Question about Maxent MX-42XM11 Television
No picture When turned on unit just clicks a once or twice, no picture or sound, front green power light comes on but nothing else. was working fine, turned off and could not turn back on. cycled main power button in back with no change.
  • Anonymous Jan 16, 2009
    i have the same problem but since my tv has removable panles in the back, i just remove them and then recycle the main power buton, the picture gose on in blue screen again and carefully replace the the panels after recycle, this is my 27in i dont know if your panels can be removed. if it is one solid panel, leave it alone and take it to a repair shop
SOURCE: TV gettin power...but no pic and no sound
I am Having the same problem as PScott. I will open my TV this weekend wil a friend who is a electrical technitian. We hope that ther is any schematics inside the TV though..
Posted on Mar 07, 2008
  • 3 Answers
SOURCE: maxent MX-42VM11 won't turn on
I had the identical problem (clicking sounds, no picture, but just the sound). I took Richdogg's advice above, but it didn't work out for me (lost money on the purchase of the part) - no offense Richdogg as I'm sure that was the problem in your TV. I later found out that the problem was with the Y-Sustain (also called Y-Main) Board. As with most parts in this TV, this is also made by Samsung and used in Maxent, Magnavox and a number of other 42" TVs. The part number is LJ 92-01256A (using LJ 41-02668A also give you the same part number). Hope others will find this useful.
- Kamal
Posted on Apr 11, 2008
ramon49
  • 111 Answers
SOURCE: 50" maxent green light no picture
WWW. maxentusa.com. Sounds like your power supply board is bad or you have a shorted board somewhere. Maxent is still in business and they are pretty good at customer service.
phone 1-888-373-4368.
Posted on Mar 07, 2009
  • 23 Answers
SOURCE: I have a 3 year old Maxent MX-42VM11 plasma tv with no pic/sound
swollen capasitors, replaceing will cost $500, so best to get another one, 42'' samsung will sell for about $800. the pn42a450
once a plasma has a problem, fixing it or not, more problems will occure, trust me, i am the flat pannel guru.
Posted on May 02, 2009
sonicboomele
  • 1557 Answers
SOURCE: No picture/no sound.
there is a problem with the heat curcuits leading to the tube
send it into a pro
Posted on May 15, 2010
Rca Tv wont power on HD61W66
Sounds like the capacitors on the deflection power board CP150, CP120 and CP114 they are famous for failing in all versions of the ITC222 chassis. You can get the repair kit by that same name from www.tvrepairworld.com the kit has the caps and the cd with repair instructions
May 18, 2012 | RCA HD61W66 61" Projection HDTV
Red light flashing, no picture/sound!!!!
HI, this unit has 3 main fuse links on the main board that may be blown. the fuse links should be check before you move further into the diagnosis stage. once you have checked the fuses and they are still in a working state, this will confirm a power supply board failure. this board provides and regulates the current flow and distribution of it throughout the entire unit. If the fuses are fine and the power supply board is damaged, the green light will come on briefly then, the main control will notice that the power supply is not functioning properly. Once the main control board senses an abnormal current, it will shut down the TV rendering the red light warning. The list of fuses to check are below. Remember, if they are fine and working, the issue will be the power supply board itself and, it will need to be replaced.
FUSE CHECK LIST--
3A 12v- fuse----(242208600623)
SM 3A 125v-fuse----(242208600657)
500 MA-fuse-----(242208611092)
PART NUMBER FOR POWER SUPPLY BOARD
(996500036816)
Please rate and god bless:)
Apr 13, 2009 | Philips 42PF9631D 42 in. Plasma Television
NO PICTURE, NO SOUND On My Plasma TV.
Should have been 3300 UF 10V caps that were bad? Shouls have been replaced with 3300UF 18V. 50V is huge. If it was replaced with a 50 the polarity may be wrong or the cap it too big to be seated property. Sometimes the caps just dry out and even a normal looking one will be the culprit of no OSD. Are you getting an LED fault code blinking? That should be a red led. Do you hear the relay clicking.? When you replaced the caps did you charge them? Just plugging in the set without trying to power it on for about 20-30 mins. I may be able to help you
gysgt2u1@yahoo
Mar 05, 2009 | Philips 50MF231D 50 in. Plasma Television
No picture or sound
Hello. There are a few causes for this. I will list acouple solutions for you.
1. Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
2. Make sure the TV is on the correct seting. i.e. Video 1, Video 2, etc.
3. If option 1 does not work call Sony because the video out chip has blown or come unsoldered.
I hope this helps. Good luck to you.
Sep 13, 2008 | Sony Playstation 3 (PS3) Console
Power on no picture
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Aug 19, 2008 | Akai LCT2716 27 in. LCD Television
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
RCA TV Will Not Power On - Powered Off Suddenly
Theses sets had 2 problems pip mod or most of the time Flyback Transfomer bad.
Jul 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Subwoofer not powering up
I could either be the sub or the main unit. The main unit actually sends a signal to the sub to turn it on so if that circuit is bad in the main unit the sub is never going to come on. I've also seen bad cables (You'd be amazed at how stubborn people can be when din connectors don't cooperate).
Sep 10, 2006 | JVC TH-M505 System
Televison & Video Logo
176 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
