Is there a battery in T8000C
We had a power failure too but the faceplate seems to be dead and wondering if there is a battery in this obsolete model. thanks
    Problem Solver:
  • 13 Answers
No batteries in this one it uses a cap. to maintain the program. Did you remove the stat to chech for batteries? If so check the alignment of the six tiny pins on the sub base as they are very easy to bend when re installing the stat. If you did'nt.
Check for power at the furnace. If neither one is the case, I have replaced many of this stat with a Honeywell Focus Pro 6000 stat
Posted on Jan 11, 2009
Deh-p390mp not working
You might be able to find a faceplate on eBay.
Jan 14, 2018 | Pioneer DEH-P3500 CD Player
What does message :a #alarm 199: "batteries disconnected" means, and how to resolve this problem? thank's!
The charger board has failure. Model already obsolete. Propose to buy a new unit
Aug 23, 2013 | Powerware 9120 UPS System
HI I HAVE SEVERAL LITEON POWER SUPPLYS MODEL NO. PA-1201-1 THAT HAVE WENT DEAD. IT SEEM THAT THIS POWER SUPPLY FAILS ALOT. I WAS WONDERING IF THERE WAS SOME WAY I COULD FIX THE UNITS THAT I HAVE. DO YOU...
Most power supplies have a fuse in them. That is most likely the problem. Otherwise, if you open them up, you can see which capacitor has gone bad, 'cause they will have obviously ruptured.
May 12, 2011 | Lite On Computers & Internet
Powers off randomly
a lot of different causes ( priority from most probable to least ):
- CPU overheat.
- Power supply failure ( battery or charger).
- Power Jack failure.
- Motherboard malfunction.
- RAM corruption.
May 13, 2010 | HP Pavilion dv5000t Notebook
T8000c honeywell thermostat is blank
This unit doesn't require a battery. It runs off the 24v from the unit. Check that your transformer is still working. Check the control board for 24v pwr. and main pwr. Check your breaker to the unit. It could be as simple as a bad stat too. You can check by using a jumper wire and jumping across from r term. to y term.
Apr 10, 2009 | LG Art Cool LA121CNP wall/window Air...
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Apr 08, 2009 | Sentry Fireproof Safe
Day and time won't stay set on Honeywell T8000C
try replacing the batteries if there are any,sometimes the t-stat is hard wired in and there are no batteries
Nov 15, 2008 | Heating & Cooling
No power to Kenwood KDC-4019 faceplate
It sounds like the stereo does not have the "ACC" voltage. It could have blown a fuse. The "ACC" voltage goes to the red wire on the harness and you get that voltage turned on only when the ignition is turned on in the car.
The symptom of the disc ejecting and nothing else works is an indication that only the constant voltage for the yellow wire is connected. Check the voltage on the red wire with the car turned on, if you have that 12 volts at the red wire, then you need the radio serviced.
It is not very likely that the faceplate has gone bad. Just because the radio will not turn on is not an indication that the faceplate is bad. It could be a voltage regulator in the radio or a circuit trace is blown, or almost anything else. There are many reasons that the radio would have the problems you describe and it can only be found out for certain by troubleshooting the radio on a test bench with the proper tools. If you have a multimeter and a power supply I can guide you thru troubleshooting the radio and even email you the service manual in PDF format if you would like to take a crack at it yourself.
Let me know how you want to proceed.
Dave
Oct 25, 2008 | Kenwood KDC-4019 CD Player
Battery backup?
which model do you have ? the 8000/8001 or 8011 the set is different depending on your type of heating system. This model has a memory chip not a battery that saves your settings. So you could be looking at replacing the unit.
Jan 05, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
213 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
