Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite front-load
My washing machine is smelling musty---I have tried washing a load in HOT water but it does not work ---it's still there. I was wondering if i needed to put something into my washing cycle or something.
I think i may have left some clothes in it wet for awhile when my Dad passed a few months ago---I think that is when it started. I really notice my towels never smell good. Always a hint of a musty smell.
It's a Kenmore Elite Front load HE3t
Thanks for your time !!
Kim
  • stolz772004 Jan 02, 2009
    Thanks a Bunch !! I did clean the pump and yes it was nasty !! I need to do the bleach still !! But I think that will Fix Ya !!!
    Thanks ----Kim
  • 640 Answers
You must remove bottom panel ,,in the center front you will find pump,,remove pump filter,,always unplug first..it has slugg,..than after you clean filter run your unit once a month with a pint of bleach and hot water only..also wipe your rubber gasket or bellows with a touch of bleach..
Posted on Dec 28, 2008
  • onthethejob1
    onthethejob1 Jan 02, 2009
    im here great,,,
We use well water . after washing tower 2 or 3 days of use tower it starts to smell musty .how do we prevent this?
If the machine has a "clean washer" setting, run that with 2/3 cup bleach only (no soap). If it doesn't have a specific setting to clean the machine, run a small load with hot water and use 2/3 cup bleach, no soap.
If you're asking how to avoid the problem altogether, you'd most likely need to install a water softener, or water filter.
Mar 17, 2015 | Kenmore Elite 45986 Front Load Washer
My clothes smell musty after they have been washed. I was told to replace the rubber gasket in our Kenmore front loader he4T by the sears repairman for quite an expense. How can I replace this gasket...
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Dec 30, 2009 | Kenmore Elite 45986 Front Load Washer
FTF530FS Front Load washing machine. Clothes smell.
all front load washers have the problem. Mold and a build up or dirt and soap and fabric softner cause s old musty smell. The low water use makes the machine dirty and build up inside. Run a few Hot water washes with out clothing, Run it empty ,(run your hot water neer your washer to get the cold water out of the house pipes) hot water and pour bleach in side, 2 or more cups. Keep doing it. When your not using washer leave the door open so air can get inside. Hot wash,es with bleach will keep it clean, also dont use fab softner.
Nov 11, 2009 | Frigidaire FTF530FS Front Load Washer
Smell
One downfall of the front load machine that it holds moisture causing musty smell in drum. Try leaving door agar between washes and use a cleaner specific for front load smells 1 every month.
May 29, 2009 | Frigidaire ATF6000ES Front Load Washer
Smell coming from inside washing machine. Not musty.
This is a fairly common problem that often arises when the majority of washes are done with cold water.
Do what is called a maintenance wash where you set the machine to run with hot water and maximum fill of water. Add one half cup of baking soda and let it run through it's entire cycle with absolutely no clothes in it.
After it completes its full cycle check for that bad odor. If it is fully gone wonderful. If it is half as bad do a second maintenance wash.
If the maintenance wash doesnt seem to help at alll get back to me and I will make another recommendation.
May 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
1994 Kenmore 90 series washer smells musty
Do a boil wash without clothes & detergents, with a cup of bicarbonate of soda in the soap drawer.
Mar 30, 2009 | Kenmore Washing Machines
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Water Remaining in Gasket Around Door
normal problem all front loads all brands.. leave door open as much as possible.. to clean fill tub with hot water pour in 2 cups chlorine bleach use rag in solution wipe gasket out as good as possible allow washer to run normal cycle ..do as routine when ever odor is first noticed leaving door open will allow most of water to evaporate
Nov 19, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Series 90 Washer
Aside from complete disassembly & cleaning it, try a hot wash on full with nothing in it except a bunch of bleach.
Jan 09, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
296 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
