Question about Frigidaire FRS23H5AS Side by Side Refrigerator
The water dispencer dribbles the water out.
There is a big coil of water line behind and above the crisper. What is this for?
  • Anonymous Apr 06, 2009
  • rabbit60 May 09, 2009
    no water out of dispenser
  • 396 Answers
The water hose coil is to chill the drinking water coming out of the dispenser. If the water drips out it could be a bad solenoid valve since the water dispenser requires power to dispenser water. If the Ice maker is working fine then check the dispenser water solenoid valve.
Posted on Jul 14, 2009
KBFS20ECWH - On delivery, large coil of white tubing behind the two crispers. What is this?
it is most likely the water line. If you are not hooking it up to water, you can remove it.
May 18, 2015 | KitchenAid KBFS20ECWH Architect II...
Icecubes freeze together in a big lump in storage ,will not dispence
Good day,
In almost all cases, that problem is due to the dual water valve located at the bottom rear of the machine. It is not repairable and must be replaced.
Assuming the freezer is staying at it's normal temperature, when the ice maker fills, the water valve described above does not shut off completely after a normal fill, causing water to dribble down the fill chute freezing the cubes together.
Very common problem, and changing the valve is not difficult, and most appliance parts houses carry them.
Aug 29, 2010 | Whirlpool GD2SHGX Refrigerator
Water dribbling out of dispencer whirlpool american fridgefreezer
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
May 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water pooling inside of refrigorator
sounds like the drain line for the defrost cycle is plugged. the water is supposedto end up in a pan under the refrig. the drain probably needs to be defrosted and cleaned.located behind the back panel in the freezer compartment
Jan 21, 2010 | Frigidaire Refrigerators
Plastic Water Line Coiled Inside the Refrigerator
The coiled line is used for chilling the cold water dispenser. Most of the time they are hidden from view,
Mar 16, 2017 | Frigidaire FRS26R4A Side by Side...
Water pressure is extremely low.
Let over line so that one can move the unit w/o disconnecting the water line. Check to se if the preasure going to the unit is low also by disconnecting the line after someone helping you turnas it off and on at the tap valve where it attaches to the house water line. If low there turn off house warter dissemble saddle needle valve and clean .If preasure is good there Replace the water filter on the unit or the one in line. If that doesn't work , then consider replacing the fill valve.
Dec 27, 2008 | Frigidaire FRS23H5AS Side by Side...
I would like to know something.I have a big plastic corel in the back of the crisper pan and I do not know where it go.I have a plastic tube which go from the water valve inlet to the drinking water line...
The coil of plastic tubing behind the crisper is your chilled water reservoir for the water dispenser. They use a coil instead of a tank because it chills the water more quickly and ensures good turnover of the water with less chance of stagnation.
Jul 27, 2008 | Frigidaire Refrigerators
Water line
That coil is the line to the water dispenser, and its purpose is to chill the water before dispensing it. The coil of tubing is better than a tank because it chills quickly, takes less space and doesn't hold stagnant water. It shouldn't have any effect on the icemaker.
Jul 26, 2008 | GALAXY Microsystems 25.4 cu. ft....
Refrigerator doesnt dispen water
Hey it could be freezing in the tank. I just learned that the tank is in the refrigerator behind the crisper drawers under a plastic sleeve (attached w/two screws) . It can get too cold in the tank since there is a vent from the freezer pointing right on the tank that cools it. I defrosted mine by taking a heating pad and wrapping it around the tank for a few hours. I had to leave the crisper out, but oh well. I wish the slow water was my only problem!
Apr 05, 2008 | Amana SXD524VW Side by Side Refrigerator
Water dispensing
they do have a water tank freeze up kit for that exact issue
Feb 14, 2008 | KitchenAid Architect KBFA25ERSS Stainless...
Frigidaire FRS23H5AS Side by Side Refrigerator Logo
198 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
