Question about Koss KS3102 System
DVD plays few minutes than screen freezes with pixels
Must unplug and start the DVD over.
  • ruthouzts Dec 27, 2008
    I am trying to watch Mamma Mia (a brand new DVD) after about 10-12 minutes the screen freeses with scattered pixels on the screen. It has happened on other DVD's in recent weeks.
    Genius:
  • 1,239 Answers
Hi
Try cleaning the DVD lens with a cotton swab moistened with isopropyl alcohol. The DVD lens is what emits the laser from the unit. Let it dry and try again. Also try using a different DVD. Let us know if it worked and don't forget to rate me :)
Posted on Dec 27, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 27, 2008
    first step should be to clean the optical pick up unit. There is a special CD for cleaning of the optical unit (wet method).
    If this does not provide a solution please come back and advice.
    Best regards,
  • ABHISHEK.C
    for any clarification please contact me
  • 10,594 Answers
I think laser optical block got stuck when it move forward. (sled servo problem)
Please observe lens movement If you can open top cover of unit.
Take out loaded disc and move optical block to inward and outward position by holding it in your finger and make sure dont touch lens itself to avoid finger prints on it.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, the act of unplugging is simulating a reset just like in a computer. And just like in a computer, if a reset corrects the problem, then it was a glitch in the Operating System. In the Koss KS3102, it would be the firmware.
Another possibility would be hardware. Offhand, a possibly problem with the power supply of the unit, more specifically the standby +5VDC. Probably a filter capacitor either in the primary (most likely) or on the secondary (least likely).
Pls post back any other indicators if observed. Additionally, pls try to measure the resistance of the speaker through the speaker wires, should be between 4~8 ohms. This is just to eliminate the off chance possibility that the speaker is causing an auto protect.
Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 27, 2008
    Based on your additional information, try a CD disc cleaner
    that is readily available from most audio/video stores and even
    computer stores. They are designed to look and play like regular discs
    but with a brush like attachment designed to clean the lens.
    Cheers.
  • Louie  Role
    It may also be worth your while to check on the small shafting that
    guides the carriage of the laser pickup. Dirt, grime, dust and
    solidified lubricant can cause stoppage of the carriage and the laser
    eye then fails to read the next track. Please refer to the image below.
  • Koss Master
  • 19,396 Answers
That means that there is a short on one of the imputs or an internal problem.
Unplug all wires, and start the unit with minimal connections (one input or none, and only two speakers).
If you still have the problem, you need to send the unit for repair.
Call the number listed on te owner manual to get support.
    Genius:
  • 3,422 Answers
Please describe your problem in detail.
PS3 keeps freezing with colorful pixels. How can I fix this?
You need to use a vacuum and suck the back out or blow it out with air . While power is off on PS3 turn power on holding down the eject button it will blow it self out .
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Sep 20, 2014 | Sony Playstation 3 (PS3) Console
The player either freezes completely or pixelates during playback
I think the problem is for this the disc may be damaged. Or dont use copies this freezez and ruines the system, there may be a microchip problem i sugest return it and ask for compesasatin
Dec 21, 2009 | Samsung BD-P1500 Blu-Ray Player
DVR making bad DVDs
Three suggestions:
1) take it apart and clean the laser and the spindle 'hub' that the DVD rests on
OR
2) get a 'cleaner' disk that will 'whisk' any dust from the laser diode.
OR as a final suggestion
3) replace the DVD recorder with another. Plain old EIDE parallel interface units fit fine.
This is a very friendly machine in that it will accept PC compatible hard disks and DVDR drives.
tom
Feb 04, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Picture will freeze.
Either the disc is scrathed or you have to remove the cover and take a q-tip with rubbing alcohol and clean the lens.
Jan 22, 2009 | Cyberhome CH-DVD 300 DVD Player
My burned dvd will only play for a few minutes then freezes
Hello, this is more than likely the media you're using. The best to use for this are verbatim-r or taiyo yuden-r dvds. Also, could be your burner. Imgburner is the most popular one used which is free
Nov 15, 2008 | Compaq Evo D500 PC Desktop
Plays a few minutes then stops, and will not play any dvd
ITS THE MOTOR ITS FREEZING ON YOU NEEDS TO BE REPLACED
Jul 01, 2008 | Fusion DVD-811 DVD Player
P50W38H screen flickers and red and green pixels shimmer
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 16, 2017 | Zenith P50W38H 50 in. Plasma Television
DVD Freeze-Ups
Sounds like the transverse motor is bad.
Dec 03, 2007 | Samsung DVD-P241 DVD Player
Movies on my recorded discs freeze after a few minutes of play
Sometimes this unit gets "confused" - not sure why -- but try first using a CD cleaning disk and let it start and stop a couple times (sometimes lens gets dirty and does this) - if that doesn't help then try unplugging unit and leave unplugged (from wall socket) for about 30min then plug in, set local time and then see if the disks play okay - sometimes this "resets system"
Jan 20, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Koss KS3102 System Logo
Top Koss Audio Players & Recorders Experts
Steve Allison
Steve Allison
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
