Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
Whirlpool Duet Dryer stopped working
When you press teh control button nothing happens. There is power to the outlet, so I am guessing something is wrong in the dryer. I have seen several notes about thermal fuses but can't locate the thermal fuse on this dryer. Is there another way to test?
  • Anonymous Apr 13, 2009
    I am having the same problem. Just got it installed yesterday. It's a DUET SPORT model. Suddenly it stopped working. It has power, doesn't run any cycles though and also doesn't have any error codes...will be contacting my retailer for replacement. Weird?
  • 30 Answers
There is a set of instructions available at www.AnyoneCanFixIt.com for this problem. Specifically at:
http://www.anyonecanfixit.com/household.htm
It's a quick and easy fix.
Posted on Sep 19, 2009
Model FEQ1442ES0. I press the start button and all I hear is a click, nothing happens. What's wrong?
I appreciate your inquiry, Cody!
I see that your Frigidaire dryer is not operating after you hit the start button and it clicks. It is possible that your control panel or wiring harness could be causing this issue with your dryer. You may need to perform a reset on your dryer and you can do that by disconnecting power from your dryer for at least ten minutes. If this does not correct your issue I would seek assistance from a professional technician for a proper diagnosis and repair. I hope this information is helpful to you. -Matt
Jun 15, 2015 | Frigidaire Dryers
Tv will not power up
Press the TV button or ON/OFF button while remote is in TV mode and there's a source of power to the outlet or outlet strip.
Make sure the TV is plugged in.
You might have tried to turn on the TV during the lamp cool-down. Wait a few moments and the picture will appear.
Has the power light on the front of the TV been blinking for one minute? If so, the lamp may be dead. Refer to the Power indicator
is blinking or flashing section below for more information.
When you first plug your TV into an outlet, the Power indicator on the front panel will light and blink for approximately 30 seconds
and then go off during the initialization of the TV. This happens only when the TV is unplugged and plugged back in. The TV can
only be turned on after the Power indicator goes off.
Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else, such as a lamp.
Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the
remote control solutions on page 53.
Multiple TV Setup might be set to the wrong option. Press MENU/OK on the front panel. Select Setup Options, then Advanced
Options, then Multiple TV Setup. Choose TV (default).
Sep 26, 2013 | RCA Scenium M50WH187 50" HDTV
I have a blank screen when I turn it on and nothing happens but the sound works.
hi,
can you please try to power drain the laptop, removed the battery and the unplugged the charger then press and hold the power button or the on/off button for 15 seconds, obviously it will not turn on since there is no power supply connected, after 15 seconds, connect the laptop direclty to the power outlet without using the battery just for the meantime, then power on the laptop, see if theres any difference, if nothing happens, there is something wrong woth the monitor itself.
Hope this will help...
Jan 19, 2011 | Acer Aspire One PC Notebook
I have no power
Check all your breakers/fuses panel if none are tripped or blown we will assume power is @ the outlet, check it w/ a meter if you have one. I have never seen a reset button on one before but there could be a internal fuse inside the unit, to check for that you will have some disassemble work 1st
Oct 25, 2009 | Dryers
Frigidaire LEQ1442ES won't start
A defective dryer thermostat could be what is preventing your dryer from starting. Open up your dryer's cabinet. Test each of your dryer's thermostats. Replace any that have become defective.
Also check the electrical output from your house;
Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
Hope this initial info helps
Jun 13, 2009 | Frigidaire Electric Dryer
Outlet wired wrong, nothing works
Ouch! That would of applied 220 to the controller. Do any lights come on or can you get it to do anything now that it's wired right?
Apr 13, 2009 | Whirlpool Dryers
Kenmore dryer electric doesnt start
It sounds like the dryer drum belt is broken
there is a drive belt that goes all the way around the dryer drum and when you press start the drum starts turning unless teh belt is off or broken
You can change the belt or call and have service technician change it
Jan 04, 2009 | Maytag HYE3657A Electric Dryer
Kenmore 110.69912990
Need more info. Check voltage at outlet. Check thermal fuse,
check thermal cut-off assy. Then you have question -what caused the thermal to fail? There are several.
Mar 17, 2008 | Kenmore 73952 Gas Dryer
Washing Machines Logo
126 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
