Question about Brother SE-270D Computerized Sewing Machine
Automatic threader mechanism keeps sticking and a part falls off
I just got my machine back after 6 weeks to get my threader fixed. The problem started when I tried to use the thread cassette the last time I was working on an embroidery project. A metal arm that operates the threader stuck and a little metal part that actually puts the thread through the needle just fell off. I tried to use it tonight for the first time and the same thing happened. The first time the repairman said something broke and ordered a part that took 2 weeks to come in. Now I'm not sure what to do. The same metal arm is stuck...it has a spring in it and the same little metal threader is off again. What is causing this and is there anyway we can put it back on ourselves? I don't understand what the problem is. I slowly pushed the cassette down until I got a green light and then pushed it all the way.
  • Anonymous Nov 05, 2007
    I too have had the same problem , the little auto threader thingy broke off, and it is still off! I am not sure how to fix it or find a new part!
  • malted Dec 19, 2007
    This machine worked GREAT for a year--and now I can't get the threader to work at all--it gets stuck and won't even send the thread down to where I can thread it. I'm going to send it to a local sewing machine repair to see if I can get it repaired. It worked super at first...I'm so disappointed that it doesn't work correctly now.
These machines are nothing but TROUBLE and always will be. Get rid of it. Save yourself much time and frustration.
Posted on Nov 28, 2007
I have a Babylock BMP9 6 needle embroidery machine. The automatic needle threader mechanism is not dropping down far enough to use to thread the needles. Any suggestions on how to fix this?
On older machines that do not have the automatic needle-up feature, the user needs to manually adjust the needle height so the threader will match the needle eye.
Oct 29, 2016 | Sewing Machines
Automatic needle threader stuck
You may have a thread stuck in your bobbin area. Remove your bobbin, brush gently with a clean soft brush to remove dust and/or thread bits, then gently wiggle your hand wheel back and forth, and brush again. This should free up your machine.
Jul 09, 2014 | Janome Sewist 500 Sewing Machine
The automatic threader does not work
Please refer to page 33 of the user's manual.
The needle has to be in the highest position for the needle threader to align with the eye of the needle.
Threaders will not work if the eye of the needle is too small for the wire on the threader.
Sometimes the wire gets bent if it was forced against a needle that was too small or if the needle was not in the correct position for the threader to work.
The wire can be bent back into place, but you have to be careful as it is very thin and can break.
If the wire is broken, the dealer can order a new threader - they are not very expensive and are easy to install.
Feb 19, 2010 | Brother XR-65t Mechanical Sewing Machine
How do you align the needle threader on Husqvarna Quilt Designer II?
You need a torx #6 screw driver to loosen the screws on the back of the threader, (I use magnifying goggles to see the threader) then put the threader in the down postion and look to see and make sure the hook of the threader goes through the eye of the needle. Holding the threader in the down positon with the hook sticking through the eye of the needle, tighten the screws on the backside of the threader, Double check it (slowly) to be sure it didn't move while you tightened the screws.
Nov 06, 2009 | Husqvarna Viking 1
Singer Athena automatic needle threader does not work.
Check on the threader and see if the part that goes through the eye of the needle is bent. This is a very common problem. The threaders are becoming more and more difficult to replace. If the piece is bent, you can usually use a pair of tweezers to straighten it out.
Feb 07, 2009 | Singer 132QRFB Mechanical Sewing Machine
Automatic needle threader on brother se-350
Hi - first, make sure that you raise the needle to as far up as it will go. When you thread the machine, make sure you pass the thread through each number along the path - there is a hook on the threader mechanism that is really easy to miss. It is always a good idea to refer to the book when you are having a problem.
You might also try changing the needle. The threader has a teeny hook that goes in to the eye of the needle from behind, grabs the thread, and pulls it back thru the eye of the needle.
The threader can go out of alignment. If you got the machine last fall, it should still be under warranty. You can call Brother and ask where you can take the machine for repair. Or, you can go to Brother's website and look for information that might be helpful.
Good luck,
Ginny
Dec 21, 2008 | Brother XL-3500
Automatic Threader Never works
lever the auto threader slightly back and pull down- if it doesnt pull down adjust the needle up or down slightly. Once it is down behind the needle, place thread under far left of threader then pull across to far right and hook behind tiny hook. Sounds complicated but not so when you get the basic action. Release and guide back up and the thread should be thru the hole and looped up bahind it. Hope you get it.
Jan 29, 2008 | Janome D'cor Excel Pro 5124 Mechanical...
Brother SE-270D Computerized Sewing Machine Logo
397 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
