Question about Apple iPod MA446LL/A MP3 Player
Tuner receiver not working
I am having ipod video 30GB. I would like to connect the Kensington Duo FM transmitter & receiver. I ahve tried to receive the radio station. I couldn't receive the radio station whereas it transmit the signals.
SOURCE: 30GB ipod not showing any content
hey i have a 30gig ipod i am it was working fine i use real player to music on it previously but now that i have tried to do it an no it show the music on there from real player an even when i go under my computer but its not showing up on my ipod.
Posted on Jan 07, 2008
  • 13433 Answers
SOURCE: APPle 30gb ipod connect to your pc use to restore
Hey, watch this tutorial and try the things it suggest.
Id highly recommend, restarting, and returning the device into the original state.
All this is covered in the video here:
Posted on Mar 12, 2008
SOURCE: My Computer and iTunes does not recognize my iPod
Download the Ipod Reset Utility from
Posted on Jun 16, 2008
  • 903 Answers
SOURCE: ipod 30gb help
Posted on Nov 02, 2008
  • 470 Answers
hmm actualy that is a very easy problem my dear,, your video is ot compatible,, because the file is not supported,, the only way of solution is to convert it into 3gp file,, it is a universal video file format to flash it in any type of unit,, so you can also get a video on youtube and easily convert it on what you want, but make sure you are choose the #GP file,, so what are you waiting for get the video converter now,, here i suggest the best converter of all, its a free download a video get product,, just download it
Posted on Jan 19, 2009
  • 50 Answers
SOURCE: My ipod is frozen!
Don't worry, before you call it broken you should try a hard reset: press menu and center buttons together for 5 sec. That will turn it off and restart it. If it keeps freezing on you, there may be a hard drive issue. There are ipod repair guides online that show you how to replace it.
Posted on Apr 14, 2009
0 characters
1 Points
I want to connect my ipod to the radio
According to Apple, over 90 percent of new cars retailed in the United States are equipped with iPod connectivity.
The iPod has become such a popular device, that many car stereos are now furnished with a 30-pin dock connector cable in order to link to the portable media player.
But this built-in compatibility is not essential for connecting your iPod to your car stereo. In fact, there are numerous options for integrating your iPod with your car.
Recently manufactured vehicles can support an iPod connection through an auxiliary input.
And FM transmitters can be used to stream your iPod's audio files through an FM frequency. iPods can even be connected to much older car stereos with the use of a tape adapter.
Connect an iPod to a Car Stereo Through the Auxiliary Input
Insert an extension cable with 3.5 mm stereo connectors on each end into the headphone output of your iPod. Insert the other end of the 3.5 mm stereo connector cable into your car stereo system's auxiliary input. Press the "Aux" button on your car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With an FM Transmitter Insert the FM transmitter into the 30-pin dock connector of your iPod. Turn on your iPod to activate the FM transmitter. Select the FM frequency you want your device to stream audio to on your car stereo. Turn on the car stereo and tune it to the same FM frequency as the FM transmitter attached to your iPod. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With a Cassette Adapter Plug the jack connector of the cassette adapter into the headphone output of your iPod. Insert the cassette into the car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod.,2817,1865467,00.asp
Feb 10, 2013 | Apple iPod MP3 & Digital Media Players
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 | Apple iPod touch
How can I connect an iPod to work through a car stereo?
<p>An iPod can store hundreds of songs makes it an ideal source for music on your car. Buy an adapter is the easiest and cheapest way to connect your iPod to your car stereo system. Do you know which adapter fits you best and know how to use the first steps to expand their musical possibilities. <br /> <p><br /> <p>Tape deck <br /> <p>1. Buy an iPod adapter cassette player, if your car has a cassette player. This is one of the easiest and cheapest way to get your iPod to play music from a car radio. A cassette adapter is shaped like a tape with a wire connected to an end. <br /> <p><br /> <p>2. For a cassette adapter or a store of electronic music in good standing. This adapter is relatively easy to find and can usually be purchased for less than $ 20. <br /> <p><br /> <p>3. Slide the cassette tape in the car. Take the end of the cable and connect the headset to your iPod. Select a song to your iPod and press the "Play". Be sure to order the car stereo's cassette player. <br /> <p><br /> <p>FM Transmitter <br /> <p>1. Purchase an FM transmission adapter if your car has a cassette player. This type of adapter connects to both your iPod headphone jack or car cigarette lighter and stream music via FM radio signal. <br /> <p><br /> <p>2. In an FM adapter to send any electronics store. This adapter is a little more expensive than a cassette adapter. Make sure you have an FM transmitter instead, for many FM stations broadcast from a transmitter can only be transmitted to a unit to buy. This gives you more options when you're in certain areas where FM stations are vague or nonexistent. <br /> <p><br /> <p>3. Connect the FM transmitter for the iPod to a lighter (depending on model purchased). Turn on your car's FM radio and find a channel that is unoccupied. Adjust the transmitter to the channel number exactly the same and then to match the iPod. For example, 99.1 FM if you find a free channel in your area, the FM transmitter on 99.1 reading. Connect the iPod and press "Play." <br /> <p><br /> <p>Extra- <br /> <p>1. Purchase an additional cable if your car has an auxiliary input panel. This type of iPod adapter is one of the easiest ways for your iPod to play music in the car. <br /> <p><br /> <p>2. Find a reputable shop and buy an electronic overhead. This type of iPod adapter is usually sold for about $ 10. <br /> <p><br /> <p>3. Connect the cable to the extra auxiliary input on the dashboard of your car and plug it into the iPod headphone jack. Make sure the sound of the car is in standby mode. Select a number and press the "Play" button on the iPod to the music to start. <br />
Will the apple ipod nano 5th gen. work with this system. Sony AIRSA20PK S-AIR iPod Dock and Digital Wireless speakers
  • Compatibility: iPod mini; iPod nano 1G, 2G, 3G, 4G; iPod classic 4G, 5G, 5.5G, 6G; iPod touch 1G, 2G; iPhone, iPhone 3G, iPhone 3Gs
  • Wireless audio system includes iPod Dock/Transmitter and two wireless speaker systems with LCD display and alarm clock function
  • AM/FM tuner provides alternative to iPod content; multi-zone function means iPod can play in one room while radio plays in another
  • Expandable system is easy to set up, and is compatible with up to ten speakers with the compatible audio receiver
  • Connect to your home AV system with composite audio and video cables for enjoying iPod content
  • May 07, 2010 | Apple iPod nano 5th Generation
    How to add an iPod Input into a Stock Radio?
    <p>You can add an iPod to a stock radio in your car, even if the plant does not have an auxiliary input or iPod input using a specific number of iPod car accessories. One such accessory is a cassette adapter that plugs into your iPod as a headset, but ends on a cassette tape to your stock cassette radio. However, not all cars have cassette players, thus more accessible to the FM transmitter. <br /> <p><br /> <p>1. Connect your iPod to an FM transmitter, if you connect headphones to the iPod. <br /> <p><br /> <p>2. Connect the FM transmitter to your cigarette lighter to power and then to the transmitter. <br /> <p><br /> <p>3. Press up and down on the transmitter to the FM transmitter to change, you will pass the signal to your radio. Choose a station that is not a radio station on it so you do not interrupt the signal. <br /> <p><br /> <p>4. Set your stock radio to the channel you selected on your transmitter and then play the songs on your iPod. You will see the songs on your iPod through the radio station you selected. <br />
    How do I Attach my iPod to a Radio in a 2002 Miata
    <p> <p>Apple's iPod is a great way to listen to your favorite music in private and comfortable. The transfer of this experience in the private confines of your Miata is a great way to enjoy your music while you drive. Apple recommends a variety of devices that you connect your iPod directly to your Miata radio. Attaching your iPod to the radio in his 2002 Miata is a task Hable accompli given the right materials and installation. <br /> <p><br /> <p>1. Buy a car adapter. Apple recommends a variety of products at a price range and power, the Monster iCar Play Wireless 800 FM Transmitter $ 79.95 Belkin Tune Cast Auto for Live for $ 69.95 in FM Transmitter Griffin Road Trip with Smarts scan for RDS + Power $ 99.95. All products are recommended by Apple, the producer and distributor of iPods and all are available through the online store Apple Auto Accessories.<br /> <p> <br /> <p>2. Attach confirmation that the iPod radio tuner device purchased at the door on your iPod and plug the other end of the device in device port Charger / charger in his 2002 Miata. Depending on the interior options that you selected for your Miata, and the automatic or manual transmission, the device port cigarette lighter / charger is located in the panel below the radio in the glove compartment or center console area between the two banks front. <br /> <p><br /> <p>3. Miata Turn on the radio and choose a radio station with little or no audible sound. Typical among the 90 FM stations are reserved for local stations with low transmission towers, so they are often your best option. <br /> <p><br /> <p>4. Connect your iPod and select the radio through stereo cables to your Miata on your device FM radio tuner. For example, if your radio is tuned to 88.1 Miata, you have radio receiver can be tuned to 88.1. <br />
    Itouch does not play through fm transmitter
    i had the same problem... like it played through the itouch speakers and not through the radio how do i get it to play through the radio
    Apr 07, 2009 | Griffin Technology iTrip Auto FM...
    FM Radio
    iPods do not come with FM tuners. FM tuners can be bought and added on as an extra feature, but this is a third party device, not an iPod device.
    Generally, when you connect the third party FM tuner to the iPod, the iPod will recognize it and you can use the 3rd party FM tuner to change stations.
    If you do not have the FM tuner to connect to the iPod, the individual that sold you the iPod did not include the FM tuner to connect to the the iPod. In that case, the Menu will still list the FM tuner, but there is no device to connect to the iPod.
    Sep 09, 2008 | Apple iPod MA446LL/A MP3 Player
    Mar 08, 2008 | Apple iPod MA446LL/A MP3 Player
    Apple iPod MA446LL/A MP3 Player Logo
    Top Apple MP3 & Digital Media Players Experts
     Mike M
    Mike M
    Ron Dufek
    Ron Dufek
    Raisin Brann
    Level 1 Expert
    Are you an Apple MP3 and Digital Media Player Expert? Answer questions, earn points and help others
