Hp 2133 wont boot
Got new hp 2133 mini note when i turned it on for first time it would nt load the windows vista but a screen comes up system32 scanning files it then goes through files restarts the notebook and starts same phase again can youhelp of course vista is pre loaded on these.
  • alan_flurrie Dec 27, 2008
    windows is ment to be pre loaded on the note book but cant even get it to install there is no disc with this product!!
  • 139 Answers
Since we dont actually know where this problem comes from,
i advise u to format ur system and reinstall windows so d problem be solved.
try starting yr system in save mode by pressing f8 key during booting, and choosing the option save mode.
Posted on Dec 27, 2008
What should i do to boot my hp mini 2133
Does it seem like it booted all the way except the screen is black? Do you hear fans running, the hard drive spinning?
What is a hard reset? Exactly what did you do?
Apr 25, 2012 | HP 2133-1 Mini-Note PC
PC boot problem
Hi Jimmy,
Does the PC load windows fully before restarting?
If it does load and then restart,then it may be a problem on the part of your hard drive.
Run a full scan of the PC with an updated anti-virus to rid off any viral attacks.Make sure the anti-virus is always updated for better performance.
If it does not load windows,try this:-
  • Restart the PC.
  • Before it loads the first page,press Ctrl,Alt and Del.This is a soft boot sequence.
  • The booting leads you to the Bios setup page.
  • Under file save changes and exit[though no changes made].
  • If problem not solved repeat the procedure again.
If the problem persists,you may have to reinstall the operating system again.
Hope this helps.Thanks!
Nov 05, 2011 | HP 2133-1 Mini-Note PC
Time to run CHKDSK/F if you can or restore your OS. It has been caused by a registry error and there are a number of ways that can happen, from removing power before shut dow to, if Win7/Vista, trying to hack a way in without a password.
Jan 27, 2011 | HP MINI 2133 NOTEBOOK PC - 1.2GHZ PC...
Ntfs is missing
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows Vista startup disks or the Windows Vista CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows Vista installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows Vista CD, and drive is the drive where you installed Windows Vista .
  7. Remove the Windows Vista CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
  9. rate me 4 thumbs up please
Jan 10, 2011 | Microsoft Windows Vista Home Premium with...
Hi I have an HP 2133 mini notebook. It was working fine up until yesterday. Whenever I switch it on it gets as far as the Windows (XP) loading screen, then a blue screen flashes (too quick for me to...
That is known as "The Blue Screen of Death" and is a real problem.
It is usually caused by an update problem, cut off half way through updating, or a corrupt boot ini file.
As the notenook is trying to boot up, press F8, its timing is a bit tricky and it will take several attempts, a "DOS" menu will appear. Choose "Safe Mode"
The notebook will have the ability to try and replace the faulty file. When it has loaded, Back Up your Data! then click to close it down.
See if it boots normally, if it does, you are lucky! Now is the time to run CHKDSK/F to try and iron out any hard drive problems.
Hope that helps.
Nov 14, 2010 | HP Mini 1000 Netbook
How to Reset HP Mini 1000 Laptop BIOS?
Clear Bios Password for HP Mini - Compaq Mini:
HP Mini 1000, HP Mini 110, Compaq Mini 110C, Compaq Mini 110, HP 2230S, HP Mini 1120LA, HP Mini 1151NR, Compaq 700....If you see this screen on boot:Enter CURRENT Password: [_______________]
We can help you Remove Password, right now !!!
You just enter 3 random passwords one by one and see if you get a similar [System Halted] message with 10 chars Error Code. (e.g CNUXXXXXXX, 2MCXXXXXXX....)
Jul 16, 2009 | HP Mini 1000 Netbook
HP 2133 mini-note PC webcam stopped working!! Help!! PLEASE!! :((
In your control panel you can select system properties and then device manager.
If the webcam had a yellow ! then you will need to install or update the drivers. Drivers can be found under the support section at the manufactures website.
(easy way to system properties is windows key + break key)
Apr 16, 2009 | HP 2133 Notebook PC
Open Questions:
Computers & Internet Logo
847 people viewed this question
David Payne
David Payne
