Question about Nintendo DS Lite Console
Problem with a supercard
Down loaded nds gamees from web. managed to put to trabsflash via usb port. windows will not recognise the down load? neither will the DS lite
Are you using a flash cart? I'm assuming you are. You've not provided much info, but have you put the operating system on the transflash card? You need to visit the flash cart manufacturer's website and download the os, follow the instructions they provide to put it on your transflash.
Posted on Dec 27, 2008
I have a R4i V1.4.1 (gold colour/black label) and I can't seem to get it to work. I have copied loads of downleads to try without success. If just state Alex Rider Stormbreaker THQ when I load, then...
Hey Russell,
It sounds like you updated your Nintendo DSi console and your R4i card is no longer working. The best thing to do is to buy a card that works with the newest 1.4.3 firmware. Cards that do this include:
Check out R4DSRevolutionCards.com (not a shop) for information about R4 cards / R4i cards in general, they explain the differences between loads of different cards. My favourite is the Supercard DSTWO though. I recommend DSCardWorld.com as a shop but NDS-Gear.com apparently has some good reviews too.
Aug 10, 2011 | THQ Alex Rider: StormBreaker for DS
Tip
How to jailbreak your ps3 (backup and play homebrew games)
How to jailbreak PS3(PlayStation 3)? chips available at www.ndsireland.webs.com
Follow the complete step by step guide posted below to jailbreak your PlayStation 3 to enable you to create backups of original discs.
Pre-requisites are as follows:
* Any (FAT or SLIM) PlayStation 3 Console running firmware 3.41 or above.
* PS Jailbreak USB Modchip.
* An external USB drive formatted to FAT32 with the "Backup Manager" file on it which you can download from here.
* Original disc of any PS3 game which you want to backup.
Step 1: Power off your console and make sure that there isn't any disc in the Blu-ray drive.
For the SLIM Model: Remove the power chord before plugging in the USB.
For the FAT model: Turn off the power switch found at the backside of the console.
Step 2: Now insert the USB based PS Jailbreak Modchip to any USB port of your choice on the console. Once the USB is in place, Power ON the console and immediately press the "Eject" button. There should now be two LEDs turned-on on the USB as the console is loading.
If the LED light on the USB turns green, you are good to go as the PS Jailbreak has been successfully loaded.
If the LED turns red, then it means that the PS Jailbreak Modchip didn't load successfully. This usually happens when the Power and Eject button sequence wasn't performed properly. Start from Step 1 again if you end up having the red light.
Step 3: Once the console has finished booting up with the PS Jailbreak Modchip, plug-in the external USB storage device which has the "Backup Manager" setup to the console's USB port.
Step 4: Now navigate to the "Game Menu" and select the option "Install Package Files" and then select "manager.pkg" file. This will basically install the "Backup Manager" application that you download earlier to your hard drive.
Step 5: When the "manager.pkg" file is done loading, scroll all the way down in the "Game Menu" and there you should see a new application called "Backup Manager", run it.
Step 6: Now we're in the Backup Manager app. Insert the game in the console's optical drive which you want to backup. Press "O" and you will be asked where to make the backup, on the internal HDD or the external storage source connected via USB. This process is further elaborated by the following screenshots.
Step 7: In order to play a game via the backup you just made, insert any original game disc into your console (To emulate the loading process), run "Backup Manager" in the "Game Menu". Press "X" to play the selected backup game.
Step 8: Now you will be taken back to the main menu. In the "Game Menu" you will see the game which you have backed up. Now you can select the game, and run it without having the disc in the console's drive.
Oh and you must make sure that the PS Jailbreak USB Modchip is connected to your console at all the times when you are playing the games via backups.
Disclaimer: This guide is for educational purposes only. I'm not responsible for any loss of important data or malfunctioning of your Game Console.
on Oct 06, 2010 | Sony Playstation 3 (PS3) Console
Plug & Play recognises Dub E-100 attached and device manager lists it however continually get error 39 driver missing or corrupt. Drivers loaded directly from CD supplied / also download version...
Hi.Try to install again your windows xp.need fresh windows xp installation because same of your operating system software device corrupted and missing.to recognizes that USB network adapter gadget.
Jun 09, 2011 | D-Link DUB-E100 (DBDUBE100) USB Network...
USB port is not working
first check whether ur os is windows 98 or xp if it is 98 then for any device u need usb driver. if it is xp ten its ok. check the device manager whether usb driver is loaded in ur system. right click on my computer icon not the shortcut icon. then select mange then select the device manager from the option available on left hand side of the window. then check the usb section whether any driover is loaded into ur system. if not then install from ur motherboard cd. if that also does not work them u need a replace of the usb port.
tell me u have a error message window cannot recognise the usb. if this appears then it need a replacement of the port. thank u
Feb 25, 2010 | ASUS P5PE-VM Motherboard
Unable to read sd card
Hi grecko, Hope this helps, I've just bought a 4gb memory card for my daughter's ds so she can fit 58-60 games instead of 28 on a 2gb memory card and have downloaded and put a file onto the memory card before loading games onto it.
Supercard DS one have a site where you can download the files you need and it gives help. Guess it's the same if using an R4 supercard too but I bought an R4 card for partner preloaded with software.
May 14, 2009 | Nintendo DS Lite Console
I want to find a step by step guide to putting games on Micro cards and playing on ds
1. Download the system file in .zip format from the manufacturers web site (or find the CD that came with the card)
1a. Click on the .zip file to open up the contents.
2. Plug in the memory card to the USB port on the computer using the adaptor provided.
3. Copy the contents of the newly opened window (or the files from the CD) on to the memory card.
4. Search the internet and find the games you want (they will be .zip files too so double click on them once they're on your computer and you'll see what's in them). If you don't know where to find them just search Google for "NDS ROMS"
5. Copy the files that end .nds to the memory card attached to the USB port.
6. Unplug the memory card from the PC.
7. Plug the memory card back into the game adaptor.
8. Plug the game adaptor into the NDS.
9. Switch on the NDS and enjoy.
Jan 26, 2009 | Nintendo DS Lite Console
Supercard
problem solved.updated new software.works fine now
Sep 17, 2008 | Nintendo DS Lite Console
DS Card reade download
Did you buy a PASSKEY or SUPERKEY too? You are not very clear.
Contact me at agent222@free.fr
Aug 10, 2008 | Nintendo DS Lite Console
Free nds downloads...
it mite not work but on the folder, try to extract all (there is a buton) a new folder appears, highlight them all (ctrl +a) then with ctl still pressed down, drag them to the removable disk with ur games in it
shud work cus it dus for me.
GREEBS ROCK WOOOOOOOOOOOOOOOOOOO
Mar 26, 2008 | Televison & Video
Scanner & Software function - cD does not load fully
When trying to reconnect the device, don't expect Windows' plug and play to help you.
To uninstall the hardware itself, locate on your CD "x:\util\ccc\uninstall_l1.bat". Disconnect USB cable as it says before continuing. When finished, restart your computer.
REinsert the CD, and choose "Add a device"... that'll ask you to connect the USB cable so it can configure the scanner portion and not only the printer portion.
Oct 30, 2007 | HP Officejet Pro L7680 All-In-One Printer
Nintendo DS Lite Console Logo
55 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
