Question about Panasonic TH-42PWD8UK 42 in. EDTV-Ready Plasma Television
Aspect Ratio not responding/always in "Full" mode
Recently, I noticed that I can not change the aspect ratio on the television anymore. I was already aware when I bought the TV that you could not change the aspect ratio when watching a high-def source, which was fine with me. However, even when watching a non High Def source, I can not stretch the picture, etc, as you should be able to. When the Aspect Ration button on the remote is pressed, it says "Full." However, the picture on the TV does not appear as "full" as described in the manual. Instead, it appears as "Normal" (cut off sides). When the Aspect Ratio butotn is pressed, nothing changes. This is when I am looking at a signal from my cable box, which is assigned to Input 3 (component/RGB inputs). On the other hand, I when I switch over to the DVD player on input 2, I can change aspect ratio just fine. One of the notes in the manual states: For a 1125 (1080)/60i, 50i, 24p, 30p, 24sF, 1250 (1080) / 50i, 750 (720) / 60p, 50p signal input, the mode is set to "Full" mode and switching is not possible. I have no idea what this means exactly, but is describes my problem, namely that I am only getting a "Full" aspect ratio (even though it looks "normal."). Is this possibly the issue? I assume this means that the signal input from the cable box is causing the issue? I've tried everything I can think of, including setting back to "Shipping" mode, normalizing during Picture adjustments, changing the component/RGB In select, with no results. Please help, I'm tired of not being able to use my full screen. Thanks much. Chip
  • Anonymous Mar 30, 2014
    PICTURE IS OUTSIDE OF IEWING SCREEN. ALL HEADS AND TEXT ON BUT OFF
Watch out for the old large black cable boxes. These are made for component and HDMI hookups. The normal yellow white and red hookups ( composite ) will not work right. You will need an HDMI cable box.
Posted on Mar 06, 2010
I have a panasonic th-42pwd8bk tv i have it working through my sky box, but it only works in black & white no colour. it works in colour on my pc what am i doing wrong. i have no user manual
Posted on Apr 22, 2007
    Novelist:
  • 192 Answers
Normally, when I see this problem in the customer's home, I find the main culprit to be the cable box. The remote for the cable box may have a button on it to change the format or picture size. You may have to go into the menu of the cable box to change the format setting. Hope this helps.
SOURCE:
Daewoo DTQ-19TV1fc aspect ratio changed to letterbox. How do I restore it to full screen?
get the on screen menu on the screen
scroll around till you see aspect ratio and click on that use the buttons to change ( you will see the changes on the screen)
click ok and exit when satisfied
Fir aspect ration to change there can be a few reasons
some tv stations produce movies in the wrong ratio and it shows up for the movie as black edges or tall figures or fat figures ( change channel to verify)
or there can be a fault occurring in the board of the set that will not hold preset aspect ratios
Oct 26, 2015 | Daewoo Televison & Video
How do i fix a too wide picture on my sony kdl40ex500?
Why are you using 4:3 letterbox? It might be the default aspect ratio but widescreen tvs should be set to 16:9 aspect ratio.
Aug 22, 2014 | Sony KDL40EX500 40 in. HD-Ready TV
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
How to adjust aspect ratio on sony kdl-v40xbr1
Hello
To take advantage of the wide mode feature on your TV, Set the DVD players' aspect ratio to 16:9. For details, refer the operating instructions supplied with your DVD player. Aspect ratio must be set with DVD player. Not with the TV. OK.
Feb 05, 2012 | Sony BRAVIA KDL-V40XBR1 Television
Does anyone know if the L37G10A supports PAL I as well as PAL B/G. I'm moving from Australia to UK and am wondering whether to bring the TV
Screen Type LCD Panel Type IPS-alpha Progressive Full-HD LCD Panel Panel Aspect Ratio 16:9 (Widescreen) Aspect Ratio Control Modes (TV/AV modes) 4:3, 14:9, 16:9, Just, Zoom1, Zoom2, Zoom3, DTV: 16:9 & 4:3 Full Aspect Ratio Control Modes (PC mode) 16:9, 4:3 Comb Filter Yes Progressive Scan Yes TV Tuner Receiving System DVB (Digital), PAL-B/G (Analogue) Tuner Type Integrated SD/HD DVB-T 7MHz Australia, PAL B/G
Contrast Ratio 1 - Dynamic: 20000 Picture Adjustment Modes / Film Modes Normal, Dynamic, Cinema, Eco Colour Temperature Control Cool, Standard, Warm
May 21, 2011 | Televison & Video
How can I get full screen image without distortion on tv viewing? I only get 4:3, zoom, full and justified. Full looks stretched horizontally with tv, looks ok with dvd.
Hello
Most of the telivision transmissions are comes at an aspect ratio of 4:3. Wide aspect ratio is 16:9. If you try to see a picture with aspect ratio 4:3 to wide 16:9, it will look like stretched. it is not the fault of the tv. Most DVD recording have the aspect ratio of 16:9 [Wide]. This aspect ratio will be displayed correctly when your tv is also set to wide mode. If you select normal mode at this condition, the picture will be displayed elongated. Ok Your Tv has no probelm.
Oct 19, 2010 | Panasonic Televison & Video
Signs that the bulb in a dlp is going out
A DLP Lamp will fail in two ways. 1.The glass tube housing the filament will shatter and the TV will not turn on. 2. The lamp has many hours of use on it and will gradually grow dimmer. At no time will the lamp cause any picture defect. Check your Cable or Sat box for the correct aspect ratio as well as the TV aspect ratio. Chances are the aspect ratio in either system is set incorrectly. If the gray borders are uniform then the aspect ratio is not set properly. If this occurs on certain channels but not others then the particular channel is broadcasting in the 4:3 aspect ratio and there is nothing wrong with your set.
Apr 12, 2010 | Samsung HL-67A510 67" DLP HDTV
Cannot change aspect ratio of picture when ratio button is pressed on remote. Batteries in remote are good. Everything else on remote works. Sony KP-57HW40
If you are connected to a HD cable or satellite box, the aspect ratio is set by that box. If it is set for 1080i 16:9 wide screen mode then your TV is locked at that ratio. This is good considering you have a Hi-Scan 1080i television in the Sony KP57HW40. Please take a moment to rate my answer. Thanks...
Nov 24, 2009 | Sony KP-57HW40 57" Rear Projection...
How do I change the aspect ratio
Aspect Ratio–Selects the screen aspect ratio: Normal, Wide, Zoom, or
Cinema. You can also press the ZOOM button to select the aspect ratio.
Aug 16, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Aspect ratio
this is normal as you are looking at WIDE screen aspect ..
Mar 27, 2009 | Proscan 32LA30Q Television
Panasonic TH-42PWD8UK 42 in. EDTV-Ready Plasma Television Logo
589 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
