Question about SanDisk ULTRA II 4GB Compact Flash Card Flash
Scan Disk Ultra 4 Computer can't read
I formated the SD in my Nikon D90 and it works fine but when I put in in my laptop's SD slot, it doesn't read the disk, I finally used the USB line that came with the camera to download my pictures. How can I get my PC to read the pics on the SD card?
  • 35 Answers
Your laptop may be dirty or drive name is colliding with other drive letter that is why doesn't show up.
Posted on Dec 28, 2009
You need to format the disk ....
The drives can be read by another computer, so the problem is most likely with OS/drivers on the HP giving the error. The specific drivers required to read each drive format could be missing/corrupt. Formatting shouldn't be performed on a drive that contains data unless backed up (redundantly). It may be possible to recover any lost data using free recovery software. Often a format preserves data, erases only the file directory.
I would try a system restore on the HP. If that fails to correct it install or upgrade format specific drivers (e.g. SD/SDXC drivers). Contact Magellan about the GPS: you may have formatted the device's system partition. It is unlikely your computer had the correct drivers to format that device, and it is likely formatted in an incompatible format (such as NTFS). Does Magellan provide a utility to read the device's memory? The SD card should be salvageable by formatting on another computer using the appropriate formatting utility. (Go to https://www.sdcard.org and navigate to their formatting utility.)
From that site: "If an SDXC memory card is used through the direct SD slot of a computer without SDXC driver installation, the card may not be recognized correctly and a message to prompt formatting may appear. In this case, do not format the SDXC memory card. It may erase the data on the SDXC memory card and format the card for a different file system, making it incompatible with SDXC devices."
Aug 24, 2013 | HP G60-235DX Notebook
My nikon d90 doesn't works when i put the flash sb-600
Could you provide some details? How does it not work? Does the D90 not turn on? Does it take a picture but the flash doesn't go off? What exposure mode(s) are you using?
Apr 02, 2013 | Nikon Speedlight SB-600 TTL Flash
The camera reads memory card error but when I go to the menu to format the card the format catagory is not highlighted and when you page down it skips over the format area. I am using a scan disk mobile...
There are no 16GB SD cards. A card that size is actually an SDHC card (yours actually sounds like a Micro-SDHC card). SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
You really don't need a card this size on a still camera. 1Gb is plenty. If you really need more space, you can carry a spare, like people used to take extra films with them on holiday.
I don't know why the 512Mb card is giving you trouble. This might indicate an actual fault.
Dec 11, 2010 | Canon PowerShot SX20 IS Digital Camera
Xo vision dvd player/receiver 1906 wont read my usb or SD disk.
Consult the manual, it should probably say something about external media.
Check what kind of disk format is supported by your player - some players will recognize an external usb disk (or a usb memory stick) only if it's formatted in FAT32 file system.
Note that if you format the disk on a Windows machine, it will only do it on drives with a relatively small capacity (i think it's up to 32 GigaBytes), but other operating systems (like MAC OS) can perform a FAT32 format even on drives with far greater capacity.
As for the SD disk (did you mean a SD memory card?), see what the manual says about the format type, have the card (disk) formatted in the supported format and see if that works, otherwise you might want to try other brands of SD cards - my friend has an Avia (not Aiwa) dvd player with a usb port and a SD card slot and it simply won't accept some brands or models of SD cards, but will work well with others and it also works well with USB disks and USB memory sticks formatted in FAT32 file system.
That's about all i could suggest, i hope you can get it to work.
regards
3rq8 (Triarcuate)
Sep 15, 2009 | Televison & Video
CoolPix 5000 "OUT OF MEMORY" message that we can't figure out
At 4GB size, your memory card is likely a SDHC card, and not a standard SD card. Although they look the same, there is a difference in formatting. Unfortunately your model camera was designed before the SDHC format came out, and it will not work with your camera. But fortunately standard SD cards are very inexpensive these days, and you should be able to purchase a good 2GB standard card for around $6 with shipping:
http://www.amazon.com/s/ref=nb_ss_e?url=search-alias%3Delectronics&field-keywords=sd+card+2gb&x=23&y=20
Jul 03, 2009 | Nikon Coolpix 5600 Digital Camera
Cannot use the San Disk 4 GB flashdrive
up to 2gb sd cards are sd format 4gb are sdhc format . you camera will not write to sdhc and it is not a good idea to put in your camera .
Jun 03, 2009 | Nikon Coolpix 2200 Digital Camera
Sd card won't click into place on my Nikon d60
Check your SD card, there may be a piece of it missing. Did the same to my camera and looking into the card holder, there was a piece of SD card lying at th bottom! (I used a needle to dislodge it!)
Mar 11, 2009 | Nikon D60 Digital Camera
SanDisk ULTRA II 4GB Compact Flash Card Flash Logo
672 people viewed this question
Top SanDisk Cameras Experts
Henry
Are you a SanDisk Camera Expert? Answer questions, earn points and help others
