Question about Alessi (AL3847305500) Espresso Machine & Coffee Maker
Major explosion I was brewing espresso as usual and the entire pot exploded hit the wall leaving coffee grinds all over the kitchen walls and ceiling with a big dent in the wall. Luckily no one was in the kitchen at that moment. The heat was low, I had checked in on it two seconds before it blew. Contacted alessi but they said they did not sell the bottom part of the pot any longer. I noticed a tiny piece of metal jutting out from the portion where the latch snaps in. What to do? It is a six cupper.
2 Suggested Answers
SOURCE: Need gasket for Alessi 6 cup stove top espresso coffee maker
I have a Elevation Espresso Coffee Maker it worked fine until today when it stopped heating the water. Any help would be great.
Regards
frank
Posted on May 31, 2009
I have 2 of these pots, neither of which will brew coffee. The water does not go up through the coffee grounds
Please be careful! Don't use them.
Mine did the same, and it exploded, destroyed my kitchen, my stove and my hearing!
Charlotte Furst, Sweden
Sep 02, 2010 | Vev Vigano Vespress Inox 3-Cup
Cuisinart Grind and Brew will not emply all the water
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Aug 18, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Sometimes coffee maker overflows
Do you grind your beans at home before brewing or is it ground from the store. If you grind just before brewing check her grind and compare it with yours.
Also check to see if she levels the coffee in the basket. Usually when a pot overflows it is because of the grind or the way the coffee sits in the basket.
May 21, 2009 | Bunn NHB Coffee Maker
Cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
My cuisinart coffee maker just recently started not using all the water I've poured into the reserve. Up 'til today it was leaving the last two cups in the reserve, but today, out of the six cups I poured...
This is a real problem with these coffee makers, and there's not much that can be done. However, there is a work around: before brewing, just hit the button to brew 1-4 cups. It'll still brew a whole pot, it'll use all the water, the coffee will taste no different, and you can still program it however you'd like. Cheers!
Sep 21, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Product is not completely brewing all of the water - it takes 3 times to brew a full pot of coffee. very frustrating.
Having the same problem. It's a thermostat issue. The product seems to have three. Trying to figure out which one is causing the problem.
Aug 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Water/grinds spillover in coffee basket
Pot must be inserted with the handle pointing straight out the front so it will hit the valve that is below the basket designed for the "rob a cup" while brewing feature.
Calvin
Aug 13, 2008 | Coleman 5008C700 Camping Coffee Maker Free
EXPLODING SAECO VIA VENETO
I think your machine is overheated, try to replace the thermostat on the boiler.
May 25, 2007 | Saeco VIA Veneto Espresso & Coffee Maker
Alessi (AL3847305500) Espresso Machine & Coffee Maker Logo
62 people viewed this question
Top Alessi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Terry
Terry
Are you an Alessi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
