Question about Ridgid 25648 Wet/Dry Vacuum
Water isdischarging from the exhaust of my new Ridgid Wet/Dry Vac
I don't have the filter in because I thought that is for dry vacuuming. do I need to have the filter in? Thank you in advance
Robin McCarthy
  • Anonymous Mar 29, 2009
    same problem, water sprays from exhaust of vacuum
  • Anonymous Mar 16, 2014
    how do you wet vac instead of dry vac
  • 368 Answers
Hi Robinm61,
I always have the filter in - - it helps protect the motor.
If you're going to vac liquids, I recommend use of an intermediate trap to stop most of the liquid from getting to my vac (makes clean-up a LOT easier). A cyclone-top (available at Rocker.com, for example) fitting on a 5-gallon pail works great. The liquid is mostly deposited in the 5-gal pail, and doesn't gum-up the guts of your vac. You need another section of hose, but that's another one of those tools that is hard to have too-much of. (Rockler also sells a nice hose as part of it's Vacuum Tool Kit - also at Rockler.com). Photos (courtesy of Rockler.com) follow below.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance,
Jon
Posted on Dec 29, 2008
Ridgid shop vac. use filter or not when vac. water
Just use the sponge filter, if wet dust goes through the blades, it will build up, throw it off balance and the vacuum blades will break loose from the shaft.
Jun 07, 2014 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Can u wash the paper filter on a wet dry vac
You really cannot wash the paper filter. You can blow it out with an air hose if you have access to one, or vacuum it off with another vacuum. If it does get wet you should let it dry outside of the vacuum before you use it again.
May 10, 2014 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
How do you remove the filter from Rigid wet dry vac?
Unscrew the 'tab/nut' at the BOTTOM of the filter and pull off the filter cartridge
Jul 07, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
I did not get a manual with my vac. I am trying to soak up water from a water tank leak and water seems to go right trough the vac and water is coming out the blower hole. the tub is not full.
There is a special sock that you need to buy for it. You can run the paper filter if your in a pinch but after that one time, that's it, that filter is ruined.
The paper filter is for dry vacuuming, the foam filter is for wet vacuuming, You have to have one or the other in place.
There are two ways to snap the cover onto the basket, only one is the right way.
Look to see that the baffle is facing the hose inlet hole.
Apr 22, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Ridgid shop vac is not sucking
Check the intake hose for a blockage. Attach the hose to the exhaust outlet and turn the vacuum on. If no extracted air is blowing out of it the hose is totally clogged up
Apr 10, 2010 | Ridgid 25648 Wet/Dry Vacuum
How do you change the ridgid 9 gallon wet/dry shop vac from a dry to wet vac? Is it simply changing the hose to the back fitting?
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Oct 13, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Ridgid 16.5 gallon motor running with no suction
When you use the shop vac for cleaning up water you must remove the filter.
The filter is for dust particles not for water
I would replace your filter and dump the water out from the shop vac, Also after each time you vacuum up water dump it out of shop vac.
I hope this helped you happy new year!
Jun 30, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Ridgid 25648 Wet/Dry Vacuum Logo
197 people viewed this question
Top Ridgid Vacuums Experts
Dan
Level 1 Expert
ken skalski
Are you a Ridgid Vacuum Expert? Answer questions, earn points and help others
