I need to find the setup codes for an Akai KC01-B2 to operate by a comcast remote. The codes listed in the comcast guide do not work. Also found reference to substitute Samsung remote setup codes and that does not work either. Thanks. Steve
Chiefahles@aol.com
i have just purchased Dish network, however, i have to use both remotes to turn the tv off, change the volume, etc. The remote model is KC01-B2 and the tv model is LCT2785TA
-   i just bought the same set and ran into that with dish..no solution i have found has worked..no codes that i can find with searching internet..the set has great reception but with having to use 2 remotes it seems alot more trouble..any solutions out there is welcomed!-   igottabeme
Feb 18, 2009
-   THAT TV IS **** -   Guest
Jan 26, 2009
-   I have been looking for 2 years for a code that would work...good luck-   mmerrill26
the remote on my akai tv wont turn the tv on i put new batteries in the remote you have to un plug...
(More)
the remote on my akai tv wont turn the tv on i put new batteries in the remote you have to un plug the power cord on the tv and plug it back in then it will work
tv won't turn on. Standby red light is on, then flashes when the stby button is pushed on tv or...
(More)
tv won't turn on. Standby red light is on, then flashes when the stby button is pushed on tv or remote
The green light goes off and the red light may or may not come on. Can plug into another outlet and...
(More)
The green light goes off and the red light may or may not come on. Can plug into another outlet and the TV may come on for a short time. I leave it off for an hour and it comes on again.
My Akai LCD TV lct2785ta seems to have lost HDMI and component input. I switched out components to...
(More)
My Akai LCD TV lct2785ta seems to have lost HDMI and component input. I switched out components to test. Only detects audio input.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
