Question about Lexicon Lambda Usb Desktop Recording Interface Sound Card
Lexicon Lamda Problem
I recently just purchased a sterling st-51 condenser mic with the Lamda Lexicon usb interface. When I plug in the condenser mic to the interface, and activate the phantom power, the mic does not work at all. It has to be something simple. I just can't figure it out. Thanks in advance for any help.
  • 1 more comment
  • HPARER56 Feb 19, 2009
    I HAVE THE SAME MIC AND SAME PROBLEMS BUT I HAVE WIDOWS VISTA 64 BIT
  • matthew2157 Mar 10, 2009
    Dynamic mic works; condenser does not. In both mic inputs; there is a distant buzz sound when turned up loud.
  • Anonymous Mar 30, 2009
    I have the same problem - I tried an AT4033a condenser mic and got nothing, the phantom power light comes on but - no signal from the mic. The mic checks out fine on my Mackie mixer. Tried another good quality condenser mic and got same results.
I have a Sterling st-51 condenser mic and purchased a Behringer xenyx 1002b mixer. Similar problem, dynamic mics work in low impedence with or without phantom pwr on. My Washburn acoustic bass with preamp in line input section. So I tried it on my Omega Lexicon interface. The condenser mic and everything else works on the Omega. This unit has a wall wart ( your Lambda is USB powered). I checked the voltages with a meter and found 23 volts from the mixer and 48 volts from the Omega. Further, I have two Shure SM-82 line mics which work on the mixer with the inputs turned all the way down but do not work on the Omega nor on my Spirit SX mixer which has 48 volts phantom power. The SM-82s are old line mics that have a 9.6 volt battery in the sleeve. They overload badly in all but the 1002B mixer. Their voltage should run btwn the 9.6 battery or a 22 volt phantom power.
Check your Lambda voltage, It could be way less than needed by the st-51. I will check with a friend who has the Lambda and check its voltage. Bet it is too low.
Again, My St-51 and 1002B mixer combo barely works at 23volts, the Mic gain is all the way up as is the channel slider and the main output slider. I cant get any reading on my led meters, occasional bump on the first light, no possible way to clip the input or the output and have to turn the high eq off and the mid way back due to hiss noise. Hope this helps,couldn't find minimum voltages on the ST-51 as yet.
Posted on Apr 08, 2010
I recently bought the AKG Perception 120 and have a macbook pro. I also bought a XLR to usb cord to record it in Garageband... But there is no sign of any sound going through the microphone. Please he
Make sure your preferences settings in the MBP are set to use that input. USB recording is not the best way to do things. I'd look online and buy an inexpensive interface, like a Lexicon or Presonus etc, then the interface will connect via USB, but your mic will go into a genuine XLR input on the interface. You'll also benefit from much more gain and level control.
May 14, 2014 | AKG Perception 120 Microphone
What is the best way to run the mic on desktop
Your condensor mic requires special electrical handling usually reserved for proffesional audio equipment, not a PC. You will need two pieces of equipment, a short XLR cable and an adapter cable.
1) Behringer PS400 Ultra-Compact Phantom Power Supply.
This will supply the mic with necessary Phantom Power.
2) Rapco Horizon ISOBLOX Transformer Isolation 1:1 BLOX Device
This will isolate the Phantom Power from your computer, allowing it to work as necessary.
The adaptor connector cable you need will be a female XLR (with pins 1 and 3 shorted, pin 2 hot), through a cable connect to a 1/8" mini plug. They connect in that order with a short XLR cable between 1) and 2). .
Aug 23, 2012 | CAD Microphones GXL2200 Professional...
I installed the lexicon lambda with the disk provided but when i put my mic on the mic input it doesn't record... what should i do? please help!
first thing to do is check your sound and audio settings, goto control pannel,then, sound/audio setings and see if everythings set up properly
Sep 19, 2011 | Lexicon Lambda Usb Desktop Recording...
I have a lexicon alpha, samsung CO1 condenser mic and a samsung phantom power box, i have all the correct wires but i dont think i am connecting the correctly, HELP ME ! lol
Sorry, but the Alpha does NOT have Phantom power which IS required for a condenser mic.
You will either have to get a mic preamp that supplies phantom power or go to a dynamic type mic if you stay with the Lexicon Alppha.
Jan 17, 2011 | Lexicon Alpha Personal Recording Studio
Can I connect a CAD GXL2200SP Condenser Mic to a computer?
Technically, you can plug any microphone into a computer via an audio interface or USB(if applicable) With this mic it will require an audio interface just remember that since you are using a condenser you will need an interface that can supply phantom power. Good Luck, Cody J.
Dec 15, 2010 | CAD Microphones GXL2200 Professional...
Im having a problem with hearing my b-1 studio condenser mic on the lexicon alpha progam?
Sorry but... Very simply, you CANNOT use a condenser mic with the Alpha since it does not supply the required Phantom power for the mic. You must step up to another interface to use condenser mics. You can use dynamic mics with the Alpha or other audio sources. I use a Roland/Cakewalk UA25E interface with condenser mics and also the Lexicon Omega which does have Phantom power for the mics..
Nov 03, 2010 | Lexicon Alpha Personal Recording Studio
Have just purchased lexicon alpha to use on a Mac. Having trouble just getting started. Have hooked up a nice condenser mic into the alpha through the mic input on the rear and cannot get anything on the...
Make sure you have Phantom power turned on on the Lexicon... Oh,oh... it appears that the Alphs may NOT have phantom power which IS a REQUIREMENT for most condenser mics...
The Lexicon Omega does have this but apparently the Aplpha doesn't have it.
That leaves you with the choice of either getting a dynamic mic that doesn't need Phantom, or replacing the Alpha, OR using a preamp ahead of the mic before the Alpha...
Sorry, but those are the only solutions I see for you.
REMEMBER that condenser mics pick up everything and you cannot run them into a PA or they will feedback.
Oct 08, 2010 | Lexicon Alpha Personal Recording Studio
No Power to the lambda
Make sure the usb socket is working ,the lamda takes current from your computer.Don't use a usb hub.Make sure you are using xp service pack 2 or higher.Try another usb socket.
Jul 14, 2009 | Lexicon Lambda Usb Desktop Recording...
Lexicon Lambda on Mac
Hi, I just bought one today and am using a condenser mic through the lamdba. I booted up apple logic - plugged in the device and it found it as a usb audio device. You need to use the headphone jack on the lamdba. good luck
Dec 26, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexcion lamda and a mixer
yes you can. simply take a 1/4 in cable from the main out of you mixer and plug it in through one of the line in inputs on the back.
then plug whatever you want to record in through the mixer
May 03, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
998 people viewed this question
Top Lexicon Computers & Internet Experts
Tony
aftab Nawaz
aftab Nawaz
Alun Cox
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
