Question about GE DBSR453EBWW Electric Dryer
Ge dryer wont start had problems with switch before
    Problem Solver:
  • 10 Answers
More than likely if you say you had problems with the switch before than you might have a bad starting switch, but check to see if the start switch is getting power from the timer if is getting power from the timer check the "safety fuse" located in the heater area. This "safety fuse" is designed to cut power off to the motor if the dryer overheats above a "safe" level (On dryers made after January 1, 1996 in accordance with U.L. and C.P.S.C. standards). If the "safety-fuse" is good than check the "start" circut of the motor.If there IS POWER (115 volts) going into the "start" circut of the motor ,but the motor won't "run" than the motor needs to be replaced.
Plus check to see if the timer hasn't "shorted out" as well.
Posted on Sep 13, 2009
Wont start when button is pushed
could be a bad door switch, wen door switch goes bad it wont start the dryer thinks the door is still open.
Dec 17, 2012 | GE GTDP300EMWS Dryer
Ge gas dryer wont start
Check the motor kill switch by the motor next to the wall
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 07, 2012 | GE Dryers
Have GE DWSR405 Dryer - Turn switch and doesn't come on. Is this a switch problem
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
May 30, 2011 | GE Dryers
My ge electric dryer model number fse747ges1 wont start. i replaced the start switch. still wont start.
Check the door switch. If it is bad, loose, or faulty, the machine won't start. You can test the switch with an ohmmeter. They are a common problem causer, especially in a no-start senario
May 06, 2010 | Dryers
My dryer wont start at all...
Did you check the door switch. If it is open (not making contact) the machine will not run. Could be the motor start/run switch which could be stuck with lint (clean it) or worn out ( replace the motor).
Sep 18, 2009 | GE DSXH47GGWW Dryer
G.E. electric dryer will not run, when you turn the switch to start it only hums. What could be the problem, it is only 3 years old. Thank you
First of all check your door switch, make sure it is operational.If the door switch checks good, the start switch could be faulty, in newer dryers the start switch is built into the timer in older dryers your start switch may be seperate, if you have to push on the timer dial to start the dryer, its built into the timer.
Check any other safteys that may be stuck open.Double check anyway. If it wont do anything, I would say its the door switch or the start switch.
Aug 27, 2009 | GE Dryers
GE electric dryer wont start
The first thing I would do is check your door switch. When the door closes it hits a switch to tell the machine it's safe to start.
Hope this helps!?
Jun 19, 2009 | GE DBL333EBCC 5.7 cu. ft. Electric Dryer
My ge dryer wont start
Hi thanks for the question. You could have a problem with the door switch, On that dryer theres a belt break switch.check that
Dec 16, 2008 | GE DWXR483EBCC Electric Dryer
Tub wont and start switch wont hold
Hi! msbjs
Sound like this could be a motor problem. Is there a lot of lint inside the dryer and around the motor?
InMrFixIt
Oct 30, 2008 | GE DBSR453EBWW Electric Dryer
Ge dryer wont stay running
start switch is bad,it is stuck inside,get the model number inside dryer door or on top panel,call local appliance parts store to get new part,only a few bucs,replace and you should be allright,let me know-mike
Jun 15, 2008 | GE DBSR453EBWW Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
107 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
vince
Marc Taylor
Are you a GE Dryer Expert? Answer questions, earn points and help others
