Question about NetGear DG834G Router
Netgear router wont let me get on line
I can get online just fine until i try to load the router then i cant get on line. can you help me please. thanks
  • myeishawilli Feb 12, 2009
    i cant get online it tells me that monzilla fire fox has crashed
  • musicmn58 Feb 23, 2009
    I have established a wireless network and connected but it says local only. Other ones I connect to say internet. I can get on internet with those but not mine.
  • 55 Answers
Check the settings of the router
Posted on Jan 09, 2009
Cant connect my presario r3000 to netgear n600 router
First unplug the power cable from your modem. Then press and hold the power button of your modem for at least 1 minute. Then plug in the the power cable and wait until all the lights become stable. Then you can try to go online to check.
If after this step you will not be able to go online then contact with your ISP provider.
For More information you can call at +1-877-255-3353 or visit our website http://fixsmith.com/
Jun 06, 2012 | NetGear WNDR3400 N600 Wireless Dual Band...
I bought my netgear WGR614 box 6 months ago. Everything was working fine until yesturday. It picks up an excellent connection but wont connect to the internet. I tried turning it off for awhile, resetting...
This has happened to me before. I had to unplug my router, then unplug my modem aswell (if you have one) and I waited for a good 10 minutes. Then plugged my modem in and let it boot up all the way, then plugged in my router, and it worked fine after that.
Hope this helps, Nathan Taylor
Jul 18, 2011 | NetGear WGR614 Router
Old xbox 360 & netgear are fine. but i cant get new xbox 360 to hook up to netgear. after i put the pass code in it still wont hook it up(online). it has full bars . its wireless. what should i do?
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.1.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
now scan for the wireless network on the XBOX and connect to the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 16, 2009 | NetGear WGR614 Wireless Router
I'm on AOL and use a Netgear DGB111G router. It's been fine until recently when it takes about 30 times to initialise and for the wireless, DSL & internet to set properly and then we can get on line....
It could be your router, do you update the firmware of the router? That might help. Also do you have a modem from AOL? if you disconnect the router do you get online right away?
Sep 08, 2009 | Computers & Internet
Cant connect to the internet
Hi, Can you provide some more details:
1. Model number of wireless router?
2. Are you online when connected direclty to the wireless router using ethernet cable.
3. Operating system on the computer with the adapter WPN111.
This will help me provide an effcent resolution.
Jul 28, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
Router connected to the internet but no network on another pc
yes... this is most likely a settings issue. first, you need to get to the router settings page.
this will usually be http://192.168.1.1
if it isn't... do you know the ip address of the computer that is currently connected to the network?
Mar 13, 2009 | NetGear WGT624 Wireless Router
1 of the 2 computers cant get online
Pleaase check if the PC connects when plugged directly to the DSL or cable connection whatever you have without the router in between. That would ensure the functionality of the ethernet card on the other pc.
Feb 10, 2009 | NetGear MR814 Wireless Router
Netgear 108 Mbps Router WGT624 v3
As you say that, you are able to go online with the modem, connect your modem- router and laptop witha cable and check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be checked..open your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
Nov 27, 2007 | NetGear WGT624 Wireless Router
NetGear DG834G Router Logo
114 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
