Question about Toshiba Satellite P105-S6084 Notebook
Wabling sound with playing music with CD
When playing music from the CD or from "My Music". The sound is wabling in and out.
  • tpclary Dec 27, 2008
    That worked. Thank you very much!
    Tim
  • 238 Answers
Go to this link:
http://www.free-codecs.com/XP_Codec_Pack_download.htm
Download it. When a box appears, Click Run button.
Best regards
Posted on Dec 27, 2008
How to delete unwanted apps
Long press on any app untill they start wabling. Then press the x on the app you want to delete
Feb 04, 2014 | Apple iPad Air
Front hub wabling do i chage and what step do i use to repair and do i change the front axle while its apart
Definitely replace the wheel bearing/hub. I drive a lot of miles and usually am doing this repair on a car with over 100K miles. Since the axles are relatively inexpensive, I have been replacing them at the same time. You will already have done most of the work anyhow to get the hub replaced.
Mar 08, 2011 | 1992 Oldsmobile Cutlass Ciera
I just received a GPX JM250S Karaoke Party Machine. I have not tried a actual Karaoke CD yet. I plugged ipod in. Problem is- music is playing, then when I speak into mic music stops playing. There is no...
The music to sing along with apparently MUST come from a disk played on the unit. It appears that the external audio jacks are just to use the unit as either a boombox or to drive a larger sound system. You will have to convert your IPOD music into a Karaoke compatible CD to be able to sing along with it... They probably detect MIC input and mute any incoming signals from the RCA jack inputs,
Dec 26, 2010 | GPX Karaoke Party Machine
When I Play Music through Winamp/Media Player it
That is unusual - pressing in case should not effect play - not like a tape drive would.
Are you playing from CD or Hard-drive?
If Cd - try copy music to hard-drive and see how it plays - if ok - then something may be rubbing on CD in CD-Player? But that would give read errors. Have to remove CD Player and clean it.
Jan 29, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fan is wabling on a 1997 jeep, the belt is still on for now, we can't start the jeep up because it hit the schroud.
Now its a couple of things that may be wrong...1 is your waterpump may be bad, and the shaft is wobbling back and forth...2. it could be your fan clutch...or 3. it just maybe the fan blade itself..sometimes they wear out, because they are made up of plastic...however you can easliy see that, and move it around..and make sure all the bolts are tight..
So. check the waterpump, by tring to shake the fan up and down and side to side, and see if the shaft move, then its the waterpump...the clutch really wont give you too much play, it just wont spin as fast, with the engine running, Or the blade..basically it will look like its fallen off....
Jan 19, 2010 | 1997 Jeep Cherokee
Pulley wabling after water pump has been replaced
re tighten the bolts or that pump was faulty take it back to the place that put it on and tell them to do it right this time!!!
Jan 14, 2010 | 1990 Lexus LS 400
Casette to disc
to convert music from cassett to disk u need to connect the cassett player headphone jack / line out jack to ur PC/laptop mike / line in jack....then play the music and record it in a software(Nero Sound editor etc)
then once that's done save it as mp3 file on to ut PC and trf it to ur cd/disk....u can just copy it as mp3 or create a music cd using Nero...from the mp3 file
the difference is if u just copy the mp3 on to the cd then only a mp3 player/mp3 music system deck can play it... if it's created as a music cd then any cd player can play it....just like any music cd that u buy in the mkt...
a 700 mb disk can hold almost 7 to 10 hrs of music in mp3 format....
but a music disk can hold only 80 mins of music
Jan 03, 2010 | Dell (3996D) Sound Card
CD changer won't play CDs.
time to clean the lens...get a good CD lens cleaning kit
Aug 12, 2009 | Bose Lifestyle 25 System
Toshiba Satellite P105-S6084 Notebook Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
