Question about Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas
Cozy 351A 35000 btu
Slight odor of gas when valve opens for pilot to light the burner. Is
that normal? Also, an odor as if the unit is still curing. The unit is
approximately two years old.
    Problem Solver:
  • 10 Answers
You might have a slight odor of gas when the burner first ignites. Some gas does escape before it completely ignites. It shouldn't smell after 2 years of use. If you can see the pilot flame burning from the top of the heater, the heater pilot assembly is pushed over too far. The pilot fumes could be escaping in the room and cause a smell.
Posted on Feb 03, 2009
    New Friend:
So...it is normal to get an occasional, quick whiff of gas?
Posted on Feb 12, 2016
Old anthes gas furnace with pilot light. burners will not light.blows cold air
Have to think that the thermocouple has failed if the pilot is on but the furnace main burner doesn't ignite
Apr 05, 2014 | Cozy (W352E) Heater
Cozy 351A 35,000BTU unit- pilot lights intermittently. When it does light, it shuts itself off with varying time frames. (Anywhere from a few minutes to few hours) Have replaced the thermocoupler- no...
I would be inclined to look seriously at the gas valve as the source of your problem. First I would check all wiring connections and make sure there is no breakage in the insulation. It's is really hard to say with something that acts differently like that but I would make sure that your pilot flame was good and strong and the thermocouple is as centered in the flames as you can get it. I would also clean burners and pilot light . When burner is on try tapping gently on the valve and main gas line to burners,when you do this the flame shoul burn more orange or yellow and then settle back down. Sometimes you can get tiny particles broke loose and burned on out.
You can bypass the turn over switch but I would only do this for test purposes. Hope this help. Thank you.
Jan 24, 2011 | Cozy Enclosed Front Console Heater 70,000...
Wall Heater
If you have already changed out the thermocouple and the pilot goes out when the burner goes out, it leads to reason that the gas valve has a weak magnet or that the pilot is dirty. The cheapest thing would be to remove the pilot assembly and clean out the orifice. If it still drops out, you will need to replace the gas valve.
Nov 02, 2009 | Heating & Cooling
Im looking for the pilot light
The pilot light is normally located over the just burner box and will have a small door or removable panel to help get to it. The easiest way to find it it to first locate the gas valve. This will be an aluminum block with a few pipes connected to it. It will also have a knob with Off, On, and Pilot written on it. Once you have found the gas valve, look for two small diameter pipes about 1/4" and 1/8" in diameter. Follow these pipes inside the burner area. It will lead to the pilot assembly. Follow the directions on the heater to start your pilot.
Oct 12, 2009 | Cozy Enclosed Front Console Heater 70,000...
New Cozy Enclosed Front Console 70,000. Pilote goes out, gas stay
its not the valve you have a problem with the heat exchanger a baffle issue have to change.
Feb 13, 2009 | Cozy Enclosed Front Console Heater 70,000...
Cozy heater 35000 btu pilot light goes out every 4 days
The thermocouple needs to get red hot. If the pilot flame is too low or too high or if it is not pointed on the thermocouple well, it won't stay hot enough. If the pilot flame is too low, a draft caused by opening a door could blow it out. If correcting this doesn't fix it, it could be a bad thermocouple or control. The factory assembly on these heaters is not the best.
Feb 02, 2009 | Cozy Enclosed Front Console Heater 70,000...
My Cozy Heater sized and installed by professional will not heat
I'm assuming your heater is the little Cozy direct vent wall furnace, your room calculations are correct, and at 57 degrees your main burner is constantly on. If so, it sounds as if you have too low a flame which can be caused by a main burner jet with an undersized orifice (like a propane one that got in the wrong assembly line) or obstructed by dirt, inadequate gas pressure, or a main gas valve that is not fully opening.
Open the pilot light inspection door and look at the main burner flame height. If it is less than 2 inches or so, check out the three possibilities above. If the flame is very yellow and wandering around lazily, check the air intake on your vent cap for obstruction.
Jan 31, 2009 | Cozy (W352E) Heater
Help it's cold here in Ohio
The "wire" you broke is probably the tube for the pilot assembly. It supplies gas to the pilot which in turn fires the burners thru a gas valve. The other option is you broke the thermocouple which causes the gas valve to open (its a safety feature incorporated to keep gas explosions from happening). You will need to replace the broken part before using this unit--period. It is not worth the danger involved trying to bypass these safety measures. BE SAFE!!!
Jan 14, 2009 | Cozy Enclosed Front Console Heater 70,000...
When unit goes on, there is a slight odor of gas when the valve
Cozy cheapened their heaters awhile back doing away with the air shutter. Without the shutter, a little gas can seep out into the room before it ignites and cause an odor. As for the curing odor, can you see the pilot flame looking down from the top of the heater? The pilot should be well inside the exchanger out of view. If you can see it, fumes from the pilot are getting into the room causing an odor. I had to remove the plate that holds the pilot assembly and drill a new hole shifting the plate over where it belongs. It was poorly assembled at the factory. Hope this helps.
Dec 27, 2008 | Cozy Enclosed Front Console Heater 70,000...
Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas Logo
225 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
