Question about Likom Futura LD7 17" CRT Monitor
Losing Screen Display on Boot Up
Hi! I've had the monitor for 3 years and now always experience a picture cut-out while the PC is booting. The boot sequence is shown at the start but after 30 secs or so the monitor powers down and goes to standby (orange light) and can not be brought back without tuurning the power button off then on again. Once back on, it stays on without any problem until the pc powers down during long idle periods and the same thing occurs without fail every time.
I would be grateful for your advice. Thanks.
Geoff
2 Suggested Answers
  • 49 Answers
SOURCE: my monitor does not boot anymore the only thing it
check video card or power source ... often it's the power source, some capacitors failed
Posted on Jan 02, 2010
Compaq Presario CQ56-115DX shows a blank screen on boot, but runs perfect on external display
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 24, 2012 | Compaq Presario CQ56-115DX Laptop
My msi gx600 laptop experience black screen problem, wont boot up. what should i do?
Well the first step is to try and boot from your recovery disc. If you still have no monitor output then plug in an external monitor. This should invoke your os into using a generic display driver for the os. If you get some visual output then its just your driver for your laptop display thats corrupt and needs re-installing. If not then the chances are you fried your graphics chipset.
I dont think that an Msi GX600 will have a replacable MMX2 or 3 card so the chipset is more likely hard fixed to the motherboard. Basically you need a new laptop.
Mar 16, 2010 | MSI TurboBook GX600, Overclocked 15.4" ACV...
Turns on fan runs but no info to the monitor doesnt seem to boot
If the Monitor is displaying no infomation at all, your display signal from the PC to the monitor has failed.
1: Check the cable between the monitor and PC
2: If you are using onboard graphics then that display port is faulty.
3: If you are using a graphics card then remove it and try the onboard graphics.
4: Your monitor maybe faulty aswell so test it on another computer to be safe.
Its more likely to be option 2
Jan 15, 2010 | Gateway GT5220 PC Desktop
My pc does not boot and no display on the monitor. my pc hung and i shut it down. upon turning on, it does not boot anymore and no display on monitor
Open your Notebook which is very tough to explain as they are different for different models. Anyway you can always consult your manual regarding that. Locate your RAM and remove it. And insert it again if another slot is available insert there first and check.
Usually RAM undetection problem gives no diaplay on monitor and the system doesn't boot.
Good luck.
Jan 03, 2010 | Gateway Computers & Internet
I have this monitor hooked to my PC ATI 7500 graphics card with a DVI cable. When the PC initially boots up, the monitor display is blank - it does not display the boot-up messages until the MS Windows...
This is normal. Your monitor has a VGA hook in for regular definition. What it is doing, the monitor always by default looks for the VGA hook first. On my desktop it does the same thing until it finds a signal on the DVI.
Dec 29, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
3 year old HP laptop. First screen with diagonal
Hi:
I am not 100% sure, but you could have a problem with the onboard video on your laptop. If you hook up an external monitor to your laptop, and boot to the external screen, this will tell you if your laptop screen is ok, if the video displays the same on a external monitor. To get to the external display, some laptops require that you toggle to them, such as holding down the function key and hitting F8, but your model may differ.
Nov 10, 2009 | HP Computers & Internet
Blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Sep 03, 2009 | HP w1907 LCD Monitor
Cannot display anything at all,sounds it is working but, cannot dispaly boot screen and rest???
Try connecting an external monitor to the Dell Latitude D820. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor has no display, then your problem is with either the video card or motherboard located inside your laptop.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 07, 2008 | Dell Latitude D820 Notebook
Dell C400 will not boot using LCD screen when cold
I have seen this problem before, after booting to the external monitor go into the display settings and try setting the resolution to 1024 X 768 and the color settng to 16 bit or preferably 32 bit. If you can do this, then shut down the laptop remove the external monitor and try booting on the LCD display. BPCS
Nov 17, 2007 | Dell Latitude C400 Notebook
Likom Futura LD7 17" CRT Monitor Logo
50 people viewed this question
Top Likom Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Likom Computer and Internet Expert? Answer questions, earn points and help others
