Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Whirlpool ghw9150 help !!!!!!!
I have a whirlpool ghw9150 it has a fo2 error and sud. I cleaned out pump, the pump is spinning and pumping water, I also cleaned out hose. I test by putting on rinse/spin cylce, but it will not spin, replace both elec panels. Now what ?
    New Friend:
  • 88 Answers
I would run the drain hose into a bucket or the sink to make sure that it is not your plumbing if it still gives you the code replace the pump just because this pump is putting out water doesn't mean that it is doing it as fast as the machine wants it too. Those pumps are not that reliable and have tricked me a couple of times until I replaced them. good luck.
Posted on Jan 11, 2009
Water will not drain the fo2 code is on which I know it means its clogged but how do I get it unclogged?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display sud and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Feb 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Final spin cycle I get sud error code or f2, water mostly drained but no spin. When I restart the spin cycle just starts to spin then stops, sounds like it drains some more water then makes a small...
Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Why does my whilpool duet washer flash F2: Its holding water and beeping.
First please verify this is a f2 and not a fo2 error
they mean almost the same thing i have it listed below
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Nov 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F2 error code
Hello there
F/02 Long Drain
Nov 19, 2010 | Whirlpool Washing Machines
Fo2 on screen
your pump is jammed clean or, replace
Aug 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GHW9150PW0 Whirlpool Duet washer will not spin F02 and Sud
hi..the reason to this problem is the lid switch.
It might be faulty.
check this out..
thank u..
kindly rate my response..
Jun 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Won't drain properly after trying all troubleshooting options
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 19, 2009 | Whirlpool GHW9150 Front Load Washer
What does the "sud" message mean?
hello fo2 means if the drain time exceeds 8 minutes the water valves are turned off and f/02 flashes. things to check / check the drain hose for any kinks and blockages check the electrical connection to the pump make sure the pump is running / check the drain pump filter make sure its not block if these do not sort the problem replace the pump. to clear the display press pause and cancel to clear good luck
shaun
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Ghw9150p wont spinr
you cleaned out the filter in the pump assambly??? and did you also check inside the throat of the impellar for possible obstruction?its possible that the pump is not pumping(although its on) and not removing water would result in no spin
Dec 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
FO2 AND SUD
hAVE YOU TRIED UNPLUGGING FOR A LONGER PERIOD SO COMPUTER LOSES ITS MEMORY.
Dec 23, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
122 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
