Question about Acer Computers & Internet
Sound input Hello, all I want to know is how to a conect a mic or line in to this brilliant new Acre Aspire 8930 I have?Mark from Kent
  • 45 Answers
On your laptop if it is supported there should 3 little holes with the colors of pink, green, and blue. For the mic you need to plug right into the pink one. It may have a small picture of a microphone above it which means that is the place for the mic. Remember to install any software first if included.
Posted on Dec 27, 2008
    Scholar:
  • 160 Answers
Look on the side or back of the pc for the mic plug-in input connection.
Does anybody know how to fix built-in microphones on rolland BR-600. When I attempt to record, the only sound that gets recorded is noice (hissing sound), and that only after cranking rec volume and mic...
Most of these have a SETTING in the menus that selects the source from different mics and/or line inputs. If the setting is to the line input instead of mic, and no audio is connected to the line input it will act like you described.
Jun 23, 2011 | Boss BR-600 Digital Recording Studio
Is there a LINE IN input at the back of the PC that is not a MIC input?
Hello jeff_glover
All computers have a line in and out input at the back of the tower . I 'm not familiar with your machine but if you can't find the inputs , go to the Device manager and check the sound, video and games controller .
Maybe it's only a question of driver and go then for an update from there . If you don't find the controller , you 'll need to purchase a sound card ( pci or vga ) .
Here are a few places where you can make your choise : http://www.google.com/search?sourceid=navclient&aq=2&oq=sound+cards&ie=UTF-8&rlz=1T4GGLL_enBE391BE393&q=sound+cards+for+pc#q=sound+cards+for+pc&hl=en&rlz=1T4GGLL_enBE391BE393&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=96KMTf3cONGRswby-P2NCg&ved=0CDUQrQQ&biw=1003&bih=630&bav=on.2,or.r_gc.r_pw.&fp=7c15a4d4522ad2f7
Best regards ,
fanaudi
Mar 25, 2011 | Gateway GT5438 PC Desktop
My acer aspire 5742-7653 internal microphone is not picking up sound. what's the fix for this?
go to the sound mixer(double click on speaker mark on the task bar). and then click on option, and then properties.you can see dialog box with recording and playback settings.
first mark on playback , and check activate the mic on that, if not put the tick on selection box.
then mark on recording. check the mic activation same as that. then click ok. you can see recording mixer.
OK now check have an advance controller button near the mic controller . if not click on option, and check have a tick with the advance controller. if not put the tick in frount of addvance controller. now already you in recording mixer. now you can see that button.
after that, click on "select" check box with the mic and increase the level to top. then click on "advance" controller, and put the tick on mic 1 boost. then close all windows and check the mic,
using via some recording software (like as windows sound recorder ), or activate the mic for working with speakers via put the tick on the mic tab on playback mixer. ( when that can hear like some siren noise , pull down the mic level to control that)
Dec 05, 2010 | Acer Aspire One PC Notebook
How do u get hsm wii microphone to work on
well ..i cant see what type of conection you mic has and what you really want to achieve as far as quality of sound or ultimate use..,but...here are some ideas.. A mic needs a pre amp and that is often built into some cheap but usable mini mixers made by behringer..You could pick up one and a good cheap dynamic mic[dynamic mics are best close to the sound source] with a lead and then go from the main output of the little mixer to the audio input of the computer.. A second but easier way and one that could give very good results is purchase a USB input microphone and this will have mic pre amp built in so it just plugs into your computer usb port.. SE electronics ,Rode make brilliant ones that are used often for podcasting..[well worth the +-100 uk pounds] but i am confident that berhinger will make a usable model for much less money[these type usb condensers will be sensitive and give clear results]...
Mar 21, 2010 | Logitech Vantage USB Microphone for...
My Dell Dimension E510 cannot pick up any voice recording from my various mic inputs. I have fiddled with volumes of each respective input (line in, rear mic, mic jack) to no avail, and when I try to use...
This sounds like you have a voice morphing program installed. A morph program is useful for distorting your voice and special effects, but it also takes over your mic controls. Go to the control panel and choose sounds and audio devices, then look for the default device under sound recording and make sure your record device is the same model as your sound device and that it says INPUT. Another problem occurs if you right click your little sound/audio icon on the taskbar and choose open volume control then left click. Do that now and choose, options, then properties. Now on mixer device, choose one that says input. The white window on the bottom of that panel will show you several devices, check mark them all and click ok. Now manually select MIC as your default sound input device and close then try again.
Mar 09, 2010 | Dell Dimension™ E510 PC Desktop
Similar Sound Problem...
Right click on the speaker icon on your task bar, select recording devices, from there you should see your mic inputs and change the levels through the properties button.
Mar 09, 2009 | Acer Aspire 5500 5570-2609 Laptop
How to record sounds using external mic on acer aspire 4315???
go to the sound recorder available at start ---> programs ---> accessories then entertainment ----> sound recorder.
click on edit -----> Audio properties -------> default input device and change it to the external Mic you have connected.
let me know if this helped, good luck :)
Jan 05, 2009 | Acer Aspire 4315 Notebook
Coputer microphone
Go to Control panel>>...>>Sound and audio devices, and ensure that audio input line (mic) is enabled and not muted.
Check on the messenger settings that you have selected the computer mic on audio input.
Jan 01, 2009 | Acer Aspire 5500 5570-2609 Laptop
Cyber acoustic mc 1060
For Vista 32 bit. Go to the driver manager. De-instal/delete the driver in the Sound, Video and Game section. In my case it was RealTek High Def Audio ver 6.0.1.5371. (Select Delete the driver files.) Reboot. Vista will reinstall a driver. In my case it was Microsoft High Def audio ver 6.0.6000.16386. I had the mic plugged in when I rebooted to load the new driver. The Cyber Acoustics ML-1060 now works fine. Hope this helps.
Jan 25, 2008 | Cyber Acoustics CV-1064 Microphone
Computers & Internet Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
