Question about NetGear WGR614 Wireless Router
Im with virgin they are hopeless tried to connect my daughters laptop to my wireless router asked virgin took me into netgear web page and made me alter things mine then stopped working i then went back in and reversed everything i am now working but its not the same doesnt look the same on virgin and keeps logging me out of msn
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    What type of connection do you have with this provider? Is PPPOE used?
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Aug 16, 2009
My Dell XPS doesn't connect properly to my Netgear DGN1000SP router
It my be the amount of devices connected? Try shutting down all but one, the laptop. It's possible you have a defective wireless device? If you connect the Laptop via a Ethernet Cable does it connect and work well? Turn off every thing, unplug remove battery from everything. install battery in the ISP modem , if applicable, plug in, allow self test, plug in Netgear, allow self test, plug in Laptop only, connect to wireless, enter security key. post results. Have you done any firmware upgrades on the Netgear? Does this apply to your device: http://kb.netgear.com/app/answers/detail/a_id/18898/~/dgn1000-firmware-version-1.1.00.41-(for-worldwide-users-only)
May 14, 2013 | Dell XPS Computers & Internet
Trying to conect laptop to virgin media with netgear wireless adaptor the signal is strong but could not conect windows say to contact provider provider gave me number to enter 192.168.0.1 now i am lost
The router is not connected to the internet via Virgin media.
Your computer is connected only to the router wirelessly, that is why it says contact your internet supplier on how to connect the router successfully!
Jan 12, 2011 | NetGear WGR614 Wireless Router
I want to get my WGR614 wireless router working with my i phone3g
for you to be able to connect your iphone to the router you need to connect to the SSID or network name of your router and it will ask you for a Network Key, If you dont know the network key you can access the router page and check the wireless settings for the Network Key
Thanks for using Fixya
Jul 30, 2010 | NetGear WGR614 Wireless Router
Hi im trying to connect my new wireless router netgear mod.dg834g v5 with virgin supplier.should it not be a simple connection from the existing modem into the n/gear or i didnt get a internet conn.so use...
Ya this is some what correct. You might be lacking on some system network setting. Just you have to do is make sharing of your network without any complecated authorised or password sharing. Thats it.
May 31, 2010 | NetGear DG834G Router
Laptop can not connect to netgear wireless router
I would suggest using the network setup wizard, in the control panel. Best option is to copy the data to a pen drive and transfer to your daughters laptop.
May 30, 2010 | NetGear WGR614 Wireless Router
I forgot my password to be able to connect my daughters laptop to netgear as i just had the laptop cleaned up due to a virus
If you can plug the laptop into the router via Ethernet which will bypass the wireless security and then log into the routers web configuration page and find the wep/wpa key.
Hope this helps
Oct 17, 2009 | NetGear WGT624 Wireless Router
WGR614V9 virgin router drops connection
I should first thank you for the clear details you have given about your connection .I will try best to help you.The firmware version can be older so check the firmware version and upgrade it. Try to open the netgear smart wizard page in your wired computer by going to www.routerlogin.com or 192.168.1.1.The USERNAME:ADMIN and PASSWORD:PASSWORD(default).We can troubleshoot this only if this page is opened.In the netgear page at left side blue screen under maintenance->router status check the firmare version if its older version then click on router upgrade and check for the new version from internet(click on check tab) and upgrade the firmware.Hope this solves your problem if not try with different laptop wirelessly connect if you are able to connect then its the computer problem contact your computer vendor.Rate me if i have helped you that will motivate me.Thank you.Have a good day.
Sep 24, 2009 | NetGear WGT624 Wireless Router
TP-LINK TL-WR541G/TL-WR542G cannot get started
make sure the wifi switch in the laptop is on or not
Jan 05, 2009 | NetGear WGR614 Wireless Router
Signal Problems
try to bring another laptop to the location where you are having problem and see if the other laptop will have the same problem. if thats the case the problem is with the router. You can try upgrading the router's firmware or change the wireless channel
Apr 21, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
