Question about PC Chips A33G (V1.0) Motherboard
Pc chips a33g no boot windows
I have a pc chips a33g board that will run linux just fine.when i try to install win sp3.(after a format)nothing happens.like i said i formated the entire drive did not work.even put in a window partitioin (dual install with pc linux).Please help linux is not family freindly.
  • gsfletcher1 Dec 28, 2008
    not using sata plugs (duel plug board) using standard ide plugs.Was thinking of buying bigger sata drives good info to have thanks.Any other ideas?I working on 733mhz system now driving me nuts!!
  • 781 Answers
If you have a SATA hard drive your windows disk needs SATA drivers on it.
Download Driverspack from this site
http://driverpacks.net/DriverPacks/
Mass storage one
then copy windows CD to hard drive and use "Nlite" to install driverpack into it then burn windows to new CD and try again.
This should solve your problem
Posted on Dec 28, 2008
  • David
    David Dec 29, 2008
    When you try to install windows from a boot CD what comes up install screen or nothing.
    Sometime it may come up with "cannot find hard drive" or similar.
    Try downloading "Hirens Boot CD" burn to disk and boot from it.
    It has a lot of different utilities on it. Read on web site what it does.
    Because you had Linux previously installed it. your hard drive may not have "the Windows MBR" on hard drive so cannot find hard drive.
    the boot CD will install the MBR (Master Boot Record)
    Or use partition magic (on CD" to partition hard drive.
    If I was there could solve problem.
    You could also try a full format with one of the format programs
    I cannot remember what one I used but it did the job
    Whatever format program you use do not forget to make it active
I want to Install Linux Mint on ThinkCentre M55p Series Type 8811
If it Has Windows 8 or 8.1 you might need a new Hard Drive to do this. Windows 8 and 8.1 are encrypted so you can't use Linux of any type. If it has Windows XP try Linux Mint 13 "Maya", the replacement for win xp, If Windows 7 64 bit: Try Linux Mint 17.1 *Rebecca"
Apr 22, 2014 | Lenovo ThinkCentre® M55-8811 PC Desktop
Boot with press f1
to do a format you must boot the pc with the disc in the drive, and set pc to boot from dvd, in boot options, then when it comes to install options press options and format, this will do a wipe/format and you should be ok from then.
Jan 26, 2013 | Dell OptiPlex GX110 PC Desktop
Unable to here sound from my HP Desktop with win Xp sp3 pc model HP compaq dx 2280 MT
Try booting in safe mode and go into device manager and remove all items under sound and reboot and your sound should come back if your audio chip or card is not defective. Here is the link for the drivers SP3321277 Hope this helps
May 11, 2017 | HP dx Computers & Internet
It wont boot, but read corectly at bios screen, but when i try to reinstall an OS such as linux ubuntu, win xp and win 7, it says that cant find any HDD..@ linux Os, its readable but when we try to format...
I would recommend using a boot disk and run chkdsk (windows boot disk) or fsck (linux) This will help fix bad sectors if you use the correct options. USe the "/?" in windows for help and "man fsck" in linux.
Good luck and let me know how it goes.
Joe
Feb 15, 2011 | Fujitsu - MJA2160BH 160 GB SATA Hard Drive
Got a new 160 GB Seagate Hard disk. Formatted and installed Windows XP SP3 on it. But the problem is it gets hanged randomly every time i boot it. Tried re-formatting it, but it gets hanged even at this...
I suspect that this is NOT a HDD issue but a driver one. I suspect that you may have some driver conflict. Try booting in Safe Mode, if it does OK, then this proves it. you will then have to go through the drivers one by one until you find the bad one. Often it is the Video driver.
Try a reinstall with XP SP 2 FIRST, then upgrade as necessary, some PC's just don't play well with SP3 installs.
It MUST be a windows/driver/setting issue as you relate it works on linux.
Aug 03, 2010 | Computers & Internet
Problem installing OS in a newly assembled PC
Try installing first the windows xp.Make two apartments and install the Xp on the one.The other one format it,boot with the linux cd and try to install it to the empty apartment.Be sure that your system supports the linux kernel because some of the CPU brands don't support the linux OS;S.
Good Luck
Jun 23, 2009 | Computers & Internet
Updated driver for win xp sp3 (946gzts)
all drivers for ur board , i dont understand that ur driver does not support SP3 it is not like that Service Packs always comes with backward compatibility anyways try to install ur driver again and let me know abt the results otherwise i will try to find the updated version from some other sources pls rate me FIXYA for this if u like
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2483&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go!
Mar 13, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
System is booting but display is not comming
u cannot use linux and xp in single system.....because linux boot loader is highier version so it will not allow the win xp boot...u need to format the system and install the xp itself..thanks
Sep 19, 2008 | Zerus Intel Desktop Board D815EEA...
MoBo Replacement
did you go into the new bios and check to make sure you have the hard drive setting on auto, then check your boot order that the drive is first to boot., if that doesnt work create a floppy boot disk (google it) and see if you see the hard drive when you do that.
Feb 15, 2008 | Computers & Internet
Where is Linux mbr file
There's nothing like the Linux MBR File. The option to boot to multiple operating systems is controlled by a software called as the "Boot-Loader".
Windows XP and Linux both have their versions of boot-loaders. The Bootloader that Windows XP uses is called the NTLDR, whereas Linux provides many bootloaders (prominent among them being "Grub" and "LILO").
>but Linux is shown in the manage option from the My Computer in Win XP 2.....
That is the control section of NTLDR. So from what I understand you shouldn't have a problem selecting the operating systems.
If you want the Linux bootloader taking control of the boot process, you can always install it.
All you need is a Linux CD and then run the setup for "Grub" or "LILO".
Information about installing Grub or LILO can be found easily on the internet.
Oct 19, 2007 | HP Data Protector Express Software...
PC Chips A33G (V1.0) Motherboard Logo
289 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
