Can't close door of CD on Sony CMT-CP1
When I put CD and press PLAY door with CD go in and inmidietly open again. Thats hapens a few times (sometimes 10-15 and more) before CD starts play. Thanks a lot for help.
Mine had the same fault. The CD is being rejected as it could not load up - this is probably because of the CD loading mechanism.
You'll need to unplug and remove the case - 4 screws on the sides and 4 or 5 on the back. Once this is done plug back in (be careful not to touch any live parts inside), load a CD and watch. What you'll probably see is that when the drawer closes the mechanism under the drawer doesn't lift sufficiently. Give it small push when it tries and I bet it then will and the CD will play.
What you need to do to fix this is remove the front panel/PCB and also remove the plastic cover that is screwed above the CD drawer so that you can see more of the topside of the mechanism.
Remove the front panel/PCB by releasing the 2 screws on the bottom and then easing forward. Gentle - as there are pins connecting the front PCB to the side PCB. You should then be able to see a worm drive type arrangement that lifts the lower assembly. This will need regreasing (I used vaseline) with a small stick (I used a Q-tip with the bud cut off). You will probably see where the old grease has been pushed out. Once you've done this, reassemble and operate a good few times to work the grease in.
Done! Mine works fine now after sitting there performing the annoying trick you described for many months!
Posted on Jan 08, 2009
My Marantz CD 53 CDplayer door is not opening. what is the solution
You probably have a broken belt on the cd tray so it's neither open or closed, if the laser's ok thats why it wont play
Mar 31, 2014 | Marantz Audio Players & Recorders
I have problem with my sony cmt-cp1 model. NO DISC
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case this don't solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 08, 2010 | Sony CMT-CP11 CD Shelf System
Help - CD won't eject! I press 'Open' on my sony CMT-EX1 system and the CD moves backwards as though it's going to eject but then it stays there, unreachable. Then the display begins to switch between...
I have the same problem and it's due to dirt!
I'm going to try using compressed air, but -
this definitely works:
:) Seriously:
tilt the cd player to a 45 degree angle (flat, basically - as if they tray were horizontal.)
I had my player for 10 or 12 years, and this problem is only coming up now. My house gets very dusty.
Also - vertical load disc players are hard to clean. X_X (inside the disc tray)
I love this stereo too!
I don't want to have to go out and buy another stereo!
Oct 16, 2009 | Sony CMT-EX1 CD Shelf System
CD tray does not open.
you need to change the motor belt charge of the tray
Jul 23, 2009 | Sony CMT-EP707 CD Shelf System
Cd does not spin
the motor will need to be replaced
Apr 15, 2009 | Fisher SLIM-1500 CD Shelf System
Cd doors don't open and Errors 1 and 4
I had the same problem with my CMT-EP707. I read on this site to try various combinations of turning power off then turning the power back on while holding down either or both of the stop play button and the eject button for the affected CD tray. What seemed to work for me was turning on the power while holding down the eject button for CD tray 2, even though the error referred to CD tray 1.
Jan 02, 2008 | Sony CMT-EP707 CD Shelf System
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
My Sony CMT-HPX9 has no sound
If it's not the mute, try replacing the output fuse. Did you hear a POP last time it was operating? Good luck
May 28, 2006 | Sony CMT-HPX9 CD Shelf System
752 people viewed this question
 Grubhead
Grubhead
