Question about Toshiba Satellite A100-S8111TD Notebook
Unable to install home
I am a new user trying to install home , the unit ing will only go to a screen say" wait . I tried disconnecting to see if the unit would pick up the installation once plugged in a second time and the same message came up
  • chris dowell May 11, 2010
    are you saying that it will get to the screen that has the windows logo and in little letters says wait ?
    Genius:
  • Toshiba Master
  • 1,102 Answers
You need to reinstall the windows
boot with the cd in drive then hit enter when ask to boot from cd
somehow you did'nt finish installing properly
Posted on Jan 16, 2009
Unable to connect to roku please try again later.. is the message on the tv screen
I would disconnect the power going to the Roku Stick, wait at least a minute or so, reconnect the stick to the power supply. If this does not work contract customer support at this link: Contact Support
Jan 09, 2015 | Roku Streaming Stick
Coby kyros mid 7022 is stuck on lock scteen, how do I get around this? Also goes into hibernate for seemingly no reason. Very new android user, no clue what I'm doing
Here is the instruction on how to do the factory data reset when a customer locks the system and lost his security password/pattern. This instruction works for MID7016 and MID7022. An end user must follow each step precisely. Otherwise, he/she will not access to the system menu mode.
  • Connect the AC power adapter.
  • Turn on the system.
  • Press and hold the power button until the popup window of "Device options" appears on the screen.
  • Select the "Power off" option from the popup window. You will see another popup window of "Power off".
  • Select the "OK" option. The unit will turn off.
  • While holding down the "BACK" button, press and hold the "POWER" button until Coby logo appears on the screen.
  • Release both buttons once you see Coby logo on the screen and wait for a while. The Coby logo screen will change to Android logo.
  • Wait about 15 seconds after you see Android logo. (Do not press any button while waiting. If you do, you will not be able to access to the system menu.)
  • Press the "BACK" button once. The system menu screen will appear on the screen.
  • Choose the "wipe data/factory reset" by using the "HOME" and "MENU" buttons. (The "MENU" button will allow you to browse down through the option list, while the "HOME" button will allow you to browse up through the list.)
  • Press the "BACK" button once you select the "wipe data/factory reset" option. The confirmation message will appear on the screen with YES or NO option.
  • Choose the "Yes - delete all user data" option by using the "HOME" and "MENU" buttons.
  • Press the "BACK" button once the "Yes - delete all user data" option is selected. It will perform the factory data reset. Wait until it is done. Once it is done, the main system menu will appear on the screen again, and the "reboot system now" option will be selected as a default. If not, you will need to select the "reboot system now" option from the list.
  • Press the "BACK" button to reboot the system. The system will reboot with the initial factory data setting. All user data will be lost.
Give the reboot at least 5 minutes. Do not assume the unit has frozen
Sep 02, 2011 | Coby Kyros Tablet
I want to change owners so I want to reset Kyros 8024. How do I do that?
Following the instructions below will cause losing all user data, including the third party installed applications.
This action will even delete the "Getting started" video file, which will cause the "Cannot find video" error when a user is trying to play the video clip using the "Getting started" application. With knowing this fact, the user can follow the instructions below.
  • Turn off the unit.
  • Take a microSD card out of the slot. (Empty the microSD card slot.)
  • Press and hold down the power button for a few seconds while pressing and holding down the "Home" (Silver Push Button) button. (Both "Power" and "Home" buttons must be pressed down until he see the phrase "upgrade system activated" in the middle of the screen.
  • Release both buttons once the phrase "upgrade system activated" appears on the screen.
  • Wait until it reboots. You will see the following sentences on the left top corner of the screen: Can not find any update image. Press MENU/KEY_VOLUMEUP key to init SD card, Press BACK/KEY_VOLUMEDOWN key to cancel.
  • Press the "VOLUME UP" key. The volume up key is located at the left side of the unit and the button is closer to the built-in camera than the volume down button.
  • Wait until it finishes making a partition and shut down the system automatically.
  • Once the unit is turned off, your system will be reset to the factory settings. Thus, your previous data are lost at this point.
Jul 20, 2011 | Coby Kyros 716829701508 Tablet PC
My rooftop coleman AC main wires are burnt
Either the power supply wiring is too long - i.e. a 150 foot extension cord used to power it with poor plug blades?
Or the capacitor is shot, (more likely)
Disconnect Power supply, wait 5 minutes, try to start the unit WITH POWER DISCONNECTED. (will drain capacitor). Short capacitor with well insulated screwdriver, get the new capacitor replaced on ebay or local electrical supply or appliance store (not home depot)
Aug 30, 2009 | Coleman Mach III Air Conditioner
Leapster 2 asking to choose usa or canada but unable to select
Try calibrating the screen:
(1) Insert a cartridge, turn the unit on and wait for the sign-in screen to appear.(2) Hold down the Home, Hint and B buttons simultaneously.(3) When the screen changes, press the A button.(4) Using the Stylus, touch the center of the targets.
Aug 06, 2009 | Leapster Learning System
TomTom Go 630 malfunction
re install/repair the software
May 04, 2009 | Tomtom Go 630 GPS Receiver
I phone downgading
Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.
Alternative Method:
Step 1. Connect iphone to USB then listen to the sound when it connect and disconnect.
Step 2. Hold the home and power buttons until hear the disconnect sound then release power button.
Step 3. Wait until you hear another sound then release home button.try this
Jul 22, 2008 | Apple iPhone Smartphone
Intellisync problem
First, uninstall all software, Palm Desktop and Intellisync. Move the user files to the desktop. Reinstall all software. Try a sync. If this doesn't work, move the user files back to the proper location. Then uninstall all software, Palm Desktop and Intellisync. Now do a hard reset of palm unit. Try sync-ing.
May 18, 2007 | Palm Treo 650 Handheld
Toshiba Satellite A100-S8111TD Notebook Logo
16 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
