Question about Dometic Rooftop RV Air Conditioner
Intermittin furnace operation
New battery, converter, full tank of gas, checked all the fuses. the furnace goes on,workes for awile then stops working. the fan cycles but there is no fire from the ignighter as if there is no gas. turn the thermastate on and off and it works for awhile again. this problem seems to only happen at night when it is colder. this is on a dou system air and furnace in a 2003 allegro
  • 3 more comments
  • tlodolce Dec 27, 2008
    the ignighter trysto start the propane but it is like there is none there to ignight.i had the heat pump on then switched it to furnace and it worked for two cycles then stoped ignighting again.
    the gas line looks ok. i put soapy water on every thing and there were no leaks.
    the control valve makes sence but the outside temp hsa risen and the furnace runs fine. at one point this morning i smelled propane and the ignighter was working and there was no ignition. the fan was running blowing cold air. now it seems fine. is it possible the control valve is getting too cold to work or could it be the thermistate not working properly?
    could the control get too cold too work at night or could the thermastate be operating incorrectly?
    im going to replace the valve and see if that is the problem. ill let you know tomorrow,if i freez tonight and get into it again with the wife ill let you know thqt too.
  • 700 Answers
What you need to do is make sure that you are delivering enough pressure to the gas
Posted on Dec 27, 2008
  • Todd Born
    Todd Born Dec 27, 2008
    first thing to do is make sure that you tanks are full that the pressure regulator is operating properly. whenever the propane boils off it can cool the tank causing the pessure to drop inside of the tank then the furnace won't fire properly and lock out, sometimes the regulators stick but i don't think that is your case here. wrap the tank so that the ambient temperature does't effect the operation. Good Luck.
    Genius:
  • 1,239 Answers
Hi
Try turning the breaker off for 5 minutes and see if this resets the system.
if not you may have a defective Control board and you will need to have a HANDS on tech to diagnose these parts to be sure! They will have the diagnose equipment !
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
  • ABHISHEK.C
    ABHISHEK.C Dec 27, 2008
    yes there are chances if thermostator doesnt work properly
    Sergeant:
    Champion:
  • 338 Answers
You have one of 2 problems. either the ignitor is going bad to where it doesnt always get hot enought to lite the gas or the flame sensor is bad.. but since you said its not igniting then you are looking at 99.9 % chance of it being the itgnitor.
  • 3,037 Answers
Hello tlodolce
Have you checked the gas line, perhaps it is freezing or is getting old and needs to be replaced. Let me know what you find when you look into this.
bestdarngood
  • 1,861 Answers
It looks like you have a bad flat surface igniter.
    Top Expert:
  • Dometic Master
  • 82,313 Answers
U will need to replace the control valve (or it's voltage supply transformer) for the gas to the burners, it is defective, u said the igniter comes on, this means the solenoid in the gas valve has been sent a signal to open but doesn't do so. Also check the transformer for the control valve voltage supply, if it is defective then the the solenoid has no power, but in most cases it is the valve and not the transformer.
  • Marvin
    Marvin Dec 27, 2008
    The valve is sticking, this is still a valve issue, replace it and u will see the problem goes away.
1968 Camaro convertible fuel gage not indicating. Fuses are good. Cannot find the problem.
Pull the connector apart at the gas tank, and ground the fuel level sending wire (on the vehicle side of the connector). Turn key to on. If gauge now goes to full, the gauge is good. The sender unit in the gas tank is bad.
Oct 26, 2013 | Cars & Trucks
Domestic Dm2652 will not work on AC without DC power is this correct. We have been camping for a week plugged into 30amp power. Refrigerator worked fine then check light came on and refrigerator...
This is an RV frig correct? It SHOULD work either/or. AC or DC. If your plugged into AC then often the frig will work with that alone. DC is for when you have no AC so you can power your appliances of the battery. Maybe you have a converter (AC to DC which most RV's do) that somehow is not getting the DC to the frig.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 11, 2013 | Dometic RM2652 Refrigerator
We are trying to buy a home which once had oil heat and it has part full basement and part crawlspace, IF the old tank is still on the property (converted to gas long ago) unfortunately it's in the...
I have not seen an home heating fuel oil tank buried before. Most such oil tanks were standing on legs and outside of the house. If the old oil furnace was where the new gas furnace is, look for the old fuel line hanging loose. It might tell you where the tank was or is.
Jul 29, 2011 | Malco Products Malco STKM Ductwork Tool...
Fuel guage & water guage are not working properly the fuel guage reads ful then will go to empty after you drive it for awile - the water guage only goes up to a quater
The gas tank sending unit has a float on it to register the amount of gas in the tank. The float is probably faulty which will cause erratic readings and is a fairly common issue with some GM units. Replacement of the sending unit should resolve that issue. As far as the coolant temperature gauge, it could be a faulty temperature sending unit or a thermostat that is stuck open or someone removed the thermostat. This will cause the engine to never reach operating temperature which in turn makes the engine run rich and can clog cat. converters and destroy some sensors.
May 08, 2010 | 2001 Chevrolet Venture
Blower stays on after heat goes off
when the room thermostat is satisfied it stops the heat by stopping power to the sequencer or contactor which is in series with the heating element/s...the TEMPERATURE OPERATED FAN SWITCH then takes over the blower until the heaters cool
Oct 02, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Had to have my car jumped off when the battery when bad and the gas gauge stopped working. checked fuses and all are good.
Take the battery to Auto Zone for a check. As for the gas gage you would have to drop the gas take and replace the unit, a tough job not wore the hassle. Just keep the tank full.
Jun 27, 2009 | 2005 Nissan Maxima
1996 Blazer will not start
Have you checked fuel pressure? Have you checked the distributor cap, they are known for going bad.
May 03, 2009 | 1996 Chevrolet Blazer
Furnace won't kick on
Downstream of your fan discharge there is a little plastic assy. most likely that will have a pickup tube and a piece of vinyl or latex tubing attached. First check to make sure that the pick up tube and/or tubing does not have a restriction. If it is clean use an ohm meter to read resistance across the switch to verify it is operating.
Nov 15, 2008 | Intertherm Heating & Cooling
Gas burner doesn't work
Gas burners serve as the primary source of heat in a variety of home appliances: water heaters, gas dryers, and gas cooktops and ovens, and-of course-- furnaces and boilers. When the burner fails, most gas appliances are designed to stop working altogether to prevent a gas leak. As a rule, it's best to have gas burner problems fixed by your gas utility service person or a qualified heating technician, but there are a few steps you can take to avoid paying for a service call.
Jan 18, 2006 | Coleman 2 Burner Compact Gas 425F499G...
Dometic Rooftop RV Air Conditioner Logo
26 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Jay Finke
Jay Finke
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
