Question about U.S. Divers Avalon Purge Mask
Avalon Mask strap assembly broke
I have a new strap assembly for my Avalon mask but can't figure out how to get the mask clip off of the mask. I'm afraid I may break the mask if I apply too much presure. Any suggestions?
    Scholar:
  • 63 Answers
Try to spread apart the clip using two sets of small nosed pliars on each side of the clip, therefore not applying any pressure to the mask. Best wishes with a wonderful sport!
Posted on Jan 05, 2009
Where the strap connects to the mask broke on my snorkel mask. Can this be replaced. I only wore the mask one time.
Yes. You should be able to find a replacement strap online or at your local sporting goods store, for quite cheap.
Apr 05, 2011 | OMNI Deep See Omni Silicone Mask
Can the mask strap that has for clips on each side, the strap and adjusters be purchased
Yes they can, you need to locate your nearest scuba shop that stocks Body Glove, they will be able to order them for you. Hope that helps.
Oct 24, 2010 | Body Glove Brilliant Recreational Diving...
Pin broke holding strap in place. replacement or substitution?
Standard repair part available at any USD SCUBA dealer. OR contact the company for a replacement part. Don't be such a brute in future.
Pulling hard on the strap adjustment will NOT make the mask fit better. It actually makes things worse.
Aug 13, 2010 | U.S. Divers Seal Diving Mask
Part that holds strap to the mask is broken.
It depends on the brand and model of Mask. Divers Direct sell some replacement buckles for Tusa masks. Tusa Liberator buckles and Tusa M10 buckles as well as a few for other models. Scubastore.com lists Mares Mask Buckles.
Probably the easiest is to go online to any of the major search engines and search for the brand name of your mask plus the words "mask buckles" and you should find a supplier (if there is one).
If not, you can try this fix. Not sure if it will work - kinda depends on what part of the mask buckle is broken. Good luck.
Jun 24, 2010 | U.S. Divers Cozumel Mask
My seadive strap clip broke. How can i get it fixed?
That's a tough question. It looks like the strap is integrated with the mask skirt. I would try going back to where I bought the mask and see what kind of parts they can get. Depending on how it is attached and the nature of the damage, you may be able to replace the clip or failing that, the mask skirt.
If that doesn't work, you can try contacting the maker. The trademark is registered to E.B Industries in Paramount, CA http://www.manta.com/c/mmld23k/e-b-industries-inc
Good luck.
Good luck.
Jun 10, 2010 | Monarch Seadive Truvu Rayblockerhd...
The swivel clip on my scubamax mask broke. Where can I get a replacement piece?
Got to a store that sells Scubamax masks. They should have spares.
Failing that, contact the company and ask them to send you the part.
Should be little or no cost. Kind of a warranty thing. Don't pull the straps so tight next time ;' >
Jun 02, 2010 | Scubamax Masks Spider Eye Mask Masks wout...
The clasp to connect mask to snorkle broke. can I purchase the small clasp?
In short, no. But just do as many other do and use a short rubber band. Lay the middle of the band across the inside of the strap, and then pass the snorkel tube through the two resulting loops either side of the strap.
May 21, 2010 | Speedo Condor Mask Snorkel Set
How to choose a scuba mask
"The shape of the scuba mask and the silicone skirt on the mask must conform to the shape of your face to provide you with a comfortable fit. Ensuring the silicone skirt is a high-grade, flexible silicone can help to ensure the scuba mask conforms to the shape of your face and the long life of your scuba mask. Some people are allergic to different types of rubber, if you have an allergy to rubber, be sure to choose a silicone scuba mask because silicone is hypoallergenic. Always talk to your scuba diving gear retailer about the alternatives available to you. When trying on scuba masks you will notice the different shapes of the nose pockets. The nose pocket protects and cushions your nose, helps to keep your scuba mask from fogging during a dive and helps you to maintain equalization. Ensure the size and shape of your nose pocket is comfortable; not too tight and not too large. This will improve not only the comfort of your scuba mask, but your ability to purge your mask efficiently. There are increasingly different styles of scuba mask straps on the market. You may like the factory issue strap on your scuba mask or you may want to purchase a separate strap. Scuba mask straps are available in a single strap or a double strap design. The single strap should wrap around the centre of the back of your head. The benefit of the double strap is that you can position the top strap on the upper part of your head and the bottom strap on the lower part of your head to offer extra stability and comfort. Most scuba mask straps are rubber or silicone and fasten with a post-hole belt enclosure. Newer scuba masks offer a slide-lock type enclosure, which allows you to adjust the scuba mask quickly and easily when wearing the mask. Scuba masks are constantly improving. If you wear prescription glasses or contact lenses on a daily basis you can purchase a scuba mask without having to wear your glasses or contact lenses under your mask. Many manufacturers will create custom scuba masks which include your prescription in the front lens. A good sign you have chosen the right scuba mask for your face is when the mask stays on your face comfortably without using the straps to hold it in place. You should try this simple test with each scuba mask you try on for the first time: See our choices for scuba masks 1. Place the scuba mask over your eyes and mouth ensuring the mask is in the correct position. 2. Take a quick, light breath in through your nose and immediately start to breathe through your mouth as if you are scuba diving. This will create a slight suction between the scuba mask and your face. The scuba mask should stay on your face. If you must push the scuba mask against your face, or inhale repeatedly to help the mask stay on your face, the mask is not a good fit. 3. Keep the scuba mask on your face for approximately one minute. This will help you to determine how tight the seal is and how comfortable the mask is on your face. 4. Exhale gently through your nose to release the seal on your scuba mask and remove the mask from your face. There should be no mark on your face from the scuba mask. If there is a red line around your face from the seal of the mask, the seal was too tight or the mask is not the proper size for your face. Try the test a second time. If you still have a red mark on your face after you remove the mask, you need to continue your search for a scuba mask. Remember, a good scuba mask is one that's comfortable, doesn't leak and is easy to use."
Dec 01, 2008 | Vision Mares Pure Mask
U.S. Divers Avalon Purge Mask Logo
423 people viewed this question
Top U.S. Divers Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
ray gallant
Bill Boyd
Are you an U.S. Divers Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
