Question about Frymaster Dean MJH50-SD Deep Fryer
Working on a 50 fryer
Hello
I replaced the board and have to replace the plug that plugs in back of the board. Its the board between the inginators. Now its blowing fuses any help would be appreicated thx, Steve
    Problem Solver:
  • 19 Answers
Ok, follow these direction CAREFULLY!
1. UNPLUG THE CENTER JACK of the pcb, that leads to the computer board! LEAVE THE GROUND WIRE ON THE BOARD!!!
2 REPLACE THE FUSE. Both lights on the pcb should light up, that give you the 12 volt line, AND THE 24 VOLT LINE. If they are both lit, stay lit, and don't blow the fuse, then try plugging in the computer again ENSURING THE GROUND IS GOOD FIRST ON THE COMPUTER/TOUCHPAD!!!!!!!
3 If suddenly the fuse blows when you plug in the grounded keyboard cable back into the printed circuit board, or if one of the two lights on the printed circuit suddenly goes dim when the keyboard is plugged in, YOUR NAME JUST BECAME JESUS AND TODAY IS GOOD FRIDAY! Your computer and touchpad is defective and that is going to cost you BIG MONEY!
Posted on Feb 05, 2009
The fan on the MTI Autofry is not working. Everything else working ok. Safe to use until I can get someone in to look at it?
Should get it looked at, the fan can cause other parts to over heat and cause you more problems than just the fan not working. Try to get it to spin by using a pencil (not your fingers) to turn the blades. These fans often stick from grease build up or when going bad from age. Many have a plug connector on the fan and 4 screws holding the frame in place, fairly easy to replace.
Oct 11, 2014 | AutoFry MTI-5 Countertop Ventless Fryer
I must replace the power cord on my Deep fryer Model FR4017. It gets so hot you can hardly remove it from the wall outlet. I can't find any where to purchase one.
it would seem it drawing to much power from the socket have the wireing to your socket checked out,if the power cord is not damaged,cut the dord back 3 inches from plug and fit new plug
Jul 28, 2011 | Tefal FR4016002 Deep Fryer
My fryer went nuts, it was on and working fine, the beeper went off and I went to check on my food and the unit was off. I unplugged it and plugged it in 4-5 times and nothing, tried it again in the...
Hello;
Thermal safety switches are-common in heating type appliances. If this unit is so protected, a reset should be somewhere on the unit. Another component is a fusible link. This is basically a enclosed fuse that that will blow if a short or excessive current draw is present for an unusual length of time. The reset will kick everything back to normal instantly. The fusible link is generally inside the unit on the power in wire. This link should be replaced with its like. It will require soldering on replacement. This fryer is probably an expensive unit , so the cost of replacement opposed to repair should be weighed. Good Luck to you. Thanks for seeking your answers through Fix-ya. _Ned_
Apr 04, 2011 | Euro-Pro Kitchen Appliances - Others
Hitachi Plasma 50 inch H4011 series just went off and red light blinked 4 times. Won't come back on even after unplugging and waiting 30 seconds and plugging back in per Troubleshooting guide in owner's...
Power supply board is dead.Replaced the power supply board,Ur tv will get the power back.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for replacement.
Feb 21, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Cant get the main flame on
Check the vent hole (plastic plug, not the screw) on the regulator between your gas line & the back of the fryer. If it is plugged, it wont fire & the pilot will go out when t-stat makes.
captrick
Jul 15, 2009 | Imperial IFS40 Deep Fryer
Engine light on miss aceleracion wont go more then 50 mph
At 45 or 50 is the engine RPM normal? If its higher that it should be transmission could be slipping.
If the engine is misfiring at 45 or 50 it could be the spark plugs.
If its just holding back on power it could be catylitic convertor, or possibly fuel filter.
Mar 13, 2009 | 1997 Chevrolet Blazer
Presto Digital ProFry Deep Fryer Reset Switch
Call customer service at 800-877-0441. Have the complete model and series number found on the back of the heating unit.
Jul 23, 2008 | Presto 05460 ProFry Deep Fryer
Replacement power cord
Fryers draw high amps.Goto home depot,lowes and buy a 15amp 125 volt plug.Cut the exsisting plug off the cord,strip the cord down 2 inches you will see 3 wires black,white,green, connect the green wire to the green screw on the plug.connect the other 2 wires on either of the remaining spades(it doesnt matter).let me know
Nov 22, 2007 | Bravetti EP4305FS Deep Fryer
Frymaster Dean MJH50-SD Deep Fryer Logo
106 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Thomas Perkins
Thomas Perkins
Paul Carew
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
