Question about Biostar M7VKQ Motherboard
After post I get a NTLDR fault and the comp.stops
My comp. was crashing at defferant time so I formated the hard drive. After that it would not boot from any disk, and gave the messages in spanish faulta NTLDR
  • 238 Answers
Go to this link.
http://www.tinyempire.com/notes/ntldrismissing.htm
*Your vote is highly appreciated. Thanks in advance.
Posted on Dec 27, 2008
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
I just installed a formatted samsung sv 2044d. when i try to boot up i get a message saying NTLDR is missing. i put in the windows 98 cd and nothing happens. can you tell me what is happening. ...
The drive you installed is formatted (wiped clean). It has no operating system to boot from... tthat's the NTLDR error.Power off the machine with the Win98 CD in the CD drive. Power up the machine and while the machine is POSTing (starting up showing you what's in it) watch for something saying to hit any key to boot from CD and at that point press any key . The machine should then boot from the Win98 CD and start the install
Dec 18, 2010 | Samsung (SP0411N) 40 GB Hard Drive
My computer fails to boot up, it states i am missing NTLDR. can this be downloaded.
It sounds like your computer is trying to load from the network. This is done if you don't have an operating system on local media such as a hard drive.
If you boot from hard drive, either your OS has been corrupted, the drive has crashed, or somehow the boot order has been corrupted.
I suspect your HD has been corrupted, possibly by a virus.
TRY starting in safe mode by hitting F8 several times as you try to boot.
Jan 12, 2010 | Acer Computers & Internet
I receive this message when I'm booting my CISNET computer. NTLDR is compressed Press ctrl+alt+del to restart But when I do so, it comes back to the same page. Somebody please, help me!!!!!
Your system is probably trying to boot from a USB drive. ZT systems for some reason will put USB hard drives ahead of drive 0 in the boot sequence. You can correct this in the BIOS.
Another problem I had with mine is that the BIOS would not pick up the USB drives on a cold boot even though everything went fine with a restart. Cycling the power on the external after boot up solves this problem.
Nov 06, 2009 | ZT Group CISNET A7050 PC Desktop
My comp. was crashing at defferant time & message fault NTLDR
Use the commands
FIXBOOT and
FIXMBR in the
"Repair mode" of Windows XP installation or XP Recovery Console
for vista Recovery Environment or if you have recovery disk/disc you can use it
That error indicates a partition problem, you need to full format your harddisk and removing all partion and do a fresh install. Regarding your Win XP CD, just configure the BIOS to first BOOT to your CDROM
Hope this work for you ^_^
Jun 23, 2009 | Biostar M7VKQ Motherboard
NTLDR is missing
Reference number: CH000465
NTLDR is Missing. Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
You can go to these sites to view solutions (to much to post here) Very easy to understand:
http://www.computerhope.com/issues/ch000465.htm
May 22, 2009 | E-Machines eMachines Desktop PC
Won't boot-up
dear,your operating system has been crashed.
this problem is occured when windows install another drive (beside C)and user accidently formate the hard drive in which you install.
or another method ...........
sometimes boot order has been changed and problem occured.
once you check the boot order from motherboard setting.
you set the BOOT order as:
first boot from hard disk
second boot from floppy
third boot from cd rom.
i think you solve this problem easily.
Apr 11, 2009 | Sony VAIO PCG-K23 Notebook
I just finished my new build. when i power it up it goes through its boot series and gets to a point were it says media test failure, and under that it says exiting intel boot agent. In the bios, the hard...
I doubt it is a virus as you have not indicated doing anything that a virus could have been transmitted to your system. The blue screen of death at boot up time simply means the files that find your operating system are not working properly. Specifically, if you want to Google them they are NTLDR (NT Boot Loader), Boot.ini (tells the system the name and location of your system) NTDETECT.COM (inventories your hardware) and HAL.DLL also monitors hardware. If you could get those three files on a disk-NTLDR, Boot.ini and NTDETECT.COM, then it would boot. They are located in the C:\ drive of any computer with windows but you have to release the hidden files button first...best thing to do is go to the Microsoft Knowledge Base at support.microsoft.com and research your error and those files..you're not the only one this has happened to so there may be a fix in the knowledge base. Besides its good practice to use the Knowledge Base as you can find out about any answer on windows there..good luck. Please rate this solutionl.
Mar 19, 2009 | Computers & Internet
NTLDR missing on changing harddisk connection
put the xp bootable disk in computer and boot from it, choose repair option. it will slove your problem.
Feb 24, 2009 | Microsoft Windows XP Professional With...
NTLDR is missing
Fixes for NTLDR Errors
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD) drives for media. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors. There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  8. Open your computer's case and ensure that the cable that connects the hard drive to the motherboard is firmly in place. If this does not resolve the issue, try replacing the cable. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
  12. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive. Replace the hard drive and then perform a new installation of Windows XP.
Jan 17, 2009 | Computers & Internet
Biostar M7VKQ Motherboard Logo
65 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Alun Cox
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
