Question about Zyxel Prestige 334 Router
Configuring nbg334w router
Av completed step 1 an 2 but step 3 wont happen cuz it keeps saying web page not availible,my i.p address on laptop is set to auto etc, now thru my laptop it picks up the wireless router with full bars.....it just wont let me connect straight to internet , i have ethernet cable runnin from modem straight to router then another ethernet going to laptop. plz help
  • 50 Answers
To configure the wireless router it is recommended the it is connected directly to router.
Please follow these steps to fix your issue
1. Reset the router using reset button on the back of the NBG334W router
2. Configure or change the laptop ehternet adaptor setting to "Obtain IP address automatically.
3 connect laptop and router using ethernet cable. check the ip address using ipconfig command in DOS prompt. If IP address is 0.0.0.0 or 169.X..X..X run command
ipconfig /release
ipconfig/ renew
best way restart the computer
4. if you still have issue in getting ip address double check ethernet cable and try reseting the router again.
5. Still problem persist install new firmware on the router. you can download router firmware from
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906164737&ModelIndexflags=0,420070320142921
Please vote if this information is helpful in resolving your issue
Posted on Dec 31, 2008
How can I configure my router so all of my laptops can connect to the internet? Also, do I need to make any changes to my laptops configuration?
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
3676-001.png 3676-002.png Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Linksys Wireless-G Broadband Router
No internet on PC when cables going through router
Hello there,
You have to start from the beginning and my solution would be:
1) Remove any connections(also don't forget to turn of wifi on your laptop) to router and except the power cord. With the unit powered ON locate the reset pinhole on the back of router.
2) Press and hold reset button for at least 15 secs. then release, wait for 20-30 secs. before the router can completely rebooted.
3) Configure your Computer IP address to “Obtain an IP address automatically” .
4) Connect internet cable to router on port labeled "WAN". Connect PC to any LAN ports available.
5) Now lets configure wireless router. Open any browser you have (IE, Firefox, Chrome, Safari, etc.). On the address bar type: "192.168.1.1" (without quotes). Default username: admin ; default password: admin click "OK".
6) Go through "SETUP WIZARD" until you reach the "Setup WAN Interface" page. On "WAN Access Type:" select "DHCP" then click next.
7) You may configure your "Basic Wireless Settings" to Public or Private until finished configuring.
8) On "Operation Mode" be sure you operate on "Gateway" mode.
That's it! Hope this helps.
Don't forget to vote.
Mar 12, 2010 | Encore ENHWI-G2 Router
I installed my D-Link DIR-615 router today and did my setup in my Window 7 laptop. I don't know whether it matters whether I do setup in a laptop or a desktop. Then, I connect the modem/router to my...
If you have trouble connecting to your modem, you may need to lock the speed down on the WAN port of your router to 10Mbps. Within the web-based configuration utility for the router, go to Tools > Misc and the option to select the WAN speed will be towards the bottom. Not all routers have this option.
Follow the steps configuring the router once again...
Step 1 Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing).
Note: The address 192.168.0.1 is NOT on the Internet. The web-based configuration is built-in to the router.
Step 2 Click the Setup tab and then click the Internet button.
Step 3 Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address from the drop down menu. Click Clone Mac Address. Click on Save Settings to save the changes.
Step 4 Click on Status. Under WAN, Click DHCP Renew. If it does not get an IP address or times out, then continue with the next step.
Step 5 Power cycle the cable modem and router using the following steps:
Turn the cable modem off (first)
Turn the router off
Leave them off for 2 minutes**
Turn the cable modem on (first)
Wait until you get a solid cable light on the cable modem
Turn the router on
Wait 30 seconds ..
Step 6 Follow Step 1 again to log back into the web configuration. Click the Status tab and click the Device Info button. If you do not already have a public IP address under the WAN heading, click on the DHCP Renew button.
Jan 22, 2010 | D-Link DIR-615 Wireless Router
Says not secure
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
Dec 06, 2009 | Belkin (F5D9230-4) Wireless Router...
I wish to restore the factory settings for my Zyxel router
You may call on 1-800-585-2494 toll free for support on zyxel support.
Dec 31, 2008 | Zyxel Prestige 334 Router
Zyxel nbg334w router configuration
Hi
ipconfig /release
ipconfig/ renew
Dec 27, 2008 | Zyxel Prestige 334 Router
Trying to configure zyxel nbg334w router
If the router will not connect to the internet, you will need to create the PPPOE internet connection with the username and password that your ISP provided. BPCS
Dec 28, 2007 | Zyxel Prestige 334 Router
Set up with cd on MacBook
yes you are right.. the cd which came with the router will not work with mac or vista computers..
don not worry about it, you can do a manual troubleshooting to fix this problem, i will give you a step by step procedure to fix this problem..try this out ..
To setup your router for a cable modem..
first check..
Connect the Cable modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go on line,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go on line wired..
if not your router has to be configured first,
to config your router first check this settings..
Configuring TCP/Settings in MAC OS X
Step 1:
Click the Apple icon, select Location, then choose Automatic.
Step 2:
Select Built-in Ethernet under Show.
Step 3:
Click the TCP/IP tab and select Using DHCP under Configure or Configure IPv4.
Step 4:
Leave the Search domains or Additional search domains fields blank.
Step 5:
Click Apply Now.
You should now be able to access the router’s web-based set up page and configure your router.
Accessing the Router’s Web-Based Setup Page
Step 1:
Step 2:
Go to the Address bar and enter your router’s IP Address ("192.168.1.1" is the default IP of most Links-ys routers) then press [Enter].
Step 3:
A new window will prompt for a User name and Password. Leave the User name space blank, type in your router’s password ("admin" is the default password), then click OK.
Step 4:
When the router’s web-based setup page appears, click the drop-down arrow under the Internet Connection Type field and select
Automatic Configuration - DHCP.and then scroll the page down and click save settings..
Step 5:
Click MAC Address Clone you would find this sub tab at the top in the blue bar.
Step 6:
Select Enable and click Clone Your PC’s MAC.and click save settings..
Step 7:
Click Status at the to right side ion the black bar
Step 8:
Check the value of the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you’re not on-line, perform a power cycle to synchronize the router with the modem.
Power Cycling
Step 1:
Shutdown the computer.
Step 2:
Unplug the router’s power cable.
Step 3:
Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4:
Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5:
Plug in the router's power cable once the modem’s lights appear stable.
Step 6:
Power on the computer on and test the Internet connection.
Now if you are on-line wired remove the cable from the laptop and check for wireless connection
i am sure this would fix your problem in case if you have any more issues revert back to me..
Nov 30, 2007 | Linksys Wireless-G Broadband Router
Access configuration
Step 1 Verify physical connectivity by checking for solid link lights on the device. If you do not get a solid link light, try using a different cable or connect to a different port on the device if possible. If the computer is turned off, the link light may not be on. Step 2 Disable any internet security software running on the computer. Software firewalls such as Zone Alarm, Black Ice, Sygate, Norton Personal Firewall, and Windows XP firewall may block access to the configuration pages. Check the help files included with your firewall software for more information on disabling or configuring it. Step 3 Configure your Internet settings. Go to Start > Settings > Control Panel. Double-click the Internet Options Icon. From the Security tab, click the button to restore the settings to their defaults. Click the Connection tab and set the dial-up option to Never Dial a Connection. Click the LAN Settings button. Nothing should be checked. Click OK. Go to the Advanced tab and click the button to restore these settings to their defaults. Click OK out to the desktop and close any open windows. Step 4 Check your IP address. Your computer must have an IP address in the same range of the device you are attempting to configure. Most D-Link devices use the 192.168.0.X range. Click here to find your IP Address on your computer If you are attempting to configure a D-Link router, then make sure you take note of your computer´s Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1. If you are attempting to configure an Access Point or Print Server, you may need to configure your computer with a Static IP Address in the appropriate range. Step 5 Access the web management. Open your web browser and enter the IP address of your D-Link device in the address bar. This should open the login page for your the web management. Use the instructions provided with your product to login and complete the configuration.
Feb 16, 2006 | D-Link AirPlus DI-614+ Wireless Router
Can´t I access the web-based configuration
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Zyxel Prestige 334 Router Logo
277 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
