Question about Kenmore 23822 Top Load Washer
Kenmore 70 Series top load washer makes noise during spin cycle
When you open the top, the tub looks slightly off center (you can pull it back to center)and now each load makes an off balance noise when it starts to spin in all cycles. Every thing else works fine, but I am afraid to keep using it.
  • 21 Answers
There are three springs under your machine. two that look the same....one on each side of the tub. and one in the back of the tub. it is common on machines that are a bit older for the rear spring to wear itself through the metal at the bottom. if this is the case, it is best to get a new spring and just drill another small hole next to the old one. you might be able to get by with using the old spring for a bit longer....just drill another hole.
Posted on Dec 29, 2008
I have a Kenmore 70 series top load washer which will not go into the spin cycle. It is making a loud clicking noise
lean the washer back and look between the motor and trans,there is a coupler in the middle that most likey broke
May 04, 2010 | Kenmore Washing Machines
I have a kenmore 70 make ratchet noise ,will not
Probably bad lid switch. Your ratchet noise is normal during the wash cycle.
Mar 24, 2009 | Maytag PAV2300 Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cycle
Most washer tubs are suspended by heavy rubber O-rings. These do fail with age so that the tub is not being held centered anymore. I suspect one of them has failed or come off during a severely unbalanced load.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
Kenmore 70 series
I am assuming there is no noise coming from the machine, if not check the lid switch. open the lid and look for a small slot in the top of the washer. With the washer set to run, press down on the slot with a screwdriver or something (make sure everything is clear from the tub) see if there is a clicking sound when you push down. If the machine starts you need a depressor piece on the door. if there is no clicking sound you may need something else. lets start with the simplest, like the door switch and go from there.
Nov 02, 2007 | Kenmore 22422 Top Load Washer
Kenmore 70 Series Washer
You probably have a bad lid switch.
May 21, 2007 | Kenmore 15864/15862 Top Load Washer
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 23822 Top Load Washer Logo
157 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
