Question about Car Audio & Video
Lose power when volume is over 20
On my KD-G240, when I turn the volume above 20 it shuts off until I turn it back down. I need more volume.
  • Anonymous Mar 01, 2009
    lose power when volume is over 20"
  • c_sig2 May 26, 2009
    Mine also shuts down around 21. Bass Boost causes it to shut down much sooner.
The radio is more than likely shutting off due to low voltage. Check your ground for the radio or you may need a new battery especially if you are running amplifiers.
Posted on Jan 06, 2010
    Problem Solver:
  • 6 Answers
The speaker wires might be crossed.
Posted on Dec 29, 2008
I forgot the password to my Kurio interactive. How do I reset it?
Password Was Forgotten ΒΆ If you forget your Kurio log-in password, you will not be able to get past the lock screen. The only solution is to perform a factory reset. Performing a factory reset will erase everything on the Kurio and return it to exactly how it was when you took it out of the box. To perform a factory reset, unplug the Kurio and turn it off by holding the power button for 5 seconds until the screen displays "Power Off, Shutting Down..." Once the device is off, press and hold the volume down button and power button at the same time until the screen lights up with "KD Interactive." Release the power button, but continue to hold the volume down button until the "DROIDBOOT" screen appears. Then, navigate to the "RECOVERY" option and select it by pressing the power button. This will prompt a new menu, from here select "Wipe Data / Factory Reset." Your Kurio will go through a long restart phase and then welcome you to your new Kurio
Jan 13, 2017 | Tablets & eReaders
Shows 99% won't open and can't shut down
You can first try doing what's called doing a Soft Reset. It's the first and preferred method to try as you don't lose any files or settings. Hold the power button until the Nook turns itself off. In most cases that will be twenty seconds or more. Then turn the power back on by holding the power button down for about two seconds. Hopefully this will allow you to complete a normal boot process. The second and more dramatic way to get a working Nook back is what's called doing a Hard Reset. This process will put your Nook back to "Just Out of the Box" mode. You will lose any files and settings stored internally inside the Nook itself. The good part in all this is it won't touch anything stored externally on your external SD Cards. To do a Hard Reset Turn the NOOK off completely. Hold the Power button and Home (n) buttons. The device will turn on. Continue to hold both buttons until the device shuts off once again (~15-20 seconds). Turn the device on normally. It will prompt for a factory reset. Press the Home button twice to confirm. ------- The important part in the above is to be sure you start the Nook via holding down both the power button and the Home (n) buttons at the very same time and keep them both pressed down until the Nook turns itself off.
Mar 07, 2015 | Nook HD+
How do i reset my samsung galaxy 3 if it wont come on?
1. If your Samsung Galaxy S II is frozen, Shut the POWER OFF, take the battery out and put it back again.
2. Hold the Volume Down button
3. Briefly Press and release the Power button
4. A menu will then appears that let you allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Quickly Press and release the Power button
7. Select Volume Up for YES and Volume Down for NO
If the above procedures doesn't work. try this another method:
1. Turn the POWER OFF, pull the battery out and put it back again.
2. Simultaneously press the Volume Up, Home and Power button
3. If the Samsung Symbol appears, release the Power button
4. A Boot Menu will then show, Use the volume up/down to choose and home to select.
May 30, 2014 | Samsung Galaxy S GTI9000 Smartphone
Repeated off and on
speaks are hooked up wrong or speakers are blowin.
Apr 01, 2010 | JVC KD-SX980 CD Player
Stuck in demo mode. how do i change it?
Hello jayme84,
To cancel "DEMO" mode on the JVC:
Enter the PSM (personal settings mode) and turn DEMO off.
1) Press and hold "SEL" until the display changes.
2) Use the left/right rocker switch until "DEMO ON" is displayed.
3) Turn the volume knob to select "DEMO OFF".
4) Press "SEL" to exit.
Hope this helps.
Apr 28, 2009 | Car Audio & Video
Don't know how to set the clock on my jvc kd-g240/kd-g140 car stereo
press and hold the sel button until the menu pops up then scroll through til you see clock settings.
Dec 20, 2008 | JVC KD-G140 Car CD Player
Tower intermittently loses power
i think you have a problem in you power supply sir try changing it or try separating your monitors source of power.
Dec 10, 2008 | Computers & Internet
Stero stuck on demo mode, cant remember how to turn it off. it is a jvc kd-g240
You will find the demo mode in the settings menu. It's options will be on and off and are reset to default each time power is disconnected from the unit.
1st, hold the "SEL" button
2nd, use the left/right arrows to select option "Demo"
3rd, turn the volume knob until "OFF" is displayed
Then, lastly, press the "SEL" key once more.
Here is a link to the pdf document for the instruction manual off the JVC website: http://books.jvcservice.com/Download/717497409/GET0485-001A.pdf
Aug 10, 2008 | JVC Car Audio & Video
you need a new power supply !!!!
Jul 05, 2008 | HP Pavilion 754n PC Desktop
Demo problem
Here is how to shut off the demo:
1) Press and hold the SEL button for several second until DEMO appears on the display. Release your finger from the SEL button.
2) Using the Volume control knob, turn left or right to turn on/off DEMO.
3) Press and release the SEL button to accept.
Setting the clock:
1) Press and hold the SEL button for several seconds until the DEMO shows on the display.
2) Use the right search arrow in the 4-way button just above the SEL to get to the clock hour. Do not use the up or down key.
3) Turn the volume control knob to select the hour.
4) press the right arrow once more to get to the clock minute.
5) Turn the volume control knob to select the minute.
6) When finish, press and release the SEL to accept.
Good luck
Sep 02, 2007 | JVC KD-G230 CD Player
Car Audio & Video Logo
152 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
