Question about Parrot 3200 Ls Color Handsfree Bluetooth Car Kit
3200 LS installed in '07 Chev Sub-Parrot Won't Power Off
Parrot was installed in the above vehicle. Harness mates Parrot with factory radio. Ignition sense turns Parrot on and off with the key. Recently, Parrot remained on after vehicle ignition was turned off. Parrot staying on has since drained battery in vehicle several times. Professional wiring harness purchased from car audio on-line retailer in Texas. Parrot has performed flawlessly until now. Any ideas? Thanks in advance.
  • jwormet Jan 04, 2009
    The Parrot seems to have corrected itself on its own. The Parrot now turns on and off with the key as before. I appreciate your solution and will keep this in mind should the Parrot fall into a bad habit. Thanks again. Happy New Year!
  • Anonymous Mar 27, 2014
    already install in vehicle and I don't have the password
Try switching the red and orange wires. one is constant and one is switched. you can try by just reversing them at the inline fuses. hope this helps.
Posted on Jan 03, 2009
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
I installed an mki9200 into a 2007 ford expedition but it seems to not get any power at all I am using a plug and play harness i don't know why it's not getting power
Not all vehicles have a ignition supply at the radio as they use the canbus system to turn things off and on. You will need a multi meter to check if there is power on the correct wires and you my need to pick up the ignition from the fuse box. Parrot web site has details of the accredited engineers in your area.
Jan 01, 2012 | Parrot SA Parrot MKi9200 Advanced Color...
How to turn on parrot 3200
The kit should automatically switch on with the cars ignition, if not you will need to make sure there is power on the red wire and the orange wire.
Dec 31, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
No one can hear me/sound is very bad Parrot 3200
it sounds like the microphone is trapped or faulty, get the engineer back to sort it out or follow the microphone wire to see if is trapped behind the trim going down the side of the winscreen.
Dan
Feb 16, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Parrot Glicches
sometime, it my be in relation with the install.
Just a simple question, did you install it by yourself? if yes, did you connect the mute cable of the kit? cause if you disconnect it and try to make working the kit and see if the mute is working may be the explanation. signal treatment.
(except trouble of the kit), after a while plugging on a 12v dc only can be the explanation. Do you have the message "good bye" on the display when you switch off the ignition key? If not, that could also be due to the fuses inverted to the vehicle between the 12 dc and the 12 ignition. Then you just have to inverse fuses.
Feb 11, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Parrot 3200 Ls doesn't cut out radio
problem is the 220 has an amplefier in boot the controls the radio, unless proper leads that connect there are used to interupt the radio when call happens it just some thing u have to put up with or buy the lead, try autoleads.com or look on parrot web site for the right leads
Mar 30, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Parrot to GMC Sierra setup.
here,
When I did this truck I had to go to the amp under the center console. Good luck
#510564: 2007 GMC SIERRA C1500 2DR TRUCK
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery ORANGE (+) RADIO HARNESS
Accesory (CLASS 2 DATA) (+) RADIO HARNESS
THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE. RUN A WIRE TO THE FUSEBOX FOR SWITCHED POWER. THE ACCESSORY TURN-ON AND AMPLIFIER TURN-ON ARE CONTROLLED BY THE CLASS 2 SERIAL NETWORK.
Ground BLACK/WHITE (-) RADIO HARNESS
Illumination GRAY (+) RADIO HARNESS
Dimmer BROWN (+) RADIO HARNESS
Amp Turn On PINK (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (+) LIGHT GREEN
RF Speaker (-) DARK GREEN
LR Speaker (+) BROWN
LR Speaker (-) YELLOW
RR Speaker (+) DARK BLUE
RR Speaker (-) LIGHT BLUE
Amp Location UNDER CENTER CONSOLE
Steering Cntrls OPTIONAL
THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTAR® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT.
Speed Cntrl OPTIONAL
Radio Security YES
Jan 08, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Parrot 3200 Ls Color Handsfree Bluetooth Car Kit Logo
406 people viewed this question
Top Parrot Cell Phones Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
