Question about Pioneer VSX-D507S Receiver
Overload problem VSX-D511 gives overload display then shuts off
SOURCE: pioneer vsx-d511 amp error
I've had the same problem for over a month and have yet to find the time to get to it. However, I there may be a fuse on the circuit board that needs to be replace. That's just my guess.
Hope it's the solution.
Posted on Sep 17, 2008
OnlyOneN
  • 86 Answers
SOURCE: vsx-517 keeps going into overload mode!
Try this:
1. Turn off the receiver.
2. Disconnect all the speakers from the back of the receiver.
3. Turn on the receiver. Does it still go into overload? If so, it may need repair.
4. If not, turn the receiver back off and connect one speaker at a time and turn it back on.
Most likely one of your speaker cables is shorted out causing your receiver to get overloaded. Or, one of the speakers is damaged, having the same effect.
Posted on Apr 20, 2009
SOURCE: pioneer vsx-516 6.1 channels
Check the speakers one by one maybe there is one bad or almost damaged
Posted on Jun 06, 2009
lscf150
  • 443 Answers
SOURCE: power overload
That is a good thing, your receiver is going into "protect mode" that means the receiver is shutting down to keep from damaging delicate internal circuitry, it is sensing a speaker bottoming out or some other electrical "short" that could be damaging!
Also could be from over driveing the amp and then it starts to overheat thus going into "protect mode".
If your speakers are "clipping or distorting" turn it down, you are going to ruin your amp. Good luck !
Posted on Jan 06, 2010
Testimonial: "thanks for the solution. but di i need to get a more powerful receiver. how do i know if the receiver and speakers are matching"
  • 11 Answers
SOURCE: Receiver shuts down when setting volume above certain range.
What ohm speakers are you using? this receiver doesnt work very well with speakers that have an ohm rating below 6
Posted on May 17, 2010
Pioneer vsx-d510
Disconnect all the speakers, and then check. Connect the speakers, one by one, and find which one makes it overload. That speaker is faulty. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 15, 2016 | Pioneer Audio/Video Home Theater Remote...
My amplifier when i put it at -50 and more it write overload .....pionner vsx-d511
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Apr 27, 2011 | Pioneer VSX-D511 Receiver
Display shows overload and receiver shuts down
This means that one (or maybe more) of the amplifiers is shorted. Remove all speakers cables and try again. If you get the same message that means that one (or more) amplifiers is fried. To find which and why you will have to open the unit and test the amplifiers.
Jul 31, 2010 | Pioneer VSX-D412 Receiver
Pioneer vsx-516 6.1 channels
Jun 06, 2009 | Pioneer VSX-515 Receiver
Only Left Speakers Work
CHECK THE MENU,,SETTUP ,,NO RECIEVER NEEDEED,,IF NOT CHECK THE RAC JACKS
May 14, 2009 | Pioneer VSX-D511 Receiver
Pioneer vsx-d511 amp error
Sep 08, 2008 | Pioneer VSX-D511 Receiver
VSX D511 No input select
I am getting no sound via my optical cable input. The back of the AMP says that the optical is TV/SAT but i can't change the input to digital it will only go to analog. DVD player is set to Bitstream all dvd options set to DTS, but still no sound going through. Any help would be apprecaited
Jan 29, 2008 | Pioneer VSX-D511 Receiver
No sound
I have the same problem. It worked before and now the sound is gone. If I put it on tuner and turn it up all the way I can hear a little bit
Dec 14, 2007 | Pioneer VSX-D511 Receiver
48 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
