I have a whirlpool top load washer.. mod number lsr5132pq4 and when it spins out it shakes and vibrates extremely loud
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Loud vibrating washer
What is the model number of the unit?
Mar 03, 2014 | Kenmore HE2 Plus Front Load Washer
My whirlpool cabrio washer makes a loud noise when it spins
The bearing is probably going bad, spin it with your hand if it makes noise or you feel a vibration its bad Parts for Whirlpool WTW6600SW2 Motor Basket and Tub Parts
May 27, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Squeaky basket and loud vibration when in spin cycle.
Bearings worn, belt loose and probably motor brushes.
May 17, 2012 | Kenmore HE3T Washer
Kenmore Mod.#11027831600. When in spin cycle the washer shakes and move around the floor. I check that it is level. And that the clothes were in the evenly.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:!retrieve.pd?modelNumber=110.27831600&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
If it's not the springs or pads, you may consider that the "Agitator Cams" in the transmission are not raising the Agitator Gear high enough (about 1/16" ) when the washer goes into spin mode.
See the description of what the Cams do in the Service Manual.
We had the same problem, excessive vibration and noise during the spin cycle.
In order to solve that problem, :
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
It sounds a bit complicated but it really isn't too bad and (For a $15 part, saved buying a $170 transmission.)
Following is the Whirlpool parts list for their commercial washers although the consumer models use the same part numbers.
Aug 06, 2010 | Kenmore 27831 Top Load Washer
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Extremely loud rumbling thunderous sound emits at the end of the spin cycle. And the washer itself makes a rather unusual shaking or vibration at the very few seconds of the end of the spin.
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if the tub brake is grabbing.
Just as on a car, if the brakes grab the rotors or in particular the brake drums too hard, the car will shake.
If the brake shoes on the washer grab the brake drum too aggressively, the washer will emit a loud noise and shaking.
A way to resolve the problem is to actually force some slippage into the system.
When ours did the same thing, I sprayed some silicone grease very lightly and carefully into the brake drum.
Following is a description of how to access the brake system.
When you pull the brake tube, check the condition of the brake shoes and when re-installing the transmission, be sure to align the clutch so that the plastic cam on the basket drive is outside of the smaller section of the clutch spring holder.
As an aside, when you remove the tub, instead of a special spanner nut wrench, I've used a short 10" pipe wrench and tapped the handle with a hammer. I also used a short piece of wood under the drive block when tapping it up with a hammer.
Be sure to align the tabs on the drive tube with the slots in the drive block when re-assembling the washer.
Oct 20, 2009 | Kenmore Washing Machines
Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Feb 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
New washer rattles and vibrates when on spin cycle.
did you remove the yellow tab at the pack to pull the shipping pins check your owners manuel under installation for details let me know
Mar 30, 2008 | Whirlpool GST9679P Top Load Washer
Washing Machines Logo
105 people viewed this question
Top Washing Machines Experts
