs $125 to $145.
Thank You!
Solution #4
posted on Oct 01, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
u dont really need to return it just click on display then it returns to normal i know this because it happened to me before.
Thank You!
Solution #5
posted on Jun 21, 2008
Not Rated (0)
dlundmark
Rank:Wiz Wiz
Rating: 81%, 70 votes
ccd problems will be fixed with a limited amount of models.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=221&modelid=8776
Comment by dlundmark, posted on Jun 21, 2008
This is not really a recall. It is a repair by Canon. I have had more than 10 cameras fixed by Canon and a few fixed by Nikon.
The postage will be paid by Canon both ways. Nikon pays only the return, you have to pay to NY, or other repair unit.
The guarantee, is not really a warranty as such, but will be covered for a limited time.
Thank You!
Solution #6
posted on Jun 14, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
I lost Instructions How to work camera
Thank You!
Can you Help with these Digital Cameras problems?
Canon PowerShot SD300 / IXUS 40 Digital...
lense always open and I cannot take pictures, but I can...
we dropped the camera accidently. Now it won't turn on....
My canon powershot SD300 was working fine and now all of a...
I have this camera alomst four years already. Lately there...
hi i saw your solution to another person's problem earlier...
Loading problems.
Repair Service
Find Digital Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
