Could this possibly be a problem with the defrost timer? I completely
defrosted the freezer and cleened all the coils real good. There is no ice build on the coils behind the panel in the freezer.
Can you locate the defrost timer? It is usually located in the center right next to the t-stat looks like a plastic housing. There is a flat blade screw driver recessed area that advances the timer. It only turns one way so if it don't go one way it will go the other real easy. Advance till it clicks that is defrost mode. Now wait 30 min. and does it advance till it goes back into cooling? That is how you can test the timer to see if it is advancing. ken
yes, the fan is running.
Thanks alot. I'll test it when I get home and hopefully replace it on Monday. Sounds like the defrost timer could be the problem. I appreciate your help.
What is the problem with the timer - can they be opened up and properly fixed?
I will go and look at my daughter's freezer later (Zanussi ZEBF249W). I did see the timer box and a boss on the side wher I presume the screw is. Is it worth trying to open it up? Is the heater reliable?
Is the fan running?
